Topic: series
| Tool | Description |
| r.series.accumulate | Makes each output cell value a accumulationfunction of the values assigned to the corresponding cells in the input raster map layers. |
| r.series.interp | Interpolates raster maps located (temporal or spatial) in between input raster maps at specific sampling positions. |
See also the corresponding keyword for additional references:
series
- r.gdd - Makes each output cell value a function of the values assigned to the corresponding cells in the input raster map layers.
- r.hants - Approximates a periodic time series and creates approximated output.
- r.jpdf - From two series of input raster maps, calculates the joint probability function and outputs the probabilities of occurrence in the specified bins.
- r.patch - Creates a composite raster map layer by using known category values from one (or more) map layer(s) to fill in areas of "no data" in another map layer.
- r.quantile.ref - Determines quantile for input value from reference raster map layers.
- r.regression.series - Makes each output cell value a function of the values assigned to the corresponding cells in the input raster map layers.
- r.seasons - Extracts seasons from a time series.
- r.series - Makes each output cell value a function of the values assigned to the corresponding cells in the input raster map layers.
- r.series.accumulate - Makes each output cell value a accumulationfunction of the values assigned to the corresponding cells in the input raster map layers.
- r.series.decompose - Calculates decomposition of time series X.
- r.series.interp - Interpolates raster maps located (temporal or spatial) in between input raster maps at specific sampling positions.
- r.series.lwr - Approximates a time series and creates approximated, gap-filled output.
- t.rast.patch - Patches multiple space time raster maps into a single raster map using r.patch.
- t.rast.series - Performs different aggregation algorithms from r.series on all or a subset of raster maps in a space time raster dataset.
