Topic: temporal
| Tool | Description |
| v.what.strds | Uploads space time raster dataset values at positions of vector points to the table. |
See also the corresponding keyword for additional references:
temporal
- g.gui.timeline - wxGUI Timeline Tool
- g.gui.tplot - wxGUI Temporal Plot Tool
- m.crawl.thredds - List dataset urls from a Thredds Data Server (TDS) catalog.
- t.connect - Prints/sets general temporal GIS database connection for current mapset.
- t.copy - Creates a copy of a space time raster dataset.
- t.create - Creates a space time dataset.
- t.info - Lists information about space time datasets and maps.
- t.info.iso - Lists information about space time datasets and maps.
- t.list - Lists space time datasets and maps registered in the temporal database.
- t.merge - Merges several space time datasets into a single space time dataset.
- t.rast.accdetect - Detects accumulation patterns in temporally accumulated space time raster datasets created by t.rast.accumulate.
- t.rast.accumulate - Computes cyclic accumulations of a space time raster dataset.
- t.rast.aggregate - Aggregates temporally the maps of a space time raster dataset by a user defined granularity.
- t.rast.aggregate.ds - Aggregates data of an existing space time raster dataset using the time intervals of a second space time dataset.
- t.rast.algebra - Apply temporal and spatial operations on space time raster datasets using temporal raster algebra.
- t.rast.colors - Creates/modifies the color table associated with each raster map of the space time raster dataset.
- t.rast.contour - Produces a space time vector dataset of specified contours from a space time raster dataset.
- t.rast.export - Exports space time raster dataset.
- t.rast.extract - Extracts a subset of a space time raster datasets.
- t.rast.gapfill - Replaces gaps in a space time raster dataset with interpolated raster maps.
- t.rast.import - Imports space time raster dataset.
- t.rast.import.netcdf - Import netCDF files that adhere to the CF convention as STRDS.
- t.rast.kappa - Calculate kappa parameter in a space time raster dataset
- t.rast.line - Draws line plots of the raster maps in a space-time raster dataset
- t.rast.list - Lists registered maps of a space time raster dataset.
- t.rast.mapcalc - Performs spatio-temporal mapcalc expressions on temporally sampled maps of space time raster datasets.
- t.rast.neighbors - Performs a neighborhood analysis for each map in a space time raster dataset.
- t.rast.null - Manages NULL-values of a given space time raster dataset.
- t.rast.out.vtk - Exports space time raster dataset as VTK time series.
- t.rast.out.xyz - Export space time raster dataset to a CSV file.
- t.rast.patch - Patches multiple space time raster maps into a single raster map using r.patch.
- t.rast.series - Performs different aggregation algorithms from r.series on all or a subset of raster maps in a space time raster dataset.
- t.rast.to.rast3 - Converts a space time raster dataset into a 3D raster map.
- t.rast.to.vect - Converts a space time raster dataset into a space time vector dataset
- t.rast.univar - Calculates univariate statistics from the non-null cells for each registered raster map of a space time raster dataset.
- t.rast.what - Sample a space time raster dataset at specific vector point coordinates and write the output to stdout using different layouts
- t.rast.what.aggr - Sample a space time raster dataset at specific vector point map returning aggregate values and write the output to stdout or to attribute table
- t.rast.whatcsv - Sample a space time raster dataset at specific space-time point coordinates from a csv file and write the output to stdout
- t.rast3d.algebra - Apply temporal and spatial operations on space time 3D raster datasets using temporal 3D raster algebra.
- t.rast3d.extract - Extracts a subset of a space time 3D raster dataset.
- t.rast3d.list - Lists registered maps of a space time raster3d dataset.
- t.rast3d.mapcalc - Performs r3.mapcalc expressions on maps of sampled space time 3D raster datasets.
- t.rast3d.univar - Calculates univariate statistics from the non-null cells for each registered 3D raster map of a space time 3D raster dataset.
- t.register - Assigns timestamps and registers raster, vector and raster3d maps in a space time dataset.
- t.remove - Removes space time datasets from temporal database.
- t.rename - Renames a space time dataset
- t.sample - Samples the input space time dataset(s) with a sample space time dataset and print the result to stdout.
- t.select - Select maps from space time datasets by topological relationships to other space time datasets using temporal algebra.
- t.shift - Shifts temporally the maps of a space time dataset.
- t.snap - Snaps temporally the maps of a space time dataset.
- t.stac.catalog - Get STAC API Catalog metadata
- t.stac.collection - Get STAC API collection metadata
- t.stac.item - Downloads and imports data from a STAC API server.
- t.support - Modifies the metadata of a space time dataset.
- t.topology - Lists temporal topology of a space time dataset.
- t.unregister - Unregisters raster, vector and raster3d maps from the temporal database or a specific space time dataset.
- t.upgrade - Upgrades the version of the temporal database.
- t.vect.algebra - Apply temporal and spatial operations on space time vector datasets using temporal vector algebra.
- t.vect.db.select - Prints attributes of vector maps registered in a space time vector dataset.
- t.vect.export - Exports a space time vector dataset as GRASS specific archive file.
- t.vect.extract - Extracts a subset of a space time vector dataset.
- t.vect.import - Imports a space time vector dataset from a GRASS specific archive file.
- t.vect.list - Lists registered maps of a space time vector dataset.
- t.vect.observe.strds - Observes specific locations in a space time raster dataset over a period of time using vector points.
- t.vect.univar - Calculates univariate statistics of attributes for each registered vector map of a space time vector dataset
- t.vect.what.strds - Stores raster map values at spatial and temporal positions of vector points as vector attributes.
- v.strds.stats - Calculates univariate statistics from given space-time raster datasets based on a vector map
- v.what.strds - Uploads space time raster dataset values at positions of vector points to the table.
- v.what.strds.timestamp - Uploads space time raster dataset values to the attribute table at positions of vector points in space and time.
