Talk:Color tables
From GRASS-Wiki
Script to generate the images on this page:
by H.Bowman (GRASS wiki license)
#!/bin/sh # customize this: ADDON_DIR="/path/to/grass/svn/grass-addons/raster/r.colors.tools/palettes" g.region n=100 s=0 w=0 e=450 res=1 d.mon x0 d.resize h=100 w=450 COLOR_DIR="$GISBASE/etc/colors/" cd "$COLOR_DIR" RELATIVE=`grep '%' * | cut -f1 -d: | grep -v "matches" | uniq` ABSOLUTE=`grep -v '%' * | cut -f1 -d: | grep -v "matches" | uniq` MIXED=`grep '%' $ABSOLUTE | cut -f1 -d: | grep -v "matches" | uniq` GRASS_OVERWRITE=1 export GRASS_OVERWRITE OUTPUT_DIR=/tmp/grass/colortables/ rm -rf $OUTPUT_DIR mkdir -p $OUTPUT_DIR cd $OUTPUT_DIR draw_and_output() { d.erase d.font Vera d.legend grad -c at=55,90,4,96 --quiet echo "$1" | d.text at=50,22 align=lc size=20 color=black d.out.file Colortable_$1 --quiet --overwrite } ### relative scales. run first so tables like differences with both ### will overwrite r.mapcalc "grad = row()/1.0" for CTABLE in $RELATIVE ; do echo "[$CTABLE]" r.colors grad color=$CTABLE --quiet draw_and_output $CTABLE #read done ### absolute scales. for CTABLE in $ABSOLUTE ; do MIN=`awk '{print $1}' "$COLOR_DIR/$CTABLE" | sort -n | grep -v '^#\|^nv' | head -n 1` MAX=`awk '{print $1}' "$COLOR_DIR/$CTABLE" | sort -n | grep -v '^#\|^nv' | tail -n 1` if [ `echo "$MIN" | grep -c '%'` -gt 0 ] || \ [ `echo "$MAX" | grep -c '%'` -gt 0 ] ; then continue fi if [ $CTABLE = "population" ] ; then MAX=2500000 fi echo "[$CTABLE $MIN $MAX]" GRASS_VERBOSE=0 \ r.mapcalc "grad = if(row()==1, 1.0 * $MIN, $MAX)" r.colors grad color=$CTABLE --quiet draw_and_output $CTABLE done ### mixed scales for CTABLE in $MIXED ; do MIN=-0.04 MAX=0.04 GRASS_VERBOSE=0 \ r.mapcalc "grad = if(row()==1, 1.0 * $MIN, $MAX)" r.colors grad color=$CTABLE --quiet draw_and_output $CTABLE done ### custom scales for CTABLE in `ls $ADDON_DIR` ; do MIN=`awk '{print $1}' "$ADDON_DIR/$CTABLE" | sort -n | grep -v '^#\|^nv' | head -n 1` MAX=`awk '{print $1}' "$ADDON_DIR/$CTABLE" | sort -n | grep -v '^#\|^nv' | tail -n 1` echo "[$CTABLE $MIN $MAX]" GRASS_VERBOSE=0 \ r.mapcalc "grad = if(row()==1, 1.0 * $MIN, $MAX)" r.colors grad rules="$ADDON_DIR/$CTABLE" --quiet draw_and_output $CTABLE done echo "Files written to <$OUTPUT_DIR>"
Script to generate mini-thumbnail versions:
Requires GRASS 6.5+ newer than Sept. 2009.
#!/bin/sh # customize this: ADDON_DIR="/path/to/grass/svn/grass-addons/raster/r.colors.tools/palettes" g.region n=85 s=0 w=0 e=15 res=1 d.mon x0 d.resize h=85 w=15 COLOR_DIR="$GISBASE/etc/colors/" cd "$COLOR_DIR" RELATIVE=`grep '%' * | cut -f1 -d: | grep -v "matches" | uniq` ABSOLUTE=`grep -v '%' * | cut -f1 -d: | grep -v "matches" | uniq` MIXED=`grep '%' $ABSOLUTE | cut -f1 -d: | grep -v "matches" | uniq` GRASS_OVERWRITE=1 export GRASS_OVERWRITE OUTPUT_DIR=/tmp/grass/colortables/ rm -rf $OUTPUT_DIR mkdir -p $OUTPUT_DIR cd $OUTPUT_DIR draw_and_output() { d.erase d.colortable -n grad d.out.file Colortable_$1 --quiet --overwrite convert -rotate 90 Colortable_$1.png Colortable_$1.png } ### relative scales. run first so tables like differences with both ### will overwrite g.region -d res=600 -a r.mapcalc "grad = row()/1.0" for CTABLE in $RELATIVE ; do echo "[$CTABLE]" r.colors grad color=$CTABLE --quiet draw_and_output $CTABLE #read done ### absolute scales. for CTABLE in $ABSOLUTE ; do MIN=`awk '{print $1}' "$COLOR_DIR/$CTABLE" | sort -n | grep -v '^#\|^nv' | head -n 1` MAX=`awk '{print $1}' "$COLOR_DIR/$CTABLE" | sort -n | grep -v '^#\|^nv' | tail -n 1` if [ `echo "$MIN" | grep -c '%'` -gt 0 ] || \ [ `echo "$MAX" | grep -c '%'` -gt 0 ] ; then continue fi if [ $CTABLE = "population" ] ; then MAX=2500000 fi echo "[$CTABLE $MIN $MAX]" GRASS_VERBOSE=0 \ r.mapcalc "grad = if(row()==1, 1.0 * $MIN, $MAX)" r.colors grad color=$CTABLE --quiet draw_and_output $CTABLE done ### mixed scales for CTABLE in $MIXED ; do MIN=-0.04 MAX=0.04 GRASS_VERBOSE=0 \ r.mapcalc "grad = if(row()==1, 1.0 * $MIN, $MAX)" r.colors grad color=$CTABLE --quiet draw_and_output $CTABLE done ### custom scales for CTABLE in `ls $ADDON_DIR` ; do MIN=`awk '{print $1}' "$ADDON_DIR/$CTABLE" | sort -n | grep -v '^#\|^nv' | head -n 1` MAX=`awk '{print $1}' "$ADDON_DIR/$CTABLE" | sort -n | grep -v '^#\|^nv' | tail -n 1` echo "[$CTABLE $MIN $MAX]" GRASS_VERBOSE=0 \ r.mapcalc "grad = if(row()==1, 1.0 * $MIN, $MAX)" r.colors grad rules="$ADDON_DIR/$CTABLE" --quiet draw_and_output $CTABLE done echo "Files written to <$OUTPUT_DIR>"
