Talk:Migration from CVS to SVN
The progress in the migration...
Contents |
Gotchas
- cvs2svn is known to break binary files (images) which were not imported into the CVS with the -kb flag. Luckily Glynn fixed most of these some months ago.
- Files using keyword substitution, such as $Date$ in the description.html files, will have to have support for that enabled manually, once per file (or write a find routine with | xargs svn ...).
$ svn propset svn:keywords "Date" filename.txt $ svn commit
or
$ find . -name '*.c' | xargs svn propset svn:keywords "Date" $ find . -name '*.html' | xargs svn propset svn:keywords "Date" $ svn commit
- how to maintain timestamps of files? We want to keep the last modification date, not the date of local download
GRASS CVS repository - list of tags
Based on lstag:
devices_cleanup_20000420 freetypecap grass grassreleasebranch_5_0_0 grass_6_0_0 grass_6_0_0beta1 grass_6_0_0_beta_1 grass_6_0_0_beta_2 grass_6_0_2 grass_6_1_0 grass_6_1_0beta1 grass_6_1_0RC1 grass_6_2_0 grass_6_2_0beta1 grass_6_2_0beta2 grass_6_2_0beta3 grass_6_2_0RC1 grass_6_2_0RC2 grass_6_2_0RC3 grass_6_2_1 grass_6_2_1RC1 grass_6_2_2RC1 lastworking markus post_compare_glynn_head_2002_11_27 post_compare_glynn_release_2002_11_27 post_merge_head_2002_01_22 post_sync_2002_01_22 post_vdigit_changes_2007023 pre-curses-fix pre_fileinfo_change pre_merge_head_2002_01_22 pre_merge_release_2002_01_22 pre_sync_2001_10_31 pre_sync_2002_01_17 pre_vdigit_changes_20070221 pre_vdigit_changes_2007023 releasebranch_11_april_2001_5_0_0 releasebranch_11_april_2001_5_0_0_DEAD releasebranch_14_august_2001_5_0_0 releasebranch_26_april_2002_5_0_0 releasebranch_500 releasebranch_5_0_0 releasebranch_5_4 releasebranch_6_0 releasebranch_6_1 releasebranch_6_2 releasebranch_6_3 release_03_11_2003_grass5_0_3 release_05_11_2004_grass5_4_0 release_10_04_2003_grass5_0_2 release_13_may_2002_grass5_0_0_pre4 release_13_september_2001_grass5_0_0_pre2 release_15_05_2004_grass5_3_0 release_16_january_2002_grass5_0_0_pre3 release_17_06_2004_grass5_7_0 release_20070716_grass_6_2_2 release_20071021_grass_6_2_3RC1 release_20071024_grass_6_3_0RC1 release_20071120_grass_6_3_0RC2 release_25_06_2002_grass5_0_0_pre5 release_28_01_2003_grass5_0_1 release_30_08_2002_grass5_0_0 release_grass500pre1_20_may_2001 release_grass5beta10_7_december_2000 release_grass5beta11pre1_21_january_2001 release_grass5beta11pre2_28_january_2001 release_grass5beta11_4_february_2001 release_grass5beta6_16_feb_2000 release_grass5beta7_20_april_2000 release_grass5beta8_26_july_2000 release_grass5beta9_6_december_2000 start testbranch_5_0_0stable
According to history web-page (section GRASS 6.* development) and CVS tags, these tags are missing:
- 8/2005 GRASS 6.0.1RC1 version from ITC-irst/GRASS Development Team
- 8/2005 GRASS 6.0.1RC2 version from ITC-irst/GRASS Development Team
- 22 Aug. 2005 GRASS 6.0.1 version from ITC-irst/GRASS Development Team
- 29 Dec. 2005 GRASS 6.0.2RC1 version from ITC-irst/GRASS Development Team
- 3 Jan. 2006 GRASS 6.0.2RC2 version from ITC-irst/GRASS Development Team
- 3 Jan. 2006 GRASS 6.0.2RC3 version from ITC-irst/GRASS Development Team
- 6 Jan. 2006 GRASS 6.0.2RC4 version from ITC-irst/GRASS Development Team
Status: Resolved
Testing SVN repository
- grass/grass should be renamed to grass/grass5
Question:
- Migrate all directories or only actively used (grass, grass6, newsletter, web)?
- Create separate repositories (grass5, grass6, grassweb, grassnewsletter, grass7) or one repository (grass-svn)?
Proposed structure
Note: grass6 was created by copying files from grass5 in 2000. Development of GRASS 7 will start after migration.
Scenario 1
/grass-svn | +---/grass5 | | | +---/branches | | | +---/tags | | | +---/trunk | +---/grass6 | | | +---/branches | | | +---/tags | | | +---/trunk | +---/grass7 | | | +---/branches | | | +---/tags | | | +---/trunk | +---/grass-addons | | | +---/trunk | +---/grass-web | | | +---/trunk
Scenario 2
/grass-svn | +---/grass | | | +---/trunk (grass6 CVS HEAD) | | | +---/branches | | | | | +---/releasebranch_5_x (note: 5_5 based on grass5 CVS HEAD) | | | | | +---/releasebranch_6_x | | | +---/tags | |---/grass-addons | +---/grass-web | | | +---/trunk
Alternative version
/grass-svn | +---/trunk (grass6 CVS HEAD + grassaddons) | +---/branches | | | +---/releasebranch_5_x (note: 5_5 based on grass5 CVS HEAD) | | | +---/releasebranch_6_x | +---/tags
Scenario 3
/grass-svn | +---/trunk | | | +---/grass5 (grass5 CVS HEAD) | | | +---/grass6 (grass6 CVS HEAD) | | | +---/grass7 (grass6 CVS HEAD, then modifications) | | | +---/grassaddons (grassaddons SVN HEAD) | +---/branches | | | +---/releasebranch_5_x | | | +---/releasebranch_6_x | +---/tags
Copy of GRASS CVS repository
rsync -r --times --links --bwlimit=200 --delete rsync://rsync.intevation.de/grass grass-cvs
→ cca 600 MB!
Creating GRASS SVN repository
grass5
cvs2svn --use-cvs --no-default-eol \ --encoding="ASCII" \ --encoding="UTF-8" \ --encoding="ISO-8859-1" \ -s grass5svn-orig grass-cvs/grass
Question: exclude selected branches/tags (which one?)
According to undocumented these branches/tags are suggested to be excluded:
--exclude="Mike" \ --exclude="grass" \ --exclude="unlabeled-.*" \ --exclude=devices_cleanup_20000420 \ --exclude=post_compare_glynn_head_2002_11_27 \ --exclude=post_compare_glynn_release_2002_11_27 \ --exclude=post_merge_head_2002_01_22 \ --exclude=post_sync_2002_01_22 \ --exclude=pre-curses-fix \ --exclude=pre_merge_head_2002_01_22 \ --exclude=pre_merge_release_2002_01_22 \ --exclude=pre_sync_2001_10_31 \ --exclude=pre_sync_2002_01_17 \ --exclude=release_15_05_2004_grass5_3_0 \ --exclude=releasebranch_11_april_2001_5_0_0 \ --exclude=releasebranch_11_april_2001_5_0_0_DEAD \ --exclude=releasebranch_500 \ --exclude=releasebranch_5_0_0 \ --exclude=release_grass5beta11pre1_21_january_2001 \ --exclude=release_grass5beta11pre2_28_january_2001 \ --exclude=start \ --exclude=testbranch_5_0_0stable \ --exclude=grassreleasebranch_5_0_0 \
A lot of dependency problems:
ERROR: The branch 'unlabeled-1.7.4' cannot be excluded because the following symbols depend on it: 'release_grass500pre1_20_may_2001' 'release_13_september_2001_grass5_0_0_pre2' 'release_16_january_2002_grass5_0_0_pre3' 'releasebranch_14_august_2001_5_0_0' ERROR: The branch 'unlabeled-1.6.4' cannot be excluded because the following symbols depend on it: 'release_grass500pre1_20_may_2001' 'color_changes_20010502' 'release_13_september_2001_grass5_0_0_pre2' 'release_16_january_2002_grass5_0_0_pre3' 'releasebranch_14_august_2001_5_0_0' ...
cvs2svn --use-cvs --no-default-eol \ --encoding="ASCII" \ --encoding="UTF-8" \ --encoding="ISO-8859-1" \ --exclude="Mike" \ --exclude="grass" \ --exclude="unlabeled-.*" \ --exclude=devices_cleanup_20000420 \ --exclude=post_compare_glynn_head_2002_11_27 \ --exclude=post_compare_glynn_release_2002_11_27 \ --exclude=post_merge_head_2002_01_22 \ --exclude=post_sync_2002_01_22 \ --exclude=pre-curses-fix \ --exclude=pre_merge_head_2002_01_22 \ --exclude=pre_merge_release_2002_01_22 \ --exclude=pre_sync_2001_10_31 \ --exclude=pre_sync_2002_01_17 \ --exclude=release_03_11_2003_grass5_0_3 \ --exclude=release_05_11_2004_grass5_4_0 \ --exclude=release_10_04_2003_grass5_0_2 \ --exclude=release_13_may_2002_grass5_0_0_pre4 \ --exclude=release_13_september_2001_grass5_0_0_pre2 \ --exclude=release_15_05_2004_grass5_3_0 \ --exclude=release_16_january_2002_grass5_0_0_pre3 \ --exclude=release_17_06_2004_grass5_7_0 \ --exclude=release_25_06_2002_grass5_0_0_pre5 \ --exclude=release_28_01_2003_grass5_0_1 \ --exclude=release_30_08_2002_grass5_0_0 \ --exclude=releasebranch_11_april_2001_5_0_0 \ --exclude=releasebranch_11_april_2001_5_0_0_DEAD \ --exclude=releasebranch_500 \ --exclude=releasebranch_5_0_0 \ --exclude=release_grass500pre1_20_may_2001 \ --exclude=release_grass5beta10_7_december_2000 \ --exclude=release_grass5beta11_4_february_2001 \ --exclude=release_grass5beta11pre1_21_january_2001 \ --exclude=release_grass5beta11pre2_28_january_2001 \ --exclude=release_grass5beta6_16_feb_2000 \ --exclude=release_grass5beta7_20_april_2000 \ --exclude=release_grass5beta8_26_july_2000 \ --exclude=release_grass5beta9_6_december_2000 \ --exclude=start \ --exclude=testbranch_5_0_0stable \ --exclude=releasebranch_5_4 \ --exclude=grassreleasebranch_5_0_0 \ --exclude=releasebranch_26_april_2002_5_0_0 \ -s grass5svn grass-cvs/grass
grass6
cvs2svn --use-cvs --no-default-eol \ -s grass6svn grass-cvs/grass6 ... Error summary: ERROR: A CVS repository cannot contain both grass-cvs/grass6/display/d.erase/main.c,v and grass-cvs/grass6/display/d.erase/Attic/main.c,v ERROR: A CVS repository cannot contain both grass-cvs/grass6/general/g.mapsets/main_inter.c,v and grass-cvs/grass6/general/g.mapsets/Attic/main_inter.c,v ERROR: A CVS repository cannot contain both grass-cvs/grass6/include/gproj_api.h,v and grass-cvs/grass6/include/Attic/gproj_api.h,v ERROR: A CVS repository cannot contain both grass-cvs/grass6/visualization/nviz/src/getCat.c,v and grass-cvs/grass6/visualization/nviz/src/Attic/getCat.c,v Exited due to fatal error(s).
Question: Remove Attic files?
rm -f grass-cvs/grass6/display/d.erase/Attic/main.c,v rm -f grass-cvs/grass6/general/g.mapsets/Attic/main_inter.c,v rm -f grass-cvs/grass6/include/Attic/gproj_api.h,v rm -f grass-cvs/grass6/visualization/nviz/src/Attic/getCat.c,v
Restart
cvs2svn --use-cvs --no-default-eol \ -s grass6svn grass-cvs/grass6 ... ----- pass 2 (CollateSymbolsPass) ----- ERROR: It is not clear how the following symbols should be converted. Use --force-tag, --force-branch and/or --exclude to resolve the ambiguity. 'releasebranch_6_2' is a tag in 2 files, a branch in 5259 files and has commits in 1513 files
Restart
cvs2svn --use-cvs --no-default-eol \ --force-branch=releasebranch_6_2 \ -s grass6svn-orig grass-cvs/grass6
Exclude all undocumented braches
--exclude="grass" \
--exclude="grassreleasebranch_5_0_0" \
--exclude="markus" \
--exclude="releasebranch_14_august_2001_5_0_0" \
--exclude="releasebranch_26_april_2002_5_0_0" \
--exclude="releasebranch_5_4" \
--exclude="unlabeled.*" \
-s grass6svn1 grass-cvs/grass6
Checking for blocked exclusions...
ERROR: The branch 'markus' cannot be excluded because the following symbols depend on it:
'start'
'releasebranch_11_april_2001_5_0_0'
ERROR: The branch 'grass' cannot be excluded because the following symbols depend on it:
cvs2svn --use-cvs --no-default-eol \ --force-branch=releasebranch_6_2 \ --exclude="grass" \ --exclude="grassreleasebranch_5_0_0" \ --exclude="markus" \ --exclude="releasebranch_14_august_2001_5_0_0" \ --exclude="releasebranch_26_april_2002_5_0_0" \ --exclude="releasebranch_5_4" \ --exclude="unlabeled.*" \ --exclude="devices_cleanup_20000420" \ --exclude="post_compare_glynn_head_2002_11_27" \ --exclude="post_compare_glynn_release_2002_11_27" \ --exclude="post_merge_head_2002_01_22" \ --exclude="post_sync_2002_01_22" \ --exclude="pre-curses-fix" \ --exclude="pre_merge_head_2002_01_22" \ --exclude="pre_merge_release_2002_01_22" \ --exclude="pre_sync_2001_10_31" \ --exclude="pre_sync_2002_01_17" \ --exclude="release_03_11_2003_grass5_0_3" \ --exclude="release_05_11_2004_grass5_4_0" \ --exclude="release_10_04_2003_grass5_0_2" \ --exclude="release_13_may_2002_grass5_0_0_pre4" \ --exclude="release_13_september_2001_grass5_0_0_pre2" \ --exclude="release_15_05_2004_grass5_3_0" \ --exclude="release_16_january_2002_grass5_0_0_pre3" \ --exclude="release_17_06_2004_grass5_7_0" \ --exclude="release_25_06_2002_grass5_0_0_pre5" \ --exclude="release_28_01_2003_grass5_0_1" \ --exclude="release_30_08_2002_grass5_0_0" \ --exclude="releasebranch_11_april_2001_5_0_0" \ --exclude="releasebranch_11_april_2001_5_0_0_DEAD" \ --exclude="releasebranch_500" \ --exclude="releasebranch_5_0_0" \ --exclude="release_grass500pre1_20_may_2001" \ --exclude="release_grass5beta10_7_december_2000" \ --exclude="release_grass5beta11_4_february_2001" \ --exclude="release_grass5beta11pre1_21_january_2001" \ --exclude="release_grass5beta11pre2_28_january_2001" \ --exclude="release_grass5beta6_16_feb_2000" \ --exclude="release_grass5beta7_20_april_2000" \ --exclude="release_grass5beta8_26_july_2000" \ --exclude="release_grass5beta9_6_december_2000" \ --exclude="start" \ --exclude="testbranch_5_0_0stable" \ --exclude="unlabeled-1.1.1.1.4" \ --exclude="unlabeled-1.1.1.1.6" \ --exclude="color_changes_20010502" \ -s grass6svn grass-cvs/grass6
Question: Exclude more tags (which)?
- I guess tags "freetypecap", "lastworking", "pre_fileinfo_change" and maybe also "pre_vdigit_changes_.*" could be also excluded... --ML
Add other switches (e.g. --encoding) ??
cvs2svn --use-cvs --no-default-eol \ --force-branch=releasebranch_6_2 \ --exclude="grass" \ --exclude="grassreleasebranch_5_0_0" \ --exclude="markus" \ --exclude="releasebranch_14_august_2001_5_0_0" \ --exclude="releasebranch_26_april_2002_5_0_0" \ --exclude="releasebranch_5_4" \ --exclude="unlabeled.*" \ --exclude="devices_cleanup_20000420" \ --exclude="post_compare_glynn_head_2002_11_27" \ --exclude="post_compare_glynn_release_2002_11_27" \ --exclude="post_merge_head_2002_01_22" \ --exclude="post_sync_2002_01_22" \ --exclude="pre-curses-fix" \ --exclude="pre_merge_head_2002_01_22" \ --exclude="pre_merge_release_2002_01_22" \ --exclude="pre_sync_2001_10_31" \ --exclude="pre_sync_2002_01_17" \ --exclude="release_03_11_2003_grass5_0_3" \ --exclude="release_05_11_2004_grass5_4_0" \ --exclude="release_10_04_2003_grass5_0_2" \ --exclude="release_13_may_2002_grass5_0_0_pre4" \ --exclude="release_13_september_2001_grass5_0_0_pre2" \ --exclude="release_15_05_2004_grass5_3_0" \ --exclude="release_16_january_2002_grass5_0_0_pre3" \ --exclude="release_17_06_2004_grass5_7_0" \ --exclude="release_25_06_2002_grass5_0_0_pre5" \ --exclude="release_28_01_2003_grass5_0_1" \ --exclude="release_30_08_2002_grass5_0_0" \ --exclude="releasebranch_11_april_2001_5_0_0" \ --exclude="releasebranch_11_april_2001_5_0_0_DEAD" \ --exclude="releasebranch_500" \ --exclude="releasebranch_5_0_0" \ --exclude="release_grass500pre1_20_may_2001" \ --exclude="release_grass5beta10_7_december_2000" \ --exclude="release_grass5beta11_4_february_2001" \ --exclude="release_grass5beta11pre1_21_january_2001" \ --exclude="release_grass5beta11pre2_28_january_2001" \ --exclude="release_grass5beta6_16_feb_2000" \ --exclude="release_grass5beta7_20_april_2000" \ --exclude="release_grass5beta8_26_july_2000" \ --exclude="release_grass5beta9_6_december_2000" \ --exclude="start" \ --exclude="testbranch_5_0_0stable" \ --exclude="unlabeled-1.1.1.1.4" \ --exclude="unlabeled-1.1.1.1.6" \ --exclude="color_changes_20010502" \ --exclude="freetypecap" \ --exclude="lastworking" \ --exclude="pre_fileinfo_change" \ --encoding="ASCII" \ --encoding="UTF-8" \ --encoding="ISO-8859-1" \ -s grass6svn grass-cvs/grass6
All documented braches/tags were migrated. Repository contains also some undocumented tags: grass_6_0_0, grass_6_0_0beta1, post_vdigit_changes_2007023, pre_vdigit_changes_20070221, pre_vdigit_changes_2007023, release_20071021_grass_6_2_3RC1. In contrast releasebranch_6_0 is missing.
newsletter
SUGGESTION: merge newsletter into the OSGeo journal SVN
cvs2svn --use-cvs --no-default-eol \ --encoding="ASCII" \ --encoding="UTF-8" \ --encoding="ISO-8859-1" \ -s grassnlsvn grass-cvs/newsletter
Question: exclude branch "markus" and tags "Final_version", "ready_for_grammar_spelling_correction" and "start"?
- I guess maybe only trunk can be migrate, we don't need any branches and tags in this case... --ML
--exclude="Final_version" \
--exclude="ready_for_grammar_spelling_correction" \
--exclude="start" \
'volume1_final'
Cannot exclude branch "markus"
cvs2svn --use-cvs --no-default-eol \ --exclude="Final_version" \ --exclude="ready_for_grammar_spelling_correction" \ --exclude="start" \ --encoding="ASCII" \ --encoding="UTF-8" \ --encoding="ISO-8859-1" \ -s grassnlsvn grass-cvs/newsletter
Questions:
- Rename brach "markus"?
- Rename tags "volume[1|2]_final" to "release_vol[1|2]"?
I guess only trunk is enough -- ML
cvs2svn --use-cvs --no-default-eol \ --encoding="ASCII" \ --encoding="UTF-8" \ --encoding="ISO-8859-1" \ --trunk-only \ -s grassnlsvn grass-cvs/newsletter
web
cvs2svn --use-cvs --no-default-eol \ --encoding="ASCII" \ --encoding="UTF-8" \ --encoding="ISO-8859-1" \ -s grasswebsvn grass-cvs/web ... ERROR: A CVS repository cannot contain both grass-cvs/web/bugtracking/index.html,v and grass-cvs/web/bugtracking/Attic/index.html,v ...
Question: Remove Attic file?
rm -f grass-cvs/web/bugtracking/Attic/index.html,v
Question: Ignore branches ("markus") and tags ("start")?
cvs2svn --use-cvs --no-default-eol \ --trunk-only \ --encoding="ASCII" \ --encoding="UTF-8" \ --encoding="ISO-8859-1" \ -s grasswebsvn grass-cvs/web
grass7
Based on grass6 HEAD.
cvs2svn --use-cvs --no-default-eol \ --force-branch=releasebranch_6_2 \ --trunk-only \ --encoding="ASCII" \ --encoding="UTF-8" \ --encoding="ISO-8859-1" \ -s grass7svn grass-cvs/grass6
Scenario 1
svnadmin create grass-svn
cvs2svn --use-cvs --no-default-eol \ --encoding="ASCII" \ --encoding="UTF-8" \ --encoding="ISO-8859-1" \ --branches=grass5/branches \ --tags=grass5/tags \ --trunk=grass5/trunk \ --existing-svnrepos \ -s grass-svn grass-cvs/grass
cvs2svn --use-cvs --no-default-eol \ --force-branch=releasebranch_6_2 \ --exclude="grass" \ --exclude="grassreleasebranch_5_0_0" \ --exclude="markus" \ --exclude="releasebranch_14_august_2001_5_0_0" \ --exclude="releasebranch_26_april_2002_5_0_0" \ --exclude="releasebranch_5_4" \ --exclude="unlabeled.*" \ --exclude="devices_cleanup_20000420" \ --exclude="post_compare_glynn_head_2002_11_27" \ --exclude="post_compare_glynn_release_2002_11_27" \ --exclude="post_merge_head_2002_01_22" \ --exclude="post_sync_2002_01_22" \ --exclude="pre-curses-fix" \ --exclude="pre_merge_head_2002_01_22" \ --exclude="pre_merge_release_2002_01_22" \ --exclude="pre_sync_2001_10_31" \ --exclude="pre_sync_2002_01_17" \ --exclude="release_03_11_2003_grass5_0_3" \ --exclude="release_05_11_2004_grass5_4_0" \ --exclude="release_10_04_2003_grass5_0_2" \ --exclude="release_13_may_2002_grass5_0_0_pre4" \ --exclude="release_13_september_2001_grass5_0_0_pre2" \ --exclude="release_15_05_2004_grass5_3_0" \ --exclude="release_16_january_2002_grass5_0_0_pre3" \ --exclude="release_17_06_2004_grass5_7_0" \ --exclude="release_25_06_2002_grass5_0_0_pre5" \ --exclude="release_28_01_2003_grass5_0_1" \ --exclude="release_30_08_2002_grass5_0_0" \ --exclude="releasebranch_11_april_2001_5_0_0" \ --exclude="releasebranch_11_april_2001_5_0_0_DEAD" \ --exclude="releasebranch_500" \ --exclude="releasebranch_5_0_0" \ --exclude="release_grass500pre1_20_may_2001" \ --exclude="release_grass5beta10_7_december_2000" \ --exclude="release_grass5beta11_4_february_2001" \ --exclude="release_grass5beta11pre1_21_january_2001" \ --exclude="release_grass5beta11pre2_28_january_2001" \ --exclude="release_grass5beta6_16_feb_2000" \ --exclude="release_grass5beta7_20_april_2000" \ --exclude="release_grass5beta8_26_july_2000" \ --exclude="release_grass5beta9_6_december_2000" \ --exclude="start" \ --exclude="testbranch_5_0_0stable" \ --exclude="unlabeled-1.1.1.1.4" \ --exclude="unlabeled-1.1.1.1.6" \ --exclude="color_changes_20010502" \ --encoding="ASCII" \ --encoding="UTF-8" \ --encoding="ISO-8859-1" \ --branches=grass6/branches \ --tags=grass6/tags \ --trunk=grass6/trunk \ --existing-svnrepos \ -s grass-svn grass-cvs/grass6
cvs2svn --use-cvs --no-default-eol \ --exclude="Final_version" \ --exclude="ready_for_grammar_spelling_correction" \ --exclude="start" \ --encoding="ASCII" \ --encoding="UTF-8" \ --encoding="ISO-8859-1" \ --branches=newsletter/branches \ --tags=newsletter/tags \ --trunk=newsletter/trunk \ --existing-svnrepos \ -s grass-svn grass-cvs/newsletter
cvs2svn --use-cvs --no-default-eol \ --trunk-only \ --encoding="ASCII" \ --encoding="UTF-8" \ --encoding="ISO-8859-1" \ --trunk=web/trunk \ --existing-svnrepos \ -s grass-svn grass-cvs/web
cvs2svn --use-cvs --no-default-eol \ --force-branch=releasebranch_6_2 \ --trunk-only \ --encoding="ASCII" \ --encoding="UTF-8" \ --encoding="ISO-8859-1" \ --trunk=grass7/trunk \ --existing-svnrepos \ -s grass-svn grass-cvs/grass6
Scenario 2
Notes:
- newsletter repository can be merged with OSGeo newsletter repository
- web in separate repository outside of trac
Script available here.
Scenario 3
Moving wxPython GUI code from Add-ons to trunk
See script...
MIME types
According to Converting CVS to subversion:
CVSREPOS="$(pwd)/grass-cvs" PROJECTNAME=grass6
# Find all extensions. Also include filenames without extension. # The E (extension) and S (slash) trick is to get GNU sort to separate # them, although this is not really necessary. But note that at the # same time it removes the leading slash from filenames without extension. find $CVSREPOS/$PROJECTNAME -type f -name '*,v' ! -name '.cvsignore,v' | \ sed -e 's%.*\([./][^.]*\),v$%\1%' -e 's/\./E/' -e 's/\//S/' | \ sort -u | sed -e 's/^S//' -e 's/^E/./' > step1 # Compose an extended regular expression that matches any "extension" # as found by the previous step. EXT1="($(grep '^\.' step1 | xargs echo | sed -e 's/^\.//' -e 's/\+/\\+/g' -e 's/ \./|/g'))" # Find all mime-types and related extensions that really exist. egrep -i '^alnum:[^[:space:]]*space:+([^[:space:]]+ )*'"$EXT1"'($| )' /etc/mime.types > step2 # Extract the list of extensions from the previous step, # filtering out the extensions that we don't have. for ext in $(sed -re 's/^[^[:space:]]*space:+//' step2); do echo $ext; done | \ egrep -i '^'"$EXT1"'$' | sort -u > step3 # Compose an extended regular expression from the previous step. EXT2="($(cat step3 | xargs echo | sed -e 's/ /|/g'))" # Find all "extensions" that weren't really extensions # (or for which we don't know a MIME type). grep '^\.' step1 | egrep -iv '^\.'"$EXT2"'$' > step4 # And turn it into an extended regular expression. EXT3="($(sed -e 's/\./\\\\./' step4 | xargs echo | sed -e 's/ /|/g'))" # Create a list of files for which no MIME type is known. find $CVSREPOS/$PROJECTNAME -type f -name '*,v' ! -name '.cvsignore,v' | \ sed -e 's%.*/\([^/]*\),v$%\1%' | egrep -i "$EXT3"'$' | sort -u > step5
Binary files in 'step5':
./macosx/app/app.icns: data ./db/drivers/dbf/dbf_catalog/datetime.dbf: DBase 3 data file (2 records) ./imagery/i.atcorr/test_suite/ETM4_400x400_atms_corr.raw: data ./imagery/i.atcorr/test_suite/ETM4_400x400.raw: data ./macosx/app/English.lproj/MainMenu.nib/keyedobjects.nib: Apple binary property list ./lib/proj/nzgd2kgrid0005.gsb: data ./db/drivers/dbf/dbf_catalog/river.dbf: DBase 3 data file (5 records) ./raster/r.slope.aspect/r_sl_asp_northangle_diffs.tar.gz: gzip compressed data, was "r.slope.aspect-diffs.tar", from Unix, last modified: Tue Jul 21 20:15:15 1998 ./lib/vector/diglib/test.ok: data
Add to mine.types:
application/dbase dbf application/x-gtar gtar tgz taz tar.gz application/octet-stream bin icns raw nib gsb ok
# Create a map from extension to MIME type. If a MIME type that starts # with 'text' exist, use that - otherwise use application/octet-stream # when there is more than one MIME type, or use the single known MIME type. for f in $(cat step3); do \ MIMETYPES=$(egrep -i 'space:'$f'( |$)' step2 | sed -e 's/space:.*//'); \ echo $f: $MIMETYPES; done | \ sed -e 's%:.* \(text/[^ ]*\).*%: \1%' -e 's%: [^ ].* .*%: application/octet-stream%' > step6
? b: chemical/x-molconn-Z (only ./raster/r.le/r.le.setup/polytocell/bmf.b, I guess it should be bmf.c...) grass6/raster/r.le/r.le.setup/polytocell/bmf.b: ASCII C program text grass/src/raster/r.le/r.le.setup/polytocell/bmf.b: ASCII C program text grass/src/imagery/i.points3/inter/find.b: ASCII C program text grass/src.contrib/SCS/paint/Programs/newp.map/cmd/scan_gis.b: ASCII C program text grass/src.contrib/SCS/paint/Programs/newp.map/cmd/map.b: ASCII C program text grass/src.contrib/CERL/SGI/ISM/grid/gdwrit.b: ASCII text grass/src.garden/grass.hdf/hdf3/HDF.lib.3.2.3/doc/HDF.apdx.b: ASCII English text -> b: text/plain ? bak: application/x-trash grass/src.contrib/GMSL/sg4d/lightdefs.bak: ASCII C program text grass/src.contrib/GMSL/g3d/src3d/raster/r3.showdspf.openGL/Viz.h.bak: ASCII C program text -> bak: text/plain ? bat: application/x-msdos-program grass6/scripts/windows_launch.bat: ASCII text grass6/lib/init/grass.bat: MS-DOS batch file text grass6/lib/init/init.bat: MS-DOS batch file text grass6/lib/init/grass-run.bat: MS-DOS batch file text grass6/visualization/nviz/scripts/nviz.bat: ASCII text grass/src.contrib/CERL/raster/r.rational.regression/main.bat: ASCII C program text grass/cygwin/startxgrass.bat: MS-DOS batch file text grass/cygwin/startxwingrass.bat: MS-DOS batch file text -> bat: text/plain bin: application/octet-stream grass/src/general/g.help/help/06.export/06.02.asc.bin: ASCII English text grass/src/raster/r.out.bin: directory grass/src/raster/r.in.bin: directory grass/src/tcltkgrass/module/r.out.bin: ASCII text grass/src/tcltkgrass/module/r.in.bin: ASCII English text grass/locale/ru/tcltkgrass/module/r.out.bin: ISO-8859 text grass/locale/ru/tcltkgrass/module/r.in.bin: ISO-8859 text grass6/raster/r.out.bin: directory grass6/raster/r.in.bin: directory -> bin: text/plain cab: application/x-cab grass/src.contrib/eurogis/v.in.EE/x.cab: ASCII text -> cab: text/plain cat: application/vnd.ms-pki.seccat grass/src/scripts/contrib/i.oif/i.oif.cat: ASCII English text -> cat: text/plain application/java-vm grass/src/general/g.help/help/09.imagery/09.04.class: ASCII English text grass/src/general/g.help/help/17.manual/Help.pages/i.class: ASCII English text grass/src/imagery/i.class: directory grass6/imagery/i.class: directory -> class: text/plain c: text/x-csrc cc: text/x-c++src cpp: text/x-c++src css: text/css csv: text/csv ? dat: chemical/x-mopac-input grass6/misc/m.cogo/cogo.dat: ASCII text grass6/lib/proj/ntv1_can.dat: data grass6/lib/gis/fmode.dat: ASCII C program text grass6/raster/r.statistics/gauss.dat: ASCII text grass/src/libes/proj/ntv1_can.dat: data grass/src/sites/s.qcount/tutorial/cls.dat: ASCII text grass/src/sites/s.qcount/tutorial/reg.dat: ASCII text grass/src/sites/s.qcount/tutorial/csr.dat: ASCII text grass/src/misc/m.cogo/cogo.dat: ASCII text grass/src/raster/r.in.gridatb/example/elev.dat: ASCII text grass/src/raster/r.statistics/cmd/gauss.dat: ASCII text grass/src/paint/Drivers/versatec/patterns/ce3200.dat: ASCII English text grass/src.contrib/PURDUE/s.medp/doc/cressie.dat: ASCII English text grass/src.contrib/CERL/raster/nodenumber/xsect.dat: ASCII text grass/src.contrib/CERL/raster/nodenumber/yak_trap.dat: ASCII text -> plain/text / application/octet-stream dbf: application/dbase ? dir: application/x-director grass6/raster/r.fill.dir: setgid directory grass6/tools/cvs.rename.dir: POSIX shell script text executable grass/src/raster/r.fill.dir: setgid directory grass/src/tcltkgrass/module/r.fill.dir: ASCII text -> dir: text/plain ? doc: application/msword grass/src/fonts/original/hershey.doc: ASCII English text grass/src.contrib/SDTS/libes/fips123/bugs.doc: data grass/src.contrib/SDTS/libes/fips123/fixes.doc: data grass/src.contrib/SDTS/mapdev/v.in.sdts/filenames.doc: ASCII English text grass/src.nonGPL/agnps/r.agnps50/documentation/vrfsftwr.doc: Microsoft Word 6.0 Document eps: application/postscript fig: application/x-xfig frame: application/x-maker grass/src/display/d.frame: directory grass/src/general/g.help/help/12.map.display/12.03.d.frame: ASCII English text grass/src/general/g.help/help/17.manual/Help.pages/d.frame: ASCII English text grass/src/tcltkgrass/module/d.frame: ASCII English text grass/locale/ru/tcltkgrass/module/d.frame: ISO-8859 text grass/unused/tcltkgrass/module/d.frame: ASCII English text grass6/display/d.frame: directory -> text/plain frm: application/x-maker grass/src/general/g.help/help/04.wind.mgmt/04.02.mng.frm: ASCII English text -> text/plain gen: chemical/x-genbank grass/src/display/devices/windows/libW11/wrap/xwrappers.gen: ASCII C program text, with very long lines -> text/x-csrc hdf: application/x-hdf grass/src/tcltkgrass/module/r.out.hdf: ASCII text grass/src/tcltkgrass/module/r.in.hdf: ASCII text grass/src.garden/grass.hdf: directory grass/src.garden/grass.hdf/hdf3/old/r.out.hdf: directory grass/src.garden/grass.hdf/hdf3/old/r.in.hdf: directory grass/src.garden/grass.hdf/hdf3/r.out.hdf: directory grass/src.garden/grass.hdf/hdf3/r.in.hdf: directory grass/src.garden/grass.hdf/hdf4/r.out.hdf: directory grass/src.garden/grass.hdf/hdf4/r.in.hdf: directory grass/src.garden/grass.hdf/hdf5/r.out.hdf: directory grass/src.garden/grass.hdf/hdf5/r.in.hdf: directory grass/locale/ru/tcltkgrass/module/r.out.hdf: ISO-8859 text grass/locale/ru/tcltkgrass/module/r.in.hdf: ISO-8859 text -> hdf: text/plain gif: image/gif gsb: application/octet-stream h: text/x-chdr hh: text/x-c++hdr htm: text/html html: text/html icns: application/octet-stream ico: image/x-icon jpg: image/jpeg lyx: application/x-lyx man: application/x-troff-man me: application/x-troff-me grass/src.contrib/SCS/paint/Programs/ps.map/read.me: ASCII English text -> text/plain mid: audio/midi grass/src/CMD/generic/make.mid: ASCII English text -> text/plain mpeg: video/mpeg grass/src/raster/r.out.mpeg: directory grass/src/tcltkgrass/module/r.out.mpeg: ASCII English text grass6/raster/r.out.mpeg: directory -> text/plain application/x-troff-ms grass/unused/man/utilities/ptx.to.ms: ASCII text -> text/plain nib: application/octet-stream ok: application/octet-stream ? old: application/x-trash grass6/dist.i686-pc-linux-gnu/docs/html/gem/img1.old: PNG image data, 559 x 111, 8-bit colormap, interlaced grass6/gem/docs/GEM-Manual/img1.old: PNG image data, 559 x 111, 8-bit colormap, interlaced grass/unused/misc/m.clump/proto.h.old: ASCII C program text grass/src/raster/r.random.surface/MAN.old: troff or preprocessor input text grass/src/tcltkgrass/README.old: ASCII English text -> old: image/png for grass6 old: text/plain for grass5 pat: image/x-coreldrawpattern grass/src/paint/Drivers/versatec/patterns/ce3200.pat: ASCII text -> text/plain patch: text/x-diff pdf: application/pdf pl: text/x-perl pm: text/x-perl pbm: image/x-portable-bitmap grass/src/raster/r.in.pbm: directory grass/src/tcltkgrass/module/r.in.pbm: ASCII text -> text/plain pgm: image/x-portable-grayma grass/src/raster/r.in.pgm: directory grass/src/tcltkgrass/module/r.in.pgm: ASCII text -> text/plain png: image/png ppm: image/x-portable-pixmap grass/src/paint/Programs/p.ppm: directory grass/src/general/g.help/help/17.manual/Help.pages/p.ppm: ASCII text grass/src/raster/r.out.ppm: directory grass/src/raster/r.in.ppm: directory grass/src/raster/r.in.ppm/trees24bit.ppm: Netpbm PPM "rawbits" image data grass/src/raster/r.in.ppm/image24bit.ppm: Netpbm PPM "rawbits" image data grass/src/tcltkgrass/module/r.out.ppm: ASCII text grass/src/tcltkgrass/module/r.in.ppm: ASCII English text grass/src.contrib/SCS/paint/Drivers/grey.ppm: directory grass/locale/ru/tcltkgrass/module/r.out.ppm: ISO-8859 text grass/locale/ru/tcltkgrass/module/r.in.ppm: ISO-8859 text -> text/plain / image/x-portable-pixmap ps: application/postscript py: text/x-python raw: application/octet-stream grass/src/mapdev/v.in.arc/testdata/f1.txt.raw: ASCII text grass/src/mapdev/v.in.arc/testdata/f2.txt.raw: ASCII text grass6/imagery/i.atcorr/test_suite/ETM4_400x400.raw: data grass6/imagery/i.atcorr/test_suite/ETM4_400x400_atms_corr.raw: data -> text/plain for grass5 rgb: image/x-rgb grass/src/display/d.rgb: directory grass/src/libes/g3d/snap.rgb: SGI image data, RLE, 3-D, 573 x 372, 3 channels grass/src/general/g.help/help/17.manual/Help.pages/d.rgb: ASCII English text grass/src/general/g.help/help/17.manual/Help.pages/i.his.rgb: ASCII text grass/src/general/g.help/help/17.manual/Help.pages/r.his.rgb: ASCII text grass/src/tcltkgrass/module/d.rgb: ASCII text grass/src/tcltkgrass/module/i.his.rgb: ASCII text grass/src.contrib/GMSL/NVIZ2.2/TOGL/apps/ben.rgb: SGI image data, RLE, 3-D, 133 x 158, 3 channels grass/locale/ru/tcltkgrass/module/d.rgb: ISO-8859 text grass/locale/ru/tcltkgrass/module/i.his.rgb: ISO-8859 text grass/unused/tcltkgrass/module/d.rgb: ASCII English text grass/unused/tcltkgrass/module/i.his.rgb: ASCII English text grass6/lib/g3d/snap.rgb: SGI image data, RLE, 3-D, 573 x 372, 3 channels grass6/display/d.rgb: directory grass6/scripts/i.landsat.rgb: directory grass6/scripts/i.landsat.rgb/i.landsat.rgb: Bourne shell script text executable grass6/imagery/i.his.rgb: directory -> text/plain / image/x-rgb ros: chemical/x-rosdal grass/src/raster/wildfire/src/r.ros: directory grass/src/tcltkgrass/module/r.ros: ASCII English text grass6/raster/wildfire/r.ros: directory -> text/plain rtf: application/rtf sh: text/x-sh ? src: application/x-wais-source grass6/lib/init/grass-run.src: POSIX shell script text executable grass6/lib/init/grass.src: POSIX shell script text executable grass6/binaryInstall.src: POSIX shell script text executable grass/src/general/init/grass.src: POSIX shell script text executable grass/src/tcltkgrass/gis_set.tcl.src: ASCII English text grass/binaryInstall.src: POSIX shell script text executable -> src: text/plain ? t: application/x-troff grass6/swig/perl/t/R_slope_aspect.t: ASCII English text -> t: text/plain tcl: text/x-tcl tex: text/x-tex tgz: application/x-gtar tiff: image/tiff txt: text/plain xbm: image/x-xbitmap ? xyz: chemical/x-xyz grass6/scripts/r.out.xyz: setgid directory grass6/scripts/r.out.xyz/r.out.xyz: POSIX shell script text executable grass6/raster/r.in.xyz: setgid directory grass/src/raster/r.out.xyz: setgid directory grass/src/tcltkgrass/module/r.out.xyz: ASCII text -> xyz: text/plain
# Instead, build a props file for use with the '--auto-props=FILE' option. echo "[auto-props]" > propsfile-g5 sed -e 's%: \(text/.*\)% = svn:eol-style=native;svn:keywords=Author Date Id Revision;svn:mime-type=\1%' \ -e 's/^/*./' -e 's/: / = svn:mime-type=/' step6-g5 >> propsfile-g5 echo "[auto-props]" > propsfile-g6 sed -e 's%: \(text/.*\)% = svn:eol-style=native;svn:keywords=Author Date Id Revision;svn:mime-type=\1%' \ -e 's/^/*./' -e 's/: / = svn:mime-type=/' step6-g6 >> propsfile-g6
Remove mime-type:text/*
cat propsfile-g6 | sed -e 's/svn:mime-type=text\/.*//g' > propsfile-g6-1 cat propsfile-g5 | sed -e 's/svn:mime-type=text\/.*//g' > propsfile-g5-1
#Finish the generation of propsfile sed -re 's/(.*\.([^.]*$))/\2 \1/' -e 's/^([^.]*)$/\1 \1/' step5-g6 | sort | \ sed -e 's/^[^ ]* //' -e 's%$% = svn:eol-style=native;svn:keywords=Author Date Id Revision%' >> propsfile-g6-1 #Finish the generation of propsfile sed -re 's/(.*\.([^.]*$))/\2 \1/' -e 's/^([^.]*)$/\1 \1/' step5-g5 | sort | \ sed -e 's/^[^ ]* //' -e 's%$% = svn:eol-style=native;svn:keywords=Author Date Id Revision%' >> propsfile-g5-1
Files are available here.
