WMS
From GRASS-Wiki
Contents |
Italian Public administration WMS
Example for public administration data imported via WMS into wxGUI
NASA's OnEarth WMS Example
Web Map Service (WMS) data can be downloaded and imported into GRASS using the r.in.wms module. Mini tutorial for downloading SRTM elevation and LANDSAT imagery from NASA's OnEarth WMS server.
Create a NZTM location (EPSG:2193) with the location wizard.
# Zoom to AKL region g.region n=5936130 s=5900340 w=1740030 e=1776030 res=30
If downloading for your own area, try to keep the region rows and columns smaller than the maxrow,maxcol options given to r.in.wms. Please don't abuse the server, just download small chunks.
### Download and process SRTM elevation: r.in.wms output=akl_srtm \ mapserver="http://onearth.jpl.nasa.gov/wms.cgi" \ -c layers=worldwind_dem format=geotiff style=short_int \ maxcols=1600 maxrows=1600 g.rename akl_srtm.1,akl_srtm r.colors akl_srtm color=srtm ### Download and process LANDSAT: r.in.wms output=akl_landsat \ mapserver="http://onearth.jpl.nasa.gov/wms.cgi" \ -c layers=global_mosaic_base format=geotiff style=visual \ maxcols=1600 maxrows=1600 i.landsat.rgb -p r=akl_landsat.red g=akl_landsat.green b=akl_landsat.blue d.rgb r=akl_landsat.red g=akl_landsat.green b=akl_landsat.blue r.composite r=akl_landsat.red g=akl_landsat.green b=akl_landsat.blue \ output=akl_landsat --overwrite ### Shaeded relief map r.shaded.relief akl_strm d.shadedmap relief=akl_strm.shade drape=akl_landsat bright=70 ### 3D view nviz akl_srtm color=akl_landsat
In the NVIZ (or wxNviz) Visualization → Raster Surface menu set the fine raster grid size to 1. Set the vertical exaggeration to 1.0 or 2.0
MetaCarta WMS Example
Create a NZTM location (EPSG:4326) with the location wizard.
g.region n=90 s=-90 w=-180 e=180 res=0.5 r.in.wms -c output=map \ mapserver="http://labs.metacarta.com/wms-c/Basic.py" \ layers=basic format=geotiff \
