Widget:Ohloh Project
This widget allows you to add Ohloh Project Widgets to your wiki page.
It was created by Sergey Chernyshev.
To insert this widget, use the following code:
{{#widget:Ohloh Project|id=mediawiki-widgets|type=thin_badge}}
Parameters
- id is a number or string in project profile page URL
- type is a one of the following:
- users - users voting button
- use optional style parameter to change the style of the voting button (gray, red, green, blue, rainbow)
- thin_badge (default) - Thin Badge
- partner_badge - Partner Badge
- languages - Languages summary
- cocomo - Cocomo cost summary
- factoids - Project Factoids
- basic_stats - Project Stats
Sample result
Voting button
{{#widget:Ohloh Project|id=mediawiki-widgets|type=users|style=rainbow}}
Error in widget Ohloh Project: unable to write file /var/www/grass/grass-wiki/w/extensions/Widgets/compiled_templates/wrt6635c28953e817_92964453
Thin Badge
Error in widget Ohloh Project: unable to write file /var/www/grass/grass-wiki/w/extensions/Widgets/compiled_templates/wrt6635c2895a7cc4_85415970
Partner Badge
{{#widget:Ohloh Project|id=mediawiki-widgets|type=partner_badge}}
Error in widget Ohloh Project: unable to write file /var/www/grass/grass-wiki/w/extensions/Widgets/compiled_templates/wrt6635c2895eeb11_03905985
Languages summary
{{#widget:Ohloh Project|id=mediawiki-widgets|type=languages}}
Error in widget Ohloh Project: unable to write file /var/www/grass/grass-wiki/w/extensions/Widgets/compiled_templates/wrt6635c28960ef31_23534097
Cocomo cost summary
{{#widget:Ohloh Project|id=mediawiki-widgets|type=cocomo}}
Error in widget Ohloh Project: unable to write file /var/www/grass/grass-wiki/w/extensions/Widgets/compiled_templates/wrt6635c28962eca2_05260238
Project Factoids
{{#widget:Ohloh Project|id=mediawiki-widgets|type=factoids}}
Error in widget Ohloh Project: unable to write file /var/www/grass/grass-wiki/w/extensions/Widgets/compiled_templates/wrt6635c28964cc23_79734397
Project Stats
{{#widget:Ohloh Project|id=mediawiki-widgets|type=basic_stats}}
Error in widget Ohloh Project: unable to write file /var/www/grass/grass-wiki/w/extensions/Widgets/compiled_templates/wrt6635c289678684_71247556
