NAME
r.green.biomassfor.impact  - Calculates impact and multifunctionality values
KEYWORDS
raster,
biomass
SYNOPSIS
r.green.biomassfor.impact --help
r.green.biomassfor.impact [-r] forest=name boundaries=name forest_column_yield=string forest_column_yield_surface=string forest_column_management=string forest_column_treatment=string forest_roads=name  [forest_column_roughness=string]   [rivers=name]   [lakes=name]   [energy_tops_hf=float]   [energy_cormometric_vol_hf=float]   [energy_tops_cop=float]  energy_map=name dhp=name  [output_sw_map=name]   [dtm=name]   [soiltx_map=name]   [soild_map=name]   [soilcmp_map=name]  output_basename_co2map=name output_basename_aco2map=name output_basename_nco2map=name  [dtm2=name]   [forest_column_roughness=string]   [soilp2_map=name]   [tree_diam=name]   [tree_vol=name]   [main_roads=name]   [slp_min_cc=float]   [slp_max_cc=float]   [dist_max_cc=float]   [slp_max_fw=float]   [dist_max_fw=float]   [slp_max_cop=float]   [dist_max_cop=float]   [output_fr_map=name]   [firerisk_map=name]   [output_tot_re_map=name]   [output_imp_re_map=name]   [touristic_map=name]   [tev=name]   [field_tev=name]   [area_tev=name]   [output_tev=name]   [expl=name]   [impact=float]   [base=name]   [--overwrite]  [--help]  [--verbose]  [--quiet]  [--ui]
Flags:
- -r
- Remove all operational maps
- --overwrite
- Allow output files to overwrite existing files
- --help
- Print usage summary
- --verbose
- Verbose module output
- --quiet
- Quiet module output
- --ui
- Force launching GUI dialog
Parameters:
- forest=name [required]
- Name of vector parcel map
- boundaries=name [required]
- Name of vector boundaries map (boolean map)
- forest_column_yield=string [required]
- Vector field of yield
- forest_column_yield_surface=string [required]
- Vector field of stand surface (ha)
- forest_column_management=string [required]
- Vector field of forest management (1: high forest, 2:coppice)
- forest_column_treatment=string [required]
- Vector field of forest treatment (1: final felling, 2:thinning)
- forest_roads=name [required]
- Vector map of forest roads
- forest_column_roughness=string
- Vector field of roughness
- rivers=name
- Vector map of rivers
- lakes=name
- Vector map of lakes
- energy_tops_hf=float
- Energy for tops and branches in high forest in MWh/m3
- Default: 0.49
- energy_cormometric_vol_hf=float
- Energy for tops and branches for high forest in MWh/m3
- Default: 1.97
- energy_tops_cop=float
- Energy for tops and branches for Coppices in MWh/m3
- Default: 0.55
- energy_map=name [required]
- Bioenergy map in MWh/m3
- dhp=name [required]
- Name of vector district heating points
- output_sw_map=name
- Name for output soil and water reduction bioenergy map
- dtm=name
- Name of Digital terrain model map
- soiltx_map=name
- Soil texture map
- soild_map=name
- Soil depth map
- soilcmp_map=name
- Soil compaction risk map
- output_basename_co2map=name [required]
- Name for output CO2 emissions map
- output_basename_aco2map=name [required]
- Name for output avoided CO2 emissions map
- output_basename_nco2map=name [required]
- Name for output net CO2 emissions map
- dtm2=name
- soilp2_map=name
- Soil production map
- tree_diam=name
- Average tree diameter map
- tree_vol=name
- Average tree volume map
- main_roads=name
- Vector map of main roads
- slp_min_cc=float
- Percent slope lower limit with Cable Crane
- Default: 30.
- slp_max_cc=float
- Percent slope higher limit with Cable Crane
- Default: 100.
- dist_max_cc=float
- Maximum distance with Cable Crane
- Default: 800.
- slp_max_fw=float
- Percent slope higher limit with Forwarder
- Default: 30.
- dist_max_fw=float
- Maximum distance with Forwarder
- Default: 600.
- slp_max_cop=float
- Percent slope higher limit with other techniques for Coppices
- Default: 30.
- dist_max_cop=float
- Maximum distance with other techniques for Coppices
- Default: 600.
- output_fr_map=name
- Name for output reduction map of fire risk
- firerisk_map=name
- Fire risk map
- output_tot_re_map=name
- Name for output total recreational map
- output_imp_re_map=name
- Name for output improved recreational map
- touristic_map=name
- Touristic map
- tev=name
- Name of vector Total Economic Value map
- field_tev=name
- Name of field with TEV value
- area_tev=name
- Area of TEV polygons
- output_tev=name
- TEV result
- expl=name
- Exploited areas [Energy/m2]
- impact=float
- Percentange of the impact
- Default: 0
- base=name
- Map of the reference situation for the impact
Compute the impact of using biomass forestry residuals for energy production.
  r.green,
  r.green.biomassfor
Francesco Geri,
Pietro Zambelli,
Sandro Sacchelli,
Marco Ciolli
SOURCE CODE
  Available at:
  r.green.biomassfor.impact source code
  (history)
  Latest change: Monday Jun 28 07:54:09 2021 in commit: 1cfc0af029a35a5d6c7dae5ca7204d0eb85dbc55
Main index |
Raster index |
Topics index |
Keywords index |
Graphical index |
Full index
© 2003-2023
GRASS Development Team,
GRASS GIS 7.8.9dev Reference Manual
