GRASS logo
NAME
r.green.biomassfor.impact - Calculates impact and multifunctionality values
KEYWORDS
raster, biomass
SYNOPSIS
r.green.biomassfor.impact --help
r.green.biomassfor.impact [-r] forest=name boundaries=name forest_column_yield=string forest_column_yield_surface=string forest_column_management=string forest_column_treatment=string forest_roads=name [forest_column_roughness=string] [rivers=name] [lakes=name] [energy_tops_hf=float] [energy_cormometric_vol_hf=float] [energy_tops_cop=float] energy_map=name dhp=name [output_sw_map=name] [dtm=name] [soiltx_map=name] [soild_map=name] [soilcmp_map=name] output_basename_co2map=name output_basename_aco2map=name output_basename_nco2map=name [dtm2=name] [forest_column_roughness=string] [soilp2_map=name] [tree_diam=name] [tree_vol=name] [main_roads=name] [slp_min_cc=float] [slp_max_cc=float] [dist_max_cc=float] [slp_max_fw=float] [dist_max_fw=float] [slp_max_cop=float] [dist_max_cop=float] [output_fr_map=name] [firerisk_map=name] [output_tot_re_map=name] [output_imp_re_map=name] [touristic_map=name] [tev=name] [field_tev=name] [area_tev=name] [output_tev=name] [expl=name] [impact=float] [base=name] [--overwrite] [--help] [--verbose] [--quiet] [--ui]
Flags:
-r
Remove all operational maps
--overwrite
--help
Print usage summary
--verbose
Verbose module output
--quiet
Quiet module output
--ui
Force launching GUI dialog
Parameters:
forest=name [required]
Name of vector parcel map
boundaries=name [required]
Name of vector boundaries map (boolean map)
forest_column_yield=string [required]
Vector field of yield
forest_column_yield_surface=string [required]
Vector field of stand surface (ha)
forest_column_management=string [required]
Vector field of forest management (1: high forest, 2:coppice)
forest_column_treatment=string [required]
Vector field of forest treatment (1: final felling, 2:thinning)
forest_roads=name [required]
Vector map of forest roads
Vector field of roughness
rivers=name
Vector map of rivers
lakes=name
Vector map of lakes
Vector map of lakes
Energy for tops and branches in high forest in MWh/m3
Default: 0.49
Energy for tops and branches for high forest in MWh/m3
Default: 1.97
Energy for tops and branches for Coppices in MWh/m3
Default: 0.55
energy_map=name [required]
Bioenergy map in MWh/m3
dhp=name [required]
Name of vector district heating points
output_sw_map=name
Name for output soil and water reduction bioenergy map
dtm=name
Name of Digital terrain model map
soiltx_map=name
Soil texture map
soild_map=name
Soil depth map
soilcmp_map=name
Soil compaction risk map
output_basename_co2map=name [required]
Name for output CO2 emissions map
output_basename_aco2map=name [required]
Name for output avoided CO2 emissions map
output_basename_nco2map=name [required]
Name for output net CO2 emissions map
dtm2=name
soilp2_map=name
Soil production map
tree_diam=name
Average tree diameter map
tree_vol=name
Average tree volume map
main_roads=name
Vector map of main roads
slp_min_cc=float
Percent slope lower limit with Cable Crane
Default: 30.
slp_max_cc=float
Percent slope higher limit with Cable Crane
Default: 100.
dist_max_cc=float
Maximum distance with Cable Crane
Default: 800.
slp_max_fw=float
Percent slope higher limit with Forwarder
Default: 30.
dist_max_fw=float
Maximum distance with Forwarder
Default: 600.
slp_max_cop=float
Percent slope higher limit with other techniques for Coppices
Default: 30.
dist_max_cop=float
Maximum distance with other techniques for Coppices
Default: 600.
output_fr_map=name
Name for output reduction map of fire risk
firerisk_map=name
Fire risk map
Name for output total recreational map
Name for output improved recreational map
touristic_map=name
Touristic map
tev=name
Name of vector Total Economic Value map
field_tev=name
Name of field with TEV value
area_tev=name
Area of TEV polygons
output_tev=name
TEV result
expl=name
Exploited areas [Energy/m2]
impact=float
Percentange of the impact
Default: 0
base=name
Map of the reference situation for the impact
Table of contents
DESCRIPTION
Compute the impact of using biomass forestry residuals for energy production.
NOTES
EXAMPLE
REFERENCE
SEE ALSO
r.green, r.green.biomassfor
AUTHORS
Francesco Geri, Pietro Zambelli, Sandro Sacchelli, Marco Ciolli
SOURCE CODE
Available at: r.green.biomassfor.impact source code (history)
Latest change: Thursday Feb 20 13:02:26 2025 in commit: 53de8196a10ba5a8a9121898ce87861d227137e3
Main index | Raster index | Topics index | Keywords index | Graphical index | Full index
© 2003-2025 GRASS Development Team, GRASS GIS 8.4.3dev Reference Manual
