r.futures.gridvalidation
Module for validating land change simulation on a grid
r.futures.gridvalidation simulated=name reference=name [original=name] output=name [region=name] [subregions=name] nprocs=integer [--overwrite] [--verbose] [--quiet] [--qq] [--ui]
Example:
r.futures.gridvalidation simulated=name reference=name output=name subregions=name nprocs=1
grass.tools.Tools.r_futures_gridvalidation(simulated, reference, original=None, output, region=None, subregions=None, nprocs=1, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
tools = Tools()
tools.r_futures_gridvalidation(simulated="name", reference="name", output="name", subregions="name", nprocs=1)
grass.script.run_command("r.futures.gridvalidation", simulated, reference, original=None, output, region=None, subregions=None, nprocs=1, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
gs.run_command("r.futures.gridvalidation", simulated="name", reference="name", output="name", subregions="name", nprocs=1)
Parameters
simulated=name [required]
Simulated land use raster
reference=name [required]
Reference land use raster
original=name
Original land use raster
Required for kappa simulation
output=name [required]
Vector output with values as attributes
region=name
Name of saved region
subregions=name
Name of input vector map
Vector areas for validation
nprocs=integer [required]
Number of parallel processes
Default: 1
--overwrite
--help
Print usage summary
--verbose
Verbose module output
--quiet
Quiet module output
--qq
Very quiet module output
--ui
Force launching GUI dialog
simulated : str | np.ndarray, required
Used as: input, raster, name
reference : str | np.ndarray, required
original : str | np.ndarray, optional
output : str, required
Used as: output, vector, name
region : str, optional
Used as: input, region, name
subregions : str, optional
Used as: input, vector, name
nprocs : int, required
Default: 1
overwrite : bool, optional
Default: None
verbose : bool, optional
Default: None
quiet : bool, optional
Quiet module output
Default: None
superquiet : bool, optional
Default: None
Returns:
Raises:
simulated : str, required
reference : str, required
original : str, optional
Default: 1
Default: None
Default: None
Quiet module output
Default: None
Default: None
DESCRIPTION
Tool r.futures.gridvalidation allows to validate land change simulation results spatially. It is a wrapper around r.futures.validation that computes validation metrics for each cell of a grid or for each polygon of a vector layer. It computes:
- Allocation disagreement (total and per class), see Pontius et al, 2011
- Quantity disagreement (total and per class), see Pontius et al, 2011
- Cohen's Kappa
- Kappa simulation, see van Vliet et al, 2011
When original is provided and the input rasters contain only binary categories (0 for undeveloped and 1 for developed), the tool additionally computes change detection metrics (see r.futures.validation for details). When more than two categories are present, these metrics are skipped.
The tool operates in two modes:
- Grid mode (region): A saved region is divided into grid cells and metrics are computed for each cell. Cell size of the region should be larger than the cell size of the current computational region. The output is a point vector layer with each point at the center of a grid cell.
- Subregion mode (subregions): Metrics are computed for each polygon of the input vector layer. The output is a copy of the input vector with metrics added as attribute columns.
This tool can be used for any number of classes. Input raster original represents the initial conditions and is needed for Kappa simulation and for change detection metrics.
EXAMPLES
Validate FUTURES output by computing validation metrics
on a 5km grid.
First, reclassify FUTURES output
(where -1 is undeveloped, 0 is initially developed,
and 1 to N is the step when a cell became developed)
to binary (0 = undeveloped, 1 = developed).
Create a file reclass_rules.txt with the following
content:
-1 = 0 undeveloped
0 thru 1000 = 1 developed
Then save a region used as a grid and reclassify:
g.region res=5000 -a save=grid
r.reclass input=simulated_2016 output=simulated_2016_reclass rules=reclass_rules.txt
Run the grid validation:
r.futures.gridvalidation simulated=simulated_2016_reclass reference=reference_2016 \
original=orig_2001 output=validation_grid region=grid nprocs=4
REFERENCES
Validation methods:
- Robert Gilmore Pontius Jr & Marco Millones (2011). Death to Kappa: birth of quantity disagreement and allocation disagreement for accuracy assessment. International Journal of Remote Sensing, 32:15, 4407-4429
- Jasper van Vliet, Arnold K. Bregt, Alex Hagen-Zanker (2011) Revisiting Kappa to account for change in the accuracy assessment of land-use change models. Ecological Modelling, Volume 222, Issue 8.
FUTURES references:
- Meentemeyer, R. K., Tang, W., Dorning, M. A., Vogler, J. B., Cunniffe, N. J., & Shoemaker, D. A. (2013). FUTURES: Multilevel Simulations of Emerging Urban-Rural Landscape Structure Using a Stochastic Patch-Growing Algorithm. Annals of the Association of American Geographers, 103(4), 785-807. DOI: 10.1080/00045608.2012.707591
- Dorning, M. A., Koch, J., Shoemaker, D. A., & Meentemeyer, R. K. (2015). Simulating urbanization scenarios reveals tradeoffs between conservation planning strategies. Landscape and Urban Planning, 136, 28-39. DOI: 10.1016/j.landurbplan.2014.11.011
- Petrasova, A., Petras, V., Van Berkel, D., Harmon, B. A., Mitasova, H., & Meentemeyer, R. K. (2016). Open Source Approach to Urban Growth Simulation. Int. Arch. Photogramm. Remote Sens. Spatial Inf. Sci., XLI-B7, 953-959. DOI: 10.5194/isprsarchives-XLI-B7-953-2016
- Sanchez, G.M., A. Petrasova, A., M.M. Skrip, E.L. Collins, M.A. Lawrimore, J.B. Vogler, A. Terando, J. Vukomanovic, H. Mitasova, and R.K. Meentemeyer. 2023. Spatially interactive modeling of land change identifies location-specific adaptations most likely to lower future flood risk. Sci Rep 13, 18869. DOI: https://doi.org/10.1038/s41598-023-46195-9
SEE ALSO
r.futures.validation, FUTURES, r.futures.simulation, r.futures.parallelpga, r.futures.potential, r.futures.potsurface, r.futures.devpressure, r.futures.demand, r.futures.calib, r.sample.category
AUTHORS
Corresponding author: Anna Petrasova, akratoc ncsu edu, Center for Geospatial Analytics, NCSU
Original standalone version: Ross K. Meentemeyer, Wenwu Tang, Monica A. Dorning, John B. Vogler, Nik J. Cunniffe, Douglas A. Shoemaker (Department of Geography and Earth Sciences, UNC Charlotte) Jennifer A. Koch (Center for Geospatial Analytics, NCSU)
Port to GRASS and GRASS-specific additions: Vaclav Petras, NCSU GeoForAll
Development pressure, demand, calibration, validation, preprocessing tools and maintenance: Anna Petrasova, NCSU GeoForAll
Climate forcing submodel:
Anna Petrasova,
NCSU GeoForAll
Georgina Sanchez,
Zoning:
Margaret Lawrimore,
Anna Petrasova,
NCSU GeoForAll
SOURCE CODE
Available at: r.futures.gridvalidation source code
(history)
Latest change: Wednesday Jun 17 14:05:16 2026 in commit 2b69c1e
