r.richdem.flowaccumulation
Calculate flow accumulation using RichDEM
r.richdem.flowaccumulation input=name output=name [method=string] [exponent=float] [weights=name] [--overwrite] [--verbose] [--quiet] [--qq] [--ui]
Example:
grass.tools.Tools.r_richdem_flowaccumulation(input, output, method="D8", exponent=None, weights=None, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
tools = Tools()
tools.r_richdem_flowaccumulation(input="name", output="name")
grass.script.run_command("r.richdem.flowaccumulation", input, output, method="D8", exponent=None, weights=None, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
gs.run_command("r.richdem.flowaccumulation", input="name", output="name")
Parameters
input=name [required]
Input elevation raster
output=name [required]
Output flow accumulation raster
method=string
Flow accumulation method
Allowed values: D8, D4, Dinf, Tarboton, Quinn, Holmgren, Freeman, Rho8, Rho4, FairfieldLeymarieD8, FairfieldLeymarieD4, OCallaghanD8, OCallaghanD4
Default: D8
exponent=float
Exponent for Holmgren or Freeman methods
weights=name
Optional flow accumulation weights raster
--overwrite
--help
Print usage summary
--verbose
Verbose module output
--quiet
Quiet module output
--qq
Very quiet module output
--ui
Force launching GUI dialog
input : str | np.ndarray, required
Used as: input, raster, name
Used as: output, raster, name
method : str, optional
Default: D8
exponent : float, optional
weights : str | np.ndarray, optional
overwrite : bool, optional
Default: None
verbose : bool, optional
Default: None
quiet : bool, optional
Quiet module output
Default: None
superquiet : bool, optional
Default: None
Returns:
Raises:
input : str, required
output : str, required
Default: D8
weights : str, optional
Default: None
Default: None
Quiet module output
Default: None
Default: None
DESCRIPTION
r.richdem.flowaccumulation calculates the contributing (upslope) area for each cell in a DEM using one of several flow routing algorithms. The accumulation value at each cell equals the total number of cells---or total weighted flow---draining through it.
Flow accumulation is a fundamental quantity in terrain analysis: large values identify channels and valley bottoms, while the spatial pattern of accumulation describes the drainage network. The input DEM should be hydrologically conditioned (depressions filled or breached) before running this module.
NOTES
Flow routing methods
r.richdem.flowaccumulation supports both single-flow-direction (SFD) and multiple-flow-direction (MFD) algorithms:
Single flow direction (SFD) --- each cell drains entirely to one neighbor:
- D8 / OCallaghanD8 --- steepest descent among 8 neighbors. Classic algorithm for hydrological applications (O'Callaghan and Mark, 1984).
- D4 / OCallaghanD4 --- steepest descent among 4 cardinal neighbors only.
- Rho8 / FairfieldLeymarieD8 --- stochastic D8: the downhill neighbor is selected probabilistically in proportion to slope, reducing the parallel-flow artifact of D8 (Fairfield and Leymarie, 1991).
- Rho4 / FairfieldLeymarieD4 --- stochastic D4.
Multiple flow direction (MFD) --- flow is distributed across multiple downhill neighbors:
- Dinf / Tarboton --- flow is apportioned between the two neighbors bracketing the steepest downhill direction (Tarboton, 1997). Reduces flow concentration artifacts compared to D8.
- Quinn --- flow distributed to all lower neighbors weighted by slope; equivalent to Holmgren with exponent = 1 (Quinn et al., 1991).
- Holmgren --- flow distributed to all lower neighbors weighted by slope raised to an exponent (requires exponent parameter). Larger exponents produce more concentrated flow similar to D8; exponent = 1 is equivalent to Quinn (Holmgren, 1994).
- Freeman --- similar to Holmgren; distributes flow using slope raised to an exponent (requires exponent parameter) (Freeman, 1991).
Weighted accumulation
The optional weights map specifies the amount of flow generated by each cell. If omitted, each cell contributes 1 unit. Weights can represent precipitation, effective rainfall, or any other spatially variable runoff source.
Pre-processing
Depressions and flat areas cause incorrect or undefined flow directions. Apply r.richdem.filldepressions (with optional -e flag) or r.richdem.breachdepressions followed by r.richdem.resolveflats before computing flow accumulation.
REQUIREMENTS
This module requires the RichDEM Python package, which is not a standard GRASS GIS dependency and must be installed separately:
pip install richdem
If pip install richdem fails (the package requires a C++ compiler), build
from source:
git clone https://github.com/r-barnes/richdem.git
cd richdem/wrappers/pyrichdem
pip install -e .
Ensure that RichDEM is installed into the same Python environment used by GRASS GIS.
EXAMPLES
Compute D8 flow accumulation on a pre-filled DEM:
r.richdem.filldepressions input=dem output=dem_filled
r.richdem.flowaccumulation input=dem_filled output=accum_d8
Use D-infinity flow routing:
r.richdem.flowaccumulation input=dem_filled output=accum_dinf method=Dinf
Use the Holmgren algorithm with exponent 4 (moderately convergent):
r.richdem.flowaccumulation input=dem_filled output=accum_holmgren method=Holmgren exponent=4
Weight flow accumulation by a precipitation raster:
r.richdem.flowaccumulation input=dem_filled output=discharge method=D8 weights=precip_mm
REFERENCES
- O'Callaghan, J.F., Mark, D.M. (1984). The extraction of drainage networks from digital elevation data. Computer Vision, Graphics, and Image Processing Vol 28(3), pp 323--344. DOI: 10.1016/S0734-189X(84)80011-0
- Fairfield, J., Leymarie, P. (1991). Drainage networks from grid digital elevation models. Water Resources Research Vol 27(5), pp 709--717. DOI: 10.1029/90WR02658
- Freeman, T.G. (1991). Calculating catchment area with divergent flow based on a regular grid. Computers & Geosciences Vol 17(3), pp 413--422. DOI: 10.1016/0098-3004(91)90048-I
- Quinn, P., Beven, K., Chevallier, P., Planchon, O. (1991). The prediction of hillslope flow paths for distributed hydrological modelling using digital terrain models. Hydrological Processes Vol 5(1), pp 59--79. DOI: 10.1002/hyp.3360050106
- Holmgren, P. (1994). Multiple flow direction algorithms for runoff modelling in grid based elevation models: An empirical evaluation. Hydrological Processes Vol 8(4), pp 327--334. DOI: 10.1002/hyp.3360080405
- Tarboton, D.G. (1997). A new method for the determination of flow directions and upslope areas in grid digital elevation models. Water Resources Research Vol 33(2), pp 309--319. DOI: 10.1029/96WR03137
- Barnes, R. (2016). RichDEM: Terrain Analysis Software. URL: http://github.com/r-barnes/richdem
SEE ALSO
r.richdem.filldepressions, r.richdem.breachdepressions, r.richdem.resolveflats, r.richdem.terrainattribute, r.watershed, r.stream.extract
AUTHORS
Richard Barnes (RichDEM library)
GRASS GIS bindings: Andrew D. Wickert, with assistance from Claude Sonnet 4.6
SOURCE CODE
Available at: r.richdem.flowaccumulation source code
(history)
Latest change: Saturday May 30 11:40:25 2026 in commit 6b92b36
