Note: A new GRASS GIS stable version has been released: GRASS GIS 7. Go directly to the new manual page here
MySQL driver in GRASS
KEYWORDS
database, attribute table, driver
DESCRIPTION
MySQL database driver in GRASS enables GRASS to store vector
attributes in MySQL server.
Because vector attribute tables
are created automatically when a new vector is written and the
name of the table is the same as the name of the vector it is
good practice to create a new database for each GRASS mapset.
Creating a MySQL database
A new database is created within MySQL:
mysql> CREATE DATABASE mydb;
See the MySQL manual for details.
Driver and database name
GRASS modules require 2 parameters to connect to a database.
Those parameters are 'driver' and 'database'. For MySQL driver
the parameter 'driver' should be set to value 'mysql'.
The parameter 'database' can be given in two formats:
- Database name - in case of connection from localhost
- String of comma separated list of kye=value options.
Supported options are:
- dbname - database name
- host - host name or IP address
- port - server port number
Examples of connection parameters:
db.connect driver=mysql database=mytest
db.connect driver=mysql database='dbname=mytest,host=test.grass.org'
Data types
GRASS supports almost all MySQL data types with following limitations:
- Binary columns (BINARY, VARBINARY, TINYBLOB, MEDIUMBLOB,
BLOB, LONGBLOB) are not not supported.
If a table with binary column(s) is used in GRASS
a warning is printed and only the supported columns are
returned in query results.
- Columns of type SET and ENUM are represented as string (VARCHAR).
- Very large integers in columns of type BIGINT can be lost
or corrupted because GRASS does not support 64 bin integeres
on most platforms.
- GRASS does not currently distinguish types TIMESTAMP and
DATETIME. Both types are in GRASS interpreted as TIMESTAMP.
Indexes
GRASS modules automatically create index on key column of vector
attributes table. The index on key column is important
for performance of modules which update the attribute table,
for example v.to.db, v.distance and v.what.rast.
Privileges
Because MySQL does not support groups of users and because
only MySQL 'root' can grant privileges to other users
GRASS cannot automatically grant select privileges on created
tables to group of users.
If you want to give privilege to read data from your mapset
to other users you have to ask your MySQL server administrator
to grant select privilege to them on the MySQL database used
for that mapset. For example, to allow everybody to read data
in from your database 'mydb':
shell> mysql --user=root mysql
mysql> GRANT SELECT ON mydb.* TO ''@'%';
Schemas
Because MySQL does not support database schemas the parameter
'schema' of module db.connect should never be set to any
value. If you set that parameter for MySQL driver GRASS will
try to write tables to the specified schema which will result
in errors.
Groups
MySQL does not support user groups. Any settings specified
by 'group' parameter of module db.connect are ignored by
GRASS for MySQL driver.
Troubleshooting: SQL syntax error
Attempting to use a reserved SQL word as column or table name will result
in a "SQL syntax" error. The list of reserved words for MySQL can be
found in the MySQL manual.
SEE ALSO
db.connect,
SQL support in GRASS GIS
Credits
Development of the driver was sponsored by
Faunalia (Italy)
as part of a project for ATAC.
AUTHOR
Radim Blazek
Last changed: $Date: 2014-02-15 14:27:05 -0800 (Sat, 15 Feb 2014) $
Main index -
database index -
full index
