Note: A new GRASS GIS stable version has been released: GRASS GIS 7.4, available here.
Updated manual page: here
As results a new space time vector dataset is generated that contains a single (new) vector map that links to as many time stamped attribute tables as raster map layer are present in the input space time raster dataset. Hence, for each time step in the space time raster dataset a new attribute table is created. The GRASS GIS Temporal Framework allows to time stamp attribute tables that can be linked to a single vector map layer.
The module v.what.rast is used internally for sampling the time stamped raster map layers. All sampled values of a single time stamped raster map layer are written into a new time stamped attribute table.
Use t.vect.db.select to print attribute values of the space time vector dataset to stdout.
t.vect.observe.strds input=precip_30ynormals_3d strds=tempmean_monthly \
output=precip_stations vect=precip_stations_monthly \
columns=month
t.info precip_stations type=stvds
+-------------------- Space Time Vector Dataset -----------------------------+
+-------------------- Basic information -------------------------------------+
| Id: ........................ precip_stations@climate_2009_2012
| Name: ...................... precip_stations
| Mapset: .................... climate_2009_2012
| Creator: ................... lucadelu
| Temporal type: ............. absolute
| Creation time: ............. 2014-12-02 00:42:39.187615
| Modification time:.......... 2014-12-02 00:42:55.215169
| Semantic type:.............. mean
+-------------------- Absolute time -----------------------------------------+
| Start time:................. 2009-01-01 00:00:00
| End time:................... 2013-01-01 00:00:00
| Granularity:................ 1 month
| Temporal type of maps:...... interval
+-------------------- Spatial extent ----------------------------------------+
| North:...................... 306221.830194
| South:...................... 27606.895351
| East:.. .................... 917004.829165
| West:....................... 151768.568246
| Top:........................ 1615.44
| Bottom:..................... 2.4384
+-------------------- Metadata information ----------------------------------+
| Vector register table:...... vector_map_register_be074525097c4088997c9a1979f17065
| Number of points ........... 6664
| Number of lines ............ 0
| Number of boundaries ....... 0
| Number of centroids ........ 0
| Number of faces ............ 0
| Number of kernels .......... 0
| Number of primitives ....... 6664
| Number of nodes ............ 0
| Number of areas ............ 0
| Number of islands .......... 0
| Number of holes ............ 0
| Number of volumes .......... 0
| Number of registered maps:.. 49
| Title:
| Observaion of space time raster dataset(s) tempmean_monthly
| Description:
| Observation of space time raster dataset(s) tempmean_monthly with vector map precip_30ynormals_3d
| Command history:
| # 2014-12-02 00:42:39
| t.vect.observe.strds input="precip_30ynormals_3d"
| strds="tempmean_monthly" output="precip_stations"
| vect="precip_stations_monthly" columns="month"
v.info precip_stations_monthly
| Mapset: climate_2009_2012 |
| Database: /grassdata |
| Title: North Carolina 30 year precipitation normals (3D) |
| Map scale: 1:1 |
| Name of creator: neteler |
| Organization: |
| Source date: Wed May 9 14:32:39 2007 |
| Timestamp (first layer): none |
| Map format: native |
| Type of map: vector (level: 2) |
| Number of points: 136 Number of centroids: 0 |
| Number of lines: 0 Number of boundaries: 0 |
| Number of areas: 0 Number of islands: 0 |
| Number of faces: 0 Number of kernels: 0 |
| Number of volumes: 0 Number of holes: 0 |
| Map is 3D: Yes |
| Number of dblinks: 49 |
| Projection: Lambert Conformal Conic |
| N: 306221.830194 S: 27606.895351 |
| E: 917004.829165 W: 151768.568246 |
| B: 2.4384 T: 1615.44 |
| Digitization threshold: 0 |
| Comment: |
Last changed: $Date: 2016-02-09 09:21:24 -0800 (Tue, 09 Feb 2016) $
Available at: t.vect.observe.strds source code (history)
Main index | Temporal index | Topics index | Keywords index | Full index
© 2003-2018 GRASS Development Team, GRASS GIS 7.0.7svn Reference Manual
