Note: This document is for an older version of GRASS GIS that is outdated. You should upgrade, and read the current addon manual page.
GRASS logo
NAME
r.recode.attr - Recode raster using attribute table (csv file) as input.
KEYWORDS
raster, recode
SYNOPSIS
r.recode.attr
r.recode.attr --help
r.recode.attr [-a] input=name output=name rules=name [--help] [--verbose] [--quiet] [--ui]
Flags:
-a
Align the current region to the input raster map
--help
Print usage summary
--verbose
Verbose module output
--quiet
Quiet module output
--ui
Force launching GUI dialog
Parameters:
input=name [required]
Input map
output=name [required]
name(s) output layer(s)
rules=name [required]
Full path to rules file
Name of input file
Table of contents
DESCRIPTION
The r.reclass.attr plugin let you reclass/recode a raster layer based on values in a csv table. The csv file should include at least two columns. The first column should correspond to (part of) the raster values. The other columns should hold the reclassification values.
For each column in the csv (comma separated text) file (except the first one) a new map will be created, replacing the raster values corresponding to the first column with those in the second (3rd, 4th, etc) column.
The user can define the names of the output map(s). If only one output name is provided and the rules file contains more than two columns, the function will create output names by appending for each recode layer the corresponding column name to the output name provided by the user.
NOTES
The script uses r.recode to allow the user to reclass integer values to floating point values. However, like r.reclass you can only convert number one to one (and not like r.recode ranges of values to one value or a new range of values)
TODO
EXAMPLES
See this blog post for an example.
SEE ALSO
r.reclass, r.recode
AUTHOR
Paulo van Breugel, paulo at ecodiv.org
Last changed: $Date: 2014-12-13 09:11:08 +0100 (za, 13 dec 2014)
SOURCE CODE
Available at: r.recode.attr source code (history)
Main index | Raster index | Topics index | Keywords index | Graphical index | Full index
© 2003-2019 GRASS Development Team, GRASS GIS 7.4.5svn Reference Manual
