Note: This document is for an older version of GRASS GIS that is outdated. You should upgrade, and read the current manual page.
NAME
r.surf.gauss  - Generates a raster map using gaussian random number generator.
Mean and standard deviation of gaussian deviates can be expressed by the user.
KEYWORDS
raster,
surface,
random
SYNOPSIS
r.surf.gauss
r.surf.gauss --help
r.surf.gauss output=name  [mean=float]   [sigma=float]   [--overwrite]  [--help]  [--verbose]  [--quiet]  [--ui]
Flags:
- --overwrite
- Allow output files to overwrite existing files
- --help
- Print usage summary
- --verbose
- Verbose module output
- --quiet
- Quiet module output
- --ui
- Force launching GUI dialog
Parameters:
- output=name [required]
- Name for output raster map
- mean=float
- Distribution mean
- Default: 0.0
- sigma=float
- Standard deviation
- Default: 1.0
r.surf.gauss produces a raster map of Gaussian deviates whose
mean and standard deviation can be expressed by the user. It uses a
Gaussian random number generator. It is essentially the same
as
r.surf.random, but uses a
Gaussian random number generator instead.
g.region -p n=228500 s=215000 w=630000 e=645000 res=10
r.surf.gauss out=gauss mean=0 sigma=10
# check result
r.univar gauss
Figure: Random Gaussian surface example (mean: 0; sigma: 10)
With the histogram tool the cell values versus count can be shown.
Figure: Histogram of random Gaussian surface example (mean: 0; sigma: 10)
r.surf.contour,
r.surf.fractal,
r.surf.idw,
r.surf.random,
v.surf.rst
Jo Wood,
ASSIST's homeSOURCE CODE
  Available at:
  r.surf.gauss source code
  (history)
  Latest change: Thu Feb 3 11:10:06 2022 in commit: 73413160a81ed43e7a5ca0dc16f0b56e450e9fef
Main index |
Raster index |
Topics index |
Keywords index |
Graphical index |
Full index
© 2003-2022
GRASS Development Team,
GRASS GIS 8.0.3dev Reference Manual
