Note: This document is for an older version of GRASS GIS that is outdated. You should upgrade, and read the current manual page.
| db.in.ogr | Imports attribute tables in various formats. |
| i.in.spotvgt | Imports SPOT VGT NDVI data into a raster map. |
| r.external | Links GDAL supported raster data as a pseudo GRASS raster map. |
| r.import | Imports raster data into a GRASS raster map using GDAL library and reprojects on the fly. |
| r.in.ascii | Converts a GRASS ASCII raster file to binary raster map. |
| r.in.aster | Georeference, rectify, and import Terra-ASTER imagery and relative DEMs using gdalwarp. |
| r.in.bin | Import a binary raster file into a GRASS raster map layer. |
| r.in.gdal | Imports raster data into a GRASS raster map using GDAL library. |
| r.in.gridatb | Imports GRIDATB.FOR map file (TOPMODEL) into a GRASS raster map. |
| r.in.lidar | Creates a raster map from LAS LiDAR points using univariate statistics. |
| r.in.mat | Imports a binary MAT-File(v4) to a GRASS raster. |
| r.in.pdal | Creates a raster map from LAS LiDAR points using univariate statistics. |
| r.in.png | Imports non-georeferenced PNG format image. |
| r.in.poly | Creates raster maps from ASCII polygon/line/point data files. |
| r.in.srtm | Imports SRTM HGT files into raster map. |
| r.in.wms | Downloads and imports data from OGC WMS and OGC WMTS web mapping servers. |
| r.in.xyz | Creates a raster map from an assemblage of many coordinates using univariate statistics. |
| r.unpack | Imports a GRASS GIS specific raster archive file (packed with r.pack) as a raster map |
| r3.in.ascii | Converts a 3D ASCII raster text file into a (binary) 3D raster map. |
| r3.in.bin | Imports a binary raster file into a GRASS 3D raster map. |
| r3.in.lidar | Creates a 3D raster map from LAS LiDAR points using univariate statistics. |
| r3.in.v5d | Import 3-dimensional Vis5D files. |
| r3.in.xyz | Create a 3D raster map from an assemblage of many coordinates using univariate statistics |
| t.rast.import | Imports space time raster dataset. |
| t.vect.import | Imports a space time vector dataset from a GRASS GIS specific archive file. |
| v.external | Creates a new pseudo-vector map as a link to an OGR-supported layer or a PostGIS feature table. |
| v.import | Imports vector data into a GRASS vector map using OGR library and reprojects on the fly. |
| v.in.ascii | Creates a vector map from an ASCII points file or ASCII vector file. |
| v.in.db | Creates new vector (points) map from database table containing coordinates. |
| v.in.dxf | Converts file in DXF format to GRASS vector map. |
| v.in.e00 | Imports E00 file into a vector map. |
| v.in.geonames | Imports geonames.org country files into a vector points map. |
| v.in.lidar | Converts LAS LiDAR point clouds to a GRASS vector map with libLAS. |
| v.in.lines | Imports ASCII x,y[,z] coordinates as a series of lines. |
| v.in.mapgen | Imports Mapgen or Matlab-ASCII vector maps into GRASS. |
| v.in.ogr | Imports vector data into a GRASS vector map using OGR library. |
| v.in.pdal | Converts LAS LiDAR point clouds to a GRASS vector map with PDAL. |
| v.in.wfs | Imports GetFeature from a WFS server. |
| v.unpack | Imports a GRASS GIS specific vector archive file (packed with v.pack) as a vector map |
See also the corresponding keyword import for additional references.
Main index | Topics index | Keywords index | Graphical index | Full index
© 2003-2022 GRASS Development Team, GRASS GIS 8.0.3dev Reference Manual
