NAME
v.boxplot - Draws a boxplot of values from a specified attribute column in a vector dataset, with an optional grouping based on categories in another column.
KEYWORDS
display,
vector,
plot,
histogram,
boxplot
SYNOPSIS
v.boxplot
v.boxplot --help
v.boxplot [-honrg] map=name [layer=string] column=name [group_by=name] [where=sql_query] [output=name] [plot_dimensions=string] [dpi=integer] [fontsize=integer] [order=string] [axis_limits=string] [bx_color=name] [bx_blcolor=name] [bx_width=float] [bx_lw=float] [median_lw=float] [median_color=name] [flier_marker=string] [flier_size=string] [flier_color=name] [--overwrite] [--help] [--verbose] [--quiet] [--ui]
Flags:
- -h
- horizontal boxplot(s)
- Draw the boxplot horizontal
- -o
- Include outliers
- Draw boxplot(s) with outliers
- -n
- notch
- Draw boxplot(s) with notch
- -r
- Rotate labels
- rotate x-axis labels
- -g
- Add grid lines
- Add grid lines
- --overwrite
- Allow output files to overwrite existing files
- --help
- Print usage summary
- --verbose
- Verbose module output
- --quiet
- Quiet module output
- --ui
- Force launching GUI dialog
Parameters:
- map=name [required]
- Name of vector map
- Or data source for direct OGR access
- layer=string
- Layer number or name
- Vector features can have category values in different layers. This number determines which layer to use. When used with direct OGR access this is the layer name.
- Default: 1
- column=name [required]
- Attribute column value to be plotted
- group_by=name
- Attribute column with categories to group the data by
- where=sql_query
- WHERE conditions of SQL statement without 'where' keyword
- Example: income < 1000 and population >= 10000
- output=name
- Name of output image file
- Name for output file
- plot_dimensions=string
- Plot dimensions (width,height)
- Dimensions (width,height) of the figure in inches
- dpi=integer
- DPI
- resolution of plot
- Default: 100
- fontsize=integer
- Font size
- Default font size
- Default: 10
- order=string
- Sort boxplots
- Sort boxplots based on their median values
- Options: descending, ascending
- axis_limits=string
- Limit value axis [min,max]
- min and max value of y-axis, or x-axis if -h flag is set)
- bx_color=name
- Color of the boxplots
- Color of boxplots
- Default: white
- bx_blcolor=name
- Color of the borders of the boxplots
- Color of the borderlines of the boxplots
- Default: black
- bx_width=float
- Boxplot width
- The width of the boxplots (0,1])
- Options: 0.1-1
- Default: 0.75
- bx_lw=float
- boxplot linewidth
- The boxplots border, whisker and cap line width
- Default: 1
- median_lw=float
- width of the boxplot median line
- Default: 1.1
- median_color=name
- Color of the boxlot median line
- Color of median
- Default: orange
- flier_marker=string
- Flier marker
- Set flier marker (see https://matplotlib.org/stable/api/markers_api.html for options)
- Default: o
- flier_size=string
- Flier size
- Set the flier size
- Default: 2
- flier_color=name
- Flier color
- Set the flier color
- Default: black
The v.boxplot module draws a boxplot of the values in a vector
map attribute column. Users can use the
where option to select a subset of the attribute table. Values
in the column can also be grouped according to the categories in
another column (group_by), creating separate boxplots for each
group.
Options to customize the appearance of the plot include rotating the
plot and x-axis labels, adding notches, removing outliers, and defining
the colors of various boxplot components. By default, the resulting
plot is displayed on the screen. However, users can save the plot to a
file by specifying the desired width, height, and resolution. The
format of the saved file is determined by the provided file extension.
For example, if plot_output = outputfile.png, the plot will be
saved as a PNG file.
Use the vector layer
schools_wake from the
NC sample
dataset to create boxplots of the core capacity of schools in
Wake County, North Carolina. Use the
Where clause to exclude
all records with no data. Use the
-o flag to draw outliers.
v.boxplot -n -o map=schools_wake column=CORECAPACI where="CORECAPACI >0"
Figure 1: Boxplot of
core capacity of schools in Wake County.
NC sample dataset to
create boxplots of the core capacity of the schools in Wake County,
North Carolina, grouped by city. Use the
Where clause to
exclude all records with missing data. Use the
-o flag to draw
outliers.
v.boxplot -h -o map=schools_wake column=CORECAPACI where="CORECAPACI >0" group_by=ADDRCITY order=ascending
Figure 2: Boxplot of core capacity of schools
in Wake County, grouped by city.
v.scatterplot,
d.vect.colhist,
r.boxplot,
r.series.boxplot,
t.rast.boxplot,
r.scatterplot
r3.scatterplot
Paulo van Breugel,
HAS green academy,
Innovative
Biomonitoring research group,
Climate-robust
Landscapes research group
SOURCE CODE
Available at:
v.boxplot source code
(history)
Latest change: Thursday Feb 20 13:02:26 2025 in commit: 53de8196a10ba5a8a9121898ce87861d227137e3
Main index |
Vector index |
Topics index |
Keywords index |
Graphical index |
Full index
© 2003-2024
GRASS Development Team,
GRASS GIS 8.3.3dev Reference Manual
