Image classification
From GRASS-Wiki
Jump to: navigation, search
Contents
Classification methods in GRASS
radiometric
unsupervised
radiometric
supervised 1
radiometric
supervised 2
radiometric & geometric
supervised
Image Preprocessing r.seg
Preprocessing i.cluster i.class (monitor digitizing) i.gensig (using training maps) i.gensigset (using training maps)
Classification i.maxlik i.maxlik i.maxlik i.smap
Remarks automated run based requires digitalization requires digitalization requires digitalization
on image statistics of training areas of training areas of training areas
You can digitize training areas with either r.digit (not recommended) or v.digit + v.to.rast (recommended)
Image Preprocessing (optional)
  • r.seg - produces a smooth approximation of the data and performs discontinuity detection. The module is based on the Mumford-Shah variational model for image segmentation. Used as pre-analysis for a subsequent classification.
For details, see the r.seg documentation
Interactive setup
  • i.class - Generates spectral signatures for an image by allowing the user to outline regions of interest.
The resulting signature file can be used as input for i.maxlik or as a seed signature file for i.cluster.
Preprocessing
  • i.cluster - Generates spectral signatures for land cover types in an image using a clustering algorithm.
The resulting signature file is used as input for i.maxlik, to generate an unsupervised image classification.
Unsupervised classification
  • i.maxlik - Classifies the cell spectral reflectances in imagery data.
Classification is based on the spectral signature information generated by either i.cluster, i.class, or i.gensig.
See example below.
Supervised classification
  • i.smap - Performs contextual (image segmentation) image classification using sequential maximum a posteriori (SMAP) estimation.
  • In case of panchromatic maps or limited amount of channels, it is often recommended to generate synthetic channels through texture analysis (r.texture)
See example below.
Small classification tutorial
Required: GRASS >= 6.4.0
We are using Landsat satellite data prepared for the North Carolina sampling site. It is a multispectral dataset where each channel is stored in a separate map.
We are using the North Carolina location here.
Warming up with Landsat TM
 # look what maps are there
 g.list rast
 # set to one of the color channels and print current region settings
 g.region rast=lsat7_2002_10 -p
 # look at some Landsat map (1: blue, 2: green, 3: red, 4: near infrared etc.)
 d.mon x0
 d.rast lsat7_2002_10
 d.rast lsat7_2002_20
 d.rast lsat7_2002_30
 d.rast lsat7_2002_40
We can easily query the spectrum for individual points:
 d.what.rast lsat7_2002_10,lsat7_2002_20,lsat7_2002_30,lsat7_2002_40
Histogram of a channel:
 d.histogram lsat7_2002_10
Create RGB view on the fly, true and false color:
 d.rgb b=lsat7_2002_10 g=lsat7_2002_20 r=lsat7_2002_30
 d.rgb b=lsat7_2002_70 g=lsat7_2002_20 r=lsat7_2002_30
 d.rgb b=lsat7_2002_70 g=lsat7_2002_50 r=lsat7_2002_30
 d.rgb b=lsat7_2002_70 g=lsat7_2002_50 r=lsat7_2002_10
Check thermal channel (encoded to fit into 0.255 data range):
  1. http://landsathandbook.gsfc.nasa.gov/handbook/handbook_htmls/chapter11/chapter11.html
  2. Look up LMIN/LMAX: "Table 11.2 ETM+ Spectral Radiance Range watts/(meter squared * ster * µm)"
  3. we won't go into details here, r.mapcalc would be used to convert to Kelvoin/degree Celsius.
 # look at encoded thermal channel
 d.rast lsat7_2002_61
NDVI as example for map algebra:
 r.mapcalc "ndvi = 1.0 * (lsat7_2002_40 - lsat7_2002_30)/(lsat7_2002_40 + lsat7_2002_30)"
 d.rast.leg ndvi
 r.colors ndvi color=ndvi
 d.rast.leg ndvi
Show selected NDVI "classes":
 d.rast ndvi val=0.3-1.0
 d.rast ndvi val=-1.0--0.1
 d.rast ndvi val=0.0-0.2
 d.rast ndvi val=0.0-0.3
Look at panchromatic channel, compare resolution:
 g.region rast=lsat7_2002_80 -p
 d.erase -f
 d.rast lsat7_2002_80
 d.zoom
Image Classification
Set region setting to red image:
 g.region rast=lsat7_2002_30 -p
Create a group
 i.group group=lsat7_2002 subgroup=lsat7_2002 \
   input=lsat7_2002_10,lsat7_2002_20,lsat7_2002_30,lsat7_2002_40,lsat7_2002_50,lsat7_2002_70
Generate unsupervised statistics
 i.cluster  group=lsat7_2002 subgroup=lsat7_2002 sigfile=lsat7_2002_sig classes=10 reportfile=lsat7_2002.txt
 # look at report file
 gedit lsat7_2002.txt
Assign pixels to classes, check quality of assignment:
 i.maxlik group=lsat7_2002 subgroup=lsat7_2002 sigfile=lsat7_2002_sig class=lsat7_2002_class reject=lsat7_2002_reject
 # false color composite
 d.mon x0 ; d.font Vera
 # classification result
 d.mon x1 ; d.font Vera
 d.rast.leg lsat7_2002_class
 # rejection map
 d.mon x2 ; d.font Vera
 d.rast.leg lsat7_2002_reject
 # rejection histogram
 d.mon x3 ; d.font Vera
 d.histogram lsat7_2002_reject
NC Landsat map 2002 - false color composite
unsupervised classification
unsupervised classification rejection map histogram
Play with different cluster separations:
 i.cluster group=lsat7_2002 subgroup=lsat7_2002 sigfile=lsat7_2002_sig classes=10 reportfile=lsat7_2002.txt separation=1.5
 i.maxlik group=lsat7_2002 subgroup=lsat7_2002 sigfile=lsat7_2002_sig class=lsat7_2002_class2 reject=lsat7_2002_reject2
 d.mon x4
 d.rast.leg lsat7_2002_class2
 d.rast.leg lsat7_2002_reject2
Compare to RGB:
 d.rast lsat7_2002_class2 cat=1 -o
 d.rast lsat7_2002_class cat=1 -o
We do a 3rd attempt with more classes
 i.cluster group=lsat7_2002 subgroup=lsat7_2002 sigfile=lsat7_2002_sig classes=15 reportfile=lsat7_2002.txt
 i.maxlik group=lsat7_2002 subgroup=lsat7_2002 sigfile=lsat7_2002_sig class=lsat7_2002_class3 reject=lsat7_2002_reject3
 d.rast.leg lsat7_2002_class3
unsupervised classification with 15 classes
Launch GUI for digitizer:
 g.gui wxpython
Now digitize training areas of water, asphalt, forest, uncovered soil on RGB composite in GUI. Digitize polygons/centroids with attributes. The advantage: we know what the classes are.
NC Landsat map 2002 - training areas
Assign also numerical ID for each class in new column
 v.db.select lsat7_training
 v.db.addcol lsat7_training col="id integer"
 v.db.update lsat7_training col=id where="name = 'water'" val=1
 v.db.update lsat7_training col=id where="name = 'forest'" val=2
 v.db.update lsat7_training col=id where="name = 'asphalt'" val=3
 v.db.update lsat7_training col=id where="name = 'soil'" val=4
Transform vector training map to raster model:
 g.region vect=lsat7_training align=lsat7_2002_10 -p
 v.to.rast in=lsat7_training out=lsat7_training use=attr col=id labelcol=name --o
 d.mon x0
 d.rast.leg lsat7_training
Generate statistics from training areas
 i.gensigset group=lsat7_2002 subgroup=lsat7_2002 sig=lsat7_2002_smap training=lsat7_training
Perform supervised classification
 i.smap group=lsat7_2002 subgroup=lsat7_2002 sig=lsat7_2002_smap  out=smap
Colorize:
 r.colors smap rules=- << EOF
1 aqua 2 green 3 180 180 180 4 brown EOF
 d.rast.leg smap
SMAP supervised classification
Vectorize result:
 r.to.vect smap out=smap feat=area
 d.vect smap  type=boundary col=red
That's it :)
Further reading classification with GRASS
Personal tools
Namespaces
Variants
Actions
Navigation
Toolbox
