Installation Guide
From GRASS-Wiki
Jump to: navigation, search
Contents
General
For compilation of GRASS GIS source code, see Compile and Install
This page explains the installation of GRASS binaries.
GRASS GIS requires a workstation running either some flavor of UNIX conforming to POSIX standards like Linux, Mac OS X, Solaris, IRIX, or BSD or MS-Windows. It is also possible to run GRASS in MS Windows by using UNIX translation software such as Cygwin or natively with MingGW. Ideally, you should have at least 500 Mb for data and 512 Mb RAM. The source code package needs around 270 MB uncompressed. The resulting binaries may need between 20 MB and 180 MB depending on your platform. During a full compilation you may need temporarily up to 150MB including the source code.
The Software Download Section of the main GRASS web site contains the latest binaries and source code for all supported platforms. That site also has general directions for installing GRASS manually. However, installation is slightly different on each operating system. Here you can find user-contributed pointers for installing GRASS on specific platforms. In particular, many operating systems have package management utilities that can greatly simplify GRASS installation.
MS-Windows
  • winGRASS/Cygwin packages are provided here (requires Cygwin unix emulator, see there).
  • QGIS including native winGRASS packages are provided here (no Cygwin needed).
  • Install using OSGeo4W installer (GRASS needs to be selected from the "Advanced" section)
GNU/Linux
Debian
A binary version of GRASS is available from the apt repository. As root type:
 apt-get install grass grass-doc
This is the easiest way to install GRASS on Debian. If you choose to install a binary version manually from the main web site, be sure to follow the instructions for making symlinks found as a note to the [6.4 weekly snapshot] release.
DebianGis
There is also the wonderful DebianGIS project which has a more recent GRASS version with its related packages. Read here for more details
Compiling GRASS from source
Installation on Fedora
Fedoraproject provides RPM-packages for stable releases prepared to install on Fedora systems.
Mandriva
  • Mandriva provides PROJ/GDAL/GRASS RPMs. Newer versions they are in the "backports" section:
 urpmi grass
SuSE
  • OpenSuSE provides GRASS and related RPM-packages.
Red Hat Enterprise Linux (RHEL, CentOS and Scientific Linux)
Ubuntu
GRASS Binaries are available from apt/synaptic. From a terminal type:
 sudo apt-get install grass grass-doc
or alternatively, search for and install these packages from Synaptic. This is the easy way to get GRASS on your system. Even if you choose to install binaries from another source, you may want to install this version just so that all (most) dependencies are installed as painlessly as possible.
To get the latest version of GRASS on Ubuntu, compile the code from source. See the Compile and Install section for a shell script that makes this easy.
Slackware
Slackware 12 packages for GRASS binary distributions and additional libraries are available from The Italian Slackware Community (release version) and here (SVN version).
Mac OS X
Precompiled Mac OSX packages can be found here
Personal tools
Namespaces
Variants
Actions
Navigation
Toolbox
In other languages
