Planetary mapping
From GRASS-Wiki
Jump to: navigation, search
Contents
GIS Support
  • GRASS lat/lon regions may be used as 0-360 longitude, not just 180 east+west.
  • You can set and add custom ellipsoids, see the g.setproj module. Permanently adding custom ellipsoids can be done by hand, the config tables for that are plain self-documenting text files, so reasonably easy to edit. We would of course be happy to include standard planetary ellipsoids along with future versions GRASS. An ellipse table with planetary spheroids (to put as $GISBASE/etc/*.table files) is available here.
Open Issues
  • r.out.gdal exports 'unknown' ellipsoids / datums, and also the reference meridian is named 'Greenwich'
Example of the use of GRASS GIS in Planetary Research
GRASS ps.map output as published in an article in the journal Science.
Data
Data summary (1999):
 http://publish.uwo.ca/~pjstooke/mapsummy.txt
Modules
Mars topography
See tutorial in GRASSNews volume 1:
Global dataset of bathymetry and topography. GRASS Newsletter, 1:8-11, August 2004. ISSN 1614-8746.
Screenshots
See also
  • Frigeri, A, Hare, T, Neteler, M., Coradini, A, Federico, C, Orosei, R. (2011). A research environment for digital planetary data processing and mapping using ISIS and GRASS GIS. Planetary and Space Science, 59(11-12), pp.1265-1272 [ DOI | PDF ]
Personal tools
Namespaces
Variants
Actions
Navigation
Toolbox
