NAME
v.voronoi - Creates a Voronoi diagram from an input vector map containing points or centroids.
KEYWORDS
vector
SYNOPSIS
v.voronoi
v.voronoi help
v.voronoi [-lt] input=name output=name [--overwrite] [--verbose] [--quiet]
Flags:
- -l
- Output tessellation as a graph (lines), not areas
- -t
- Do not create attribute table
- --overwrite
- Allow output files to overwrite existing files
- --verbose
- Verbose module output
- --quiet
- Quiet module output
Parameters:
- input=name
- Name of input vector map
- output=name
- Name for output vector map
DESCRIPTION
v.voronoi uses an existing vector points map (input) to create
a Voronoi diagram (Thiessen polygons) in a new vector map (output).
The bounds of the output map are limited by the current region.
(see g.region)
Voronoi diagram and Delaunay triangulation example:
Delaunay Triangulation (left pane), Voronoi diagram (center pane),
and both (right pane)
NOTES
Voronoi diagrams may be used for nearest-neighbor flood filling.
Give the centroids attributes (start with
v.db.addcol),
then optionally convert to a raster map with
v.to.rast.
EXAMPLE
Commands used with the Spearfish dataset to create the above figure.
g.region n=4927250 s=4919400 w=588650 e=594850
d.frame -c fr=one at=0,100,0,33.3333
d.frame -c fr=two at=0,100,33.3333,66.6667
d.frame -c fr=three at=0,100,66.6667,100
v.delaunay -lr in=archsites out=arch_delaunay
d.frame -s one
d.vect arch_delaunay
d.vect archsites color=red fcolor=red size=5 icon=basic/circle
v.voronoi -l in=archsites out=arch_voronoi
d.frame -s two
d.vect arch_voronoi type=line
d.frame -s three
d.vect arch_delaunay color=blue
BUGS
Only attribute table of field 1 is copied.
REFERENCES
Steve J. Fortune, (1987). A Sweepline Algorithm for
Voronoi Diagrams, Algorithmica 2, 153-174.
SEE ALSO
g.region,
v.delaunay,
v.hull
AUTHORS
James Darrell McCauley, Purdue University
GRASS 5 update, improvements: Andrea Aime, Modena, Italy
GRASS 5.7 update: Radim Blazek
Last changed: $Date: 2007-11-14 17:50:31 -0800 (Wed, 14 Nov 2007) $
Main index - vector index - Full index
© 2003-2008 GRASS Development Team
