GRASS logo
NAME
r.futures.gridvalidation - Module for validating land change simulation on a grid
KEYWORDS
raster, statistics, accuracy, validation
SYNOPSIS
r.futures.gridvalidation --help
r.futures.gridvalidation simulated=name reference=name [original=name] [allocation_disagreement=name] [allocation_disagreement_basename=basename] [quantity_disagreement=name] [quantity_disagreement_basename=basename] [kappa=name] [kappasimulation=name] region=name nprocs=integer [--overwrite] [--help] [--verbose] [--quiet] [--ui]
Flags:
--overwrite
--help
Print usage summary
--verbose
Verbose module output
--quiet
Quiet module output
--ui
Force launching GUI dialog
Parameters:
simulated=name [required]
Simulated land use raster
reference=name [required]
Reference land use raster
original=name
Original land use raster
Required for kappa simulation
Output total allocation disagreement raster
Basename for per class allocation disagreement raster
Output total quantity disagreement raster
Basename for per class quantity disagreement raster
kappa=name
Output Cohen's kappa raster
Output kappa simulation raster
region=name [required]
Name of saved region
nprocs=integer [required]
Number of parallel processes
Default: 1
Table of contents
DESCRIPTION
Module r.futures.gridvalidation allows to validate land change simulation results on a spatial grid. It computes: These metrics are computed for each cell of a region provided in region option resulting in spatially variable validation results. Cell size of the region should be larger than the cell size of the current region.
This module can be used for any number of classes. Input raster original represents the initial conditions and is needed only for Kappa simulation.
EXAMPLES
Validate FUTURES output by computing quantity and allocation disagreement on a 5km grid. First reclassify FUTURES output to 0 (undeveloped) and 1 (developed) by creating a text file "rules.txt" with the following content:
-1 = 0
0 thru 100 = 1
Then save a region used as a grid:
g.region res=5000 -a save=grid
Reclass FUTURES output:
r.reclass input=simulated_2016 output=simulated_2016_reclass rules=rules.txt
Validate FUTURES output by computing kappa simulation on a 5km grid:
r.futures.gridvalidation simulated=simulated_2016_reclass reference=reference_2016 original=orig_2001 kappasimulation=kappasim
SEE ALSO
FUTURES, r.futures.pga, r.futures.potential, r.futures.devpressure, r.futures.demand, r.futures.calib, r.sample.category
REFERENCES
AUTHOR
Anna Petrasova, NCSU GeoForAll
SOURCE CODE
Available at: r.futures.gridvalidation source code (history)
Accessed: Monday Feb 02 05:17:02 2026
Main index | Raster index | Topics index | Keywords index | Graphical index | Full index
© 2003-2023 GRASS Development Team, GRASS GIS 7.8.9dev Reference Manual
