GRASS logo
NAME
r.green.biomassfor.co2 - Calculates impact and multifunctionality values
KEYWORDS
raster, biomass
SYNOPSIS
r.green.biomassfor.co2 --help
r.green.biomassfor.co2 [-r] forest=name boundaries=name forest_column_yield=string forest_column_yield_surface=string forest_column_management=string forest_column_treatment=string forest_roads=name [forest_column_roughness=string] [rivers=name] [lakes=name] [energy_tops_hf=float] [energy_cormometric_vol_hf=float] [energy_tops_cop=float] energy_map=name dhp=name [output_basename_co2map=name] [output_basename_aco2map=name] [output_basename_nco2map=name] [dtm=name] [forest_column_roughness=string] [soilp2_map=name] [tree_diam=name] [tree_vol=name] [main_roads=name] [slp_min_cc=float] [slp_max_cc=float] [dist_max_cc=float] [slp_max_fw=float] [dist_max_fw=float] [slp_max_cop=float] [dist_max_cop=float] [--overwrite] [--help] [--verbose] [--quiet] [--ui]
Flags:
-r
Remove all operational maps
--overwrite
--help
Print usage summary
--verbose
Verbose module output
--quiet
Quiet module output
--ui
Force launching GUI dialog
Parameters:
forest=name [required]
Name of vector parcel map
boundaries=name [required]
Name of vector boundaries map (boolean map)
forest_column_yield=string [required]
Vector field of yield
forest_column_yield_surface=string [required]
Vector field of stand surface (ha)
forest_column_management=string [required]
Vector field of forest management (1: high forest, 2:coppice)
forest_column_treatment=string [required]
Vector field of forest treatment (1: final felling, 2:thinning)
forest_roads=name [required]
Vector map of forest roads
Vector field of roughness
rivers=name
Vector map of rivers
lakes=name
Vector map of lakes
Vector map of lakes
Energy for tops and branches in high forest in MWh/m3
Default: 0.49
Energy for tops and branches for high forest in MWh/m3
Default: 1.97
Energy for tops and branches for Coppices in MWh/m3
Default: 0.55
energy_map=name [required]
Bioenergy map in MWh/m3
dhp=name [required]
Name of vector district heating points
Name for output CO2 emissions map
Name for output avoided CO2 emissions map
Name for output net CO2 emissions map
dtm=name
Name of Digital terrain model map
soilp2_map=name
Soil production map
tree_diam=name
Average tree diameter map
tree_vol=name
Average tree volume map
main_roads=name
Vector map of main roads
slp_min_cc=float
Percent slope lower limit with Cable Crane
Default: 30.
slp_max_cc=float
Percent slope higher limit with Cable Crane
Default: 100.
dist_max_cc=float
Maximum distance with Cable Crane
Default: 800.
slp_max_fw=float
Percent slope higher limit with Forwarder
Default: 30.
dist_max_fw=float
Maximum distance with Forwarder
Default: 600.
slp_max_cop=float
Percent slope higher limit with other techniques for Coppices
Default: 30.
dist_max_cop=float
Maximum distance with other techniques for Coppices
Default: 600.
Table of contents
DESCRIPTION
Compute the CO2 emissions of using biomass forestry residuals for energy production.
NOTES
EXAMPLE
REFERENCE
SEE ALSO
r.green, r.green.biomassfor
AUTHORS
Francesco Geri, Pietro Zambelli, Sandro Sacchelli, Marco Ciolli
SOURCE CODE
Available at: r.green.biomassfor.co2 source code (history)
Latest change: Wednesday Mar 11 08:17:30 2026 in commit: 2a14bbb9928039c7c7d0ac539d42b08ff72c88f7
Main index | Raster index | Topics index | Keywords index | Graphical index | Full index
© 2003-2026 GRASS Development Team, GRASS 8.5.1dev Reference Manual
