GRASS logo
NAME
r.green.biomassfor.legal - Estimates potential bioenergy depending on forest increment, forest management and forest treatment
KEYWORDS
raster, biomass
SYNOPSIS
r.green.biomassfor.legal --help
r.green.biomassfor.legal forest=name boundaries=name [energy_tops_hf=float] [forest_column_yield=string] [forest_column_yield_surface=string] [forest_column_management=string] [forest_column_treatment=string] [output_basename=name] [energy_cormometric_vol_hf=float] [energy_tops_cop=float] [--overwrite] [--help] [--verbose] [--quiet] [--ui]
Flags:
--overwrite
--help
Print usage summary
--verbose
Verbose module output
--quiet
Quiet module output
--ui
Force launching GUI dialog
Parameters:
forest=name [required]
Name of vector parcel map
boundaries=name [required]
Name of vector boundaries map (boolean map)
Energy for tops and branches in high forest in MWh/m3
Default: 0.49
Vector field of yield
Default: yield
Vector field of stand surface (ha)
Default: yield_surface
Vector field of forest management (1: high forest, 2:coppice)
Default: management
Vector field of forest treatment (1: final felling, 2:thinning)
Default: treatment
Basename for potential bioenergy (HF,CC and total)
Default: biomassfor
Energy for the whole tree in high forest (tops, branches and stem) in MWh/m3
Default: 1.97
Energy for tops and branches for Coppices in MWh/m3
Default: 0.55
Table of contents
DESCRIPTION
Compute the legal biomass forestry residual potential, based on the annual/periodic forest yield.
NOTES
This module permits to evalute the maximum bio-energy from forest residual available in a particular area, on the base of the prescribed yield. The mandatory data input are a vector file with fields with values of yield, management, treatment, and forest surface. The yield value is expressed in cubic meters, the forest surface in hectares, the management is an integer value that can be 1 for high forest and 2 for coppice, the treatment is an integer field that can be 1 for final felling and 2 for thinning. The energy section contains the calorific parameters that permits to convert the biomass in energy. The output maps are expressed in Mwh.
EXAMPLE
This example shows a typical input vector file with a table composed by fields of increment, forest surface, management and treatment. This example is based on data of Maè Valley, one of the test area of the R.green project
input
yieldsurfacemanagementtreatment
35.8780011
16.4870012
24.8230021
r.green.biomassfor.legal --overwrite forest=forest@biomasfor boundaries=Boundary@biomasfor forest_column_yield=yield forest_column_yield_surface=surface forest_column_management=management forest_column_treatment=treatment energy_tops_hs=0.49 energy_cormometric_vol_hf=1.97 energy_tops_cops=0.55 output_basename=mae
output
The output map is a standardize energy map with the pixel value equal to the corresponding bioenergy stimated.
REFERENCE
Sacchelli, S., Zambelli, P., Zatelli, P., Ciolli, M., 2013. Biomasfor - an open-source holistic model for the assessment of sustainable forest bioenergy. iFor. Biogeosci. For. 6, 285-293
SEE ALSO
r.green.biomassfor.theoretical, r.green.biomassfor.technical
AUTHORS
Francesco Geri, Pietro Zambelli, Sandro Sacchelli, Marco Ciolli
SOURCE CODE
Available at: r.green.biomassfor.legal source code (history)
Latest change: Friday Feb 21 10:10:05 2025 in commit: 7d78fe34868674c3b6050ba1924e1c5675d155c9
Main index | Raster index | Topics index | Keywords index | Graphical index | Full index
© 2003-2025 GRASS Development Team, GRASS GIS 8.4.3dev Reference Manual
