NAME
r.green.hydro.recommended - Calculate hydropower energy potential with user's recommendations
KEYWORDS
raster
SYNOPSIS
r.green.hydro.recommended --help
r.green.hydro.recommended [-dc] elevation=name river=name efficiency=double len_plant=double len_min=double distance=double [p_min=double] [n=float] discharge_current=name [mfd=name] [discharge_natural=name] [percentage=double] [area=name] [buff=double] [points_view=name] [visibility_resolution=float] [n_points=integer] output_plant=name [output_vis=name] [--overwrite] [--help] [--verbose] [--quiet] [--ui]
Flags:
- -d
- Debug with intermediate maps
- -c
- Clean vector lines
- --overwrite
- Allow output files to overwrite existing files
- --help
- Print usage summary
- --verbose
- Verbose module output
- --quiet
- Quiet module output
- --ui
- Force launching GUI dialog
Parameters:
- elevation=name [required]
- Name of input elevation raster map
- river=name [required]
- Name of vector map with interesting segments of rivers
- Vector map with the segments of the river that will be analysed
- efficiency=double [required]
- Efficiency [0-1]
- Options: 0-1
- Default: 1
- len_plant=double [required]
- Maximum plant length [m]
- Default: 100
- len_min=double [required]
- Minimum plant length [m]
- Default: 10
- distance=double [required]
- Minimum distance among plants [m]
- Default: 0.5
- p_min=double
- Minimum mean power [kW]
- Default: 10.0
- n=float
- Number of operative hours per year [hours/year]
- Default: 3392
- discharge_current=name [required]
- Current discharge [m3/s]
- Name of input raster map
- mfd=name
- Minimum Flow Discharge (MFD) [m3/s]
- discharge_natural=name
- Natural discharge [m3/s]
- percentage=double
- MFD as percentage of natural discharge [%]
- Options: 0-100
- area=name
- Areas to exclude
- Vector map with the areas that must be excluded (e.g. Parks)
- buff=double
- Buffer for areas to exclude [m]
- Default: 0
- points_view=name
- Vector points of viewing position to exclude
- Vector with the points that are used to compute the visibility
- visibility_resolution=float
- Resolution of the visibility map computation
- n_points=integer
- Number of points for the visibility
- output_plant=name [required]
- Name of output vector with potential segments
- output_vis=name
- Name of output vector with viewed areas
r.green.hydro.recommended detects the position of the potential hydropower plants including legal or ecological constraints and the user's recommendations that can limit the technical potential to a more sustainable one.
Deciding the range of plant length, the distance between plants, the legal discharge we can exploit and the areas we want to exclude from the calculation (ex. protected areas and the ones according to user's recommendations), the module returns two different vector files with recommended available river segments, optimal position of the plants with their powers and their intakes and restitutions.
The difference between this module and r.green.hydro.optimal is that here we can consider a legal discharge and add areas which will be deleted from the considered streams map used to compute the potential plants.
raster map, to calculate the gross head
vector on which the potential plants will be computed
efficiency of the plant
maximum length of the plant
minimum plant length
minimum distance among the plants
name of the output vector with the potential segments
current discharge; raster for each point of these rivers or raster map with the legal discharge
[required (only if discharge_current=currentdischarge)]
- mfd=name
minimum amount of water to remain in the river to preserve the ecosystem
In this case, the discharge considered in the calculation will be the current discharge minus the MFD read in your input raster map.
The module r.green.hydro.discharge can compute the raster map of the MFD according to the legislation of some regions.
or
discharge of the river without considering the structures exploiting the water
- percentage=double
percentage used to calculate the MFD as an amount of the natural discharge
- area=name [optional]
areas to exclude from the planning of hydropower stations; only the rivers outside these excluded areas will be considered to compute the potential plants
- buff=double [optional]
buffer around the excluded areas
- points_view=name [optional]
input vector map with points of interest
- visibility_resolution=float [optional]
vision from the points of interest
An area corresponding to the fields of vision from the points of interest is computed, the latter correspond to visibility zones.
You can choose to exclude these areas or the areas where several visibility zones are superimposed.
- n_points=integer [optional]
number of points for the visibility corresponding to the number of visibility zones which are superimposed
For example, if this number is 3, the areas where two or less visibility zones are superimposed will be excluded.
- output_vis=name [optional]
name of the output vector with the viewed areas
- p_min=double [optional]
minimum mean power of the plant
The power (kW) is defined as:
P=η * ρ * g * Q * Δh
where η is the efficiency of the plant
ρ the density of water (1000 kg/m3)
g the gravity term (9,81 m/s2)
Q the discharge of the river (m3/s)
Δh the gross head of the considered segment (m)
The module maximizes the power over a given range by a brute-force search in order to examine all possible arrangements of Q and Δh. Thus, the potential segments can be shorter than the maximum plant length chosen because it depends on the maximization of the product Q * Δh. For each potential segment, the potential power is given in kW in attribute.
EXAMPLE 1
This example is based on the case-study of the Gesso and Vermenagna valleys located in the Piedmont Region, in South-West Italy, close to the Italian and French border.
In the map below you can see the file availablestreams of the considered streams. The river segments already exploited by an existing plant do not appear in the file.
This example is based on the case-study of Gesso and Vermenagna valleys in the Natural Park of the Maritime Alps, Piedmont, Italy.
input vector map availablestreams
First of all reset the region settings with g.region making them match the map elevation.
To create the map of this example, you can type in the following code in the command console or if you prefer you can only type in the main function names like r.green.hydro.recommended, d.vect or v.buffer in the console and specify the other parameters of the code like elevation or efficiency by using the graphical user interface.
r.green.hydro.recommended \
elevation=elevation \
river=availablestreams \
efficiency=0.9 \
len_plant=200 \
len_min=10 \
distance=100 \
output_plant=output_plant \
discharge_current=currentdischarge \
mfd=mvf \
area=nationalparks \
buff=100 \
p_min=20
d.vect map=output_plant color=blue
v.buffer input=nationalparks output=buff_park distance=100
d.vect map=buff_park7 color=0:128:0 fill_color=144:238:144 width=1
As you can see in the output map below, this code calculates the energy potential for a range of plant length from 10 to 200 m and a distance between the plants of 100 m. The areas with the national park and a buffer of 100 m around it are excluded. The discharge considered here is the current discharge of rivers reduced by 30% of the Minimum Flow Discharge.
output vector map: superimposition of the potential segments vector file (potentialplants, in blue) and the excluded national park (in green) and the buffer (in dark green)
EXAMPLE 2
The second example is based on the case-study of Mis valley in Belluno province, Veneto, Italy.
Here is the vector file availablestreams of the considered streams. The river segments already exploited by an existing plant do not appear in the file.
In superimposition, there are the vector map (in grey) of the national park we want to exclude and the points of interest (in green) used to create the visibility zones. These points were placed according to experts' recommendations during a focus group made in Veneto region.
input vector map availablestreams with the national park and points of interest
Points of interest are placed in the park so two different cases are presented here:
1) The national park and a buffer of 200 m around it are excluded
2) The visibility zones from points of interest is excluded
1) In the first case, the code used is:
discharge_natural=naturaldischarge \
percentage=25.00 \
efficiency=0.8 \
len_plant=400 \
len_min=10 \
distance=150 \
buff=200 \
output_plant=potentialplants
d.vect map=potentialplants color=blue
v.buffer input=nationalparks output=buff_park distance=200
d.vect map=buff_park color=255:179:179 fill_color=255:179:179 width=1
This command calculates the energy potential for a range of plant length from 10 to 400 m and a distance between plants of 150 m. The areas with the national park and a buffer of 200 m around it are excluded. The discharge considered here is the current discharge of rivers subtracted by 25% of the natural discharge (the latter corresponds to the MFD).
output vector map: superimposition of the potential segments vector file (potentialplants, in blue), the excluded national park (in grey) and the buffer (in light red)
2) In the second case, the code used is:
mfd=mfd \
efficiency=0.8 \
len_plant=400 \
len_min=10 \
distance=150 \
points_view=pointsinterest \
n_points=1 \
output_plant=potentialplants \
output_vis=vis
d.vect map= potentialpoints color=red
d.vect map= potentialplants color=blue
d.vect map= pointsinterest color=green
d.vect map= vis color=144:224:144 fill_color=144:224:144 width=1
This command calculates the energy potential for a plant length range from 10 to 400 m and a distance between plants of 150 m. The visibility zones from each point of interest are excluded. The discharge considered here is the current discharge of rivers subtracted by the MFD. The MFD was calculated previously and computed in a raster map.
output vector map: superimposition of the potential segments vector file (potentialplants, in blue), the points of interest (in green) and the visibility zones (in light green)
r.green.hydro.delplants
r.green.hydro.theoretical
r.green.hydro.structure
r.green.hydro.technical
r.green.hydro.financial
Giulia Garegnani (Eurac Research, Bolzano, Italy), Manual written by Julie Gros.
SOURCE CODE
Available at:
r.green.hydro.recommended source code
(history)
Latest change: Monday Jan 30 19:52:26 2023 in commit: cac8d9d848299297977d1315b7e90cc3f7698730
Main index |
Raster index |
Topics index |
Keywords index |
Graphical index |
Full index
© 2003-2024
GRASS Development Team,
GRASS GIS 8.3.3dev Reference Manual
