NAME
r.out.maxent_swd - Exports map data as input to MaxEnt in SWD format
KEYWORDS
raster,
export,
maxent,
ecology,
niche
SYNOPSIS
r.out.maxent_swd
r.out.maxent_swd --help
r.out.maxent_swd [-z] [alias_input=name] [env_maps=name[,name,...]] [alias_names=string] [bgr_output=name] [alias_output=name] [bgr_mask=name] [species_masks=name[,name,...]] [species_output=name] [species_names=string] [null_value=integer] [--overwrite] [--help] [--verbose] [--quiet] [--ui]
Flags:
- -z
- Zoom computational region to species data (may speed up processing)
- --overwrite
- Allow output files to overwrite existing files
- --help
- Print usage summary
- --verbose
- Verbose module output
- --quiet
- Quiet module output
- --ui
- Force launching GUI dialog
Parameters:
- alias_input=name
- File containg map and alias name(s) for environmental parameter(s)
- env_maps=name[,name,...]
- Environmental parameter map(s)
- alias_names=string
- Alias names for environmental parameter map(s)
- bgr_output=name
- Output SWD file for the environmental data of the background landscape
- alias_output=name
- CSV-like output file with alias names in first column and map names in second column, separated by comma
- bgr_mask=name
- Map to be used as mask for the background landscape
- species_masks=name[,name,...]
- Raster map(s) of specie occurence
- species_output=name
- Output SWD file for the specie(s) related environmental data
- species_names=string
- Alias-name(s) for species to be used in MaxEnt SWD file instead of map names, separated by comma (default: map names).
- null_value=integer
- Integer representing NO DATA cell value (default: -9999)
- Default: -9999
The script is intended to produce a set of SWD files as input to MaxEnt >= 3.3.3e
using
r.stats.
The SWD file format is a simple CSV-like file file format as described in Elith et al. 2011.
Generally it looks like:
specie_name,X,Y,parameter_1,parameter_2,...
your_specie,1.1,1.1,2,4.7,...
The first column always contains the name of the species, followed by
two columns for the X- and Y-coordinates. Then each column
represents one environmental parameter. In contrast to
r.stats
only integer values are accepted to represent NO DATA.
A background SWD file is always produced while species output can be omitted.
Multiple species can be processed, but each has to be in an
individual raster map. Map names of the maps containing the environmental
parameters can be replaced by short names, which should be used
in MaxEnt >= 3.3.3.e.
Results from MaxEnt can either be imported using
r.in.xyz or
calculated from MaxEnt lambdas file using the
r.maxent.lambdas.
r.stats,
r.what,
r.in.xyz,,
r.maxent.lambdas
- Steven J. Phillips, Miroslav Dudík, Robert E. Schapire. 2020: Maxent software
for modeling species niches and distributions (Version 3.4.1).
Available from url:
https://biodiversityinformatics.amnh.org/open_source/maxent
and https://github.com/mrmaxent/Maxent
- Steven J. Phillips, Miroslav Dudík, Robert E. Schapire. 2004: A maximum entropy
approach to species distribution modeling. In Proceedings of the Twenty-First International
Conference on Machine Learning, pages 655-662, 2004.
- Steven J. Phillips, Robert P. Anderson, Robert E. Schapire. 2006: Maximum entropy
modeling of species geographic distributions. Ecological Modelling, 190:231-259, 2006.
- Jane Elith, Steven J. Phillips, Trevor Hastie, Miroslav Dudík, Yung En Chee,
Colin J. Yates. 2011: A statistical explanation of MaxEnt for ecologists. Diversity and
Distributions, 17:43-57, 2011.
Stefan Blumentrath, Norwegian Institute for Nature Research (NINA),
https://www.nina.no
SOURCE CODE
Available at:
r.out.maxent_swd source code
(history)
Latest change: Wednesday Mar 11 08:17:30 2026 in commit: 2a14bbb9928039c7c7d0ac539d42b08ff72c88f7
Main index |
Raster index |
Topics index |
Keywords index |
Graphical index |
Full index
© 2003-2026
GRASS Development Team,
GRASS 8.5.1dev Reference Manual
