GRASS logomenu
NAME
r.wateroutlet.lessmem - Creates watershed basins from a drainage direction map.
KEYWORDS
raster, hydrology, watershed
SYNOPSIS
r.wateroutlet.lessmem --help
r.wateroutlet.lessmem input=name output=name coordinates=east,north [--overwrite] [--help] [--verbose] [--quiet] [--ui]
Flags:
--overwrite
--help
Print usage summary
--verbose
Verbose module output
--quiet
Quiet module output
--ui
Force launching GUI dialog
Parameters:
input=name [required]
Name of input drainage direction map
output=name [required]
Name for output watershed basin map
coordinates=east,north [required]
Coordinates of outlet point
Table of contents
DESCRIPTION
r.wateroutlet.lessmem is a modified version of r.water.outlet and requires about one third of memory compared to the original module. Input drainage direction information is stored as 4-bit segments in the buffer and output basin result is stored as 1-bit data. Because of heavy bitwise operations, there may be some performance penalty depending on the size of the input map. Other than memory management, this module uses the same interface and algorithm in r.water.outlet, so please refer to r.water.outlet for more details.
SEE ALSO
r.water.outlet
AUTHOR
Huidae Cho
based on r.water.outlet
SOURCE CODE
Available at: r.wateroutlet.lessmem source code (history)
Latest change: Thursday Feb 20 13:02:26 2025 in commit: 53de8196a10ba5a8a9121898ce87861d227137e3
Main index | Raster index | Topics index | Keywords index | Graphical index | Full index
© 2003-2025 GRASS Development Team, GRASS GIS 8.4.2dev Reference Manual
