GRASS logo
NAME
v.neighborhoodmatrix - Exports the neighborhood matrix of polygons in a vector map
KEYWORDS
vector, neighborhood matrix
SYNOPSIS
v.neighborhoodmatrix --help
v.neighborhoodmatrix [-b] input=name [player=integer] [idcolumn=name] [output=name] [separator=character] [--overwrite] [--help] [--verbose] [--quiet] [--ui]
Flags:
-b
create bidirectional matrix (same neighborhood relation repeated twice)
--overwrite
--help
Print usage summary
--verbose
Verbose module output
--quiet
Quiet module output
--ui
Force launching GUI dialog
Parameters:
input=name [required]
Name of input vector map
Or data source for direct OGR access
player=integer
Layer in map where polygons are to be found
Default: 1
idcolumn=name
Name of column containing polygon ids
output=name
Name for output file (if omitted or "-" output to stdout)
separator=character
Field separator
Special characters: pipe, comma, space, tab, newline
Default: pipe
Table of contents
DESCRIPTION
v.neighborhoodmatrix identifies all adjacency relations between polygons in a vector map and exports these as a 2xn matrix where n is the number of neighborhood relations with each relation only listed in one direction (i.e. if a is neighbor of b, the list will contain a,b, but not b,a) unless the b flag is specified. By default, neighbors are identified by the category numbers. Using the idcolumn parameter the user can define a column to use as identifier of the polygons. If a path to an output file is specified, the matrix will be written to that file, otherwise it will be sent to standard output.
NOTES
Currently the module assumes that the layer above the layer containing the polygons is empty and available for adding categories to boundaries. The module uses v.to.db to determine neighborhood relations.
EXAMPLE
Send the neighborhood matrix of the census tracts of the North Carolina dataset to standard output identifying each tract by its category value:
v.neighborhoodmatrix in=census_wake2000
Idem, but identifying each tract by its STFID code and sending the output to a file:
v.neighborhoodmatrix in=census_wake2000 idcolumn=STFID output=census_neighbors.csv
SEE ALSO
v.to.db
AUTHOR
Moritz Lennert
SOURCE CODE
Available at: v.neighborhoodmatrix source code (history)
Latest change: Thursday Feb 20 13:02:26 2025 in commit: 53de8196a10ba5a8a9121898ce87861d227137e3
Main index | Vector index | Topics index | Keywords index | Graphical index | Full index
© 2003-2025 GRASS Development Team, GRASS GIS 8.4.2dev Reference Manual
