Note: This document is for an older version of GRASS GIS that will be discontinued soon. You should upgrade, and read the current manual page.
r.basins.fill | Generates watershed subbasins raster map. |
r.carve | Generates stream channels. |
r.drain | Traces a flow through an elevation model or cost surface on a raster map. |
r.fill.dir | Filters and generates a depressionless elevation map and a flow direction map from a given elevation raster map. |
r.flow | Constructs flowlines. |
r.lake | Fills lake at given point to given level. |
r.path | Traces paths from starting points following input directions. |
r.sim.sediment | Sediment transport and erosion/deposition simulation using path sampling method (SIMWE). |
r.sim.water | Overland flow hydrologic simulation using path sampling method (SIMWE). |
r.solute.transport | Numerical calculation program for transient, confined and unconfined solute transport in two dimensions |
r.stream.extract | Performs stream network extraction. |
r.terraflow | Performs flow computation for massive grids. |
r.topidx | Creates a topographic index (wetness index) raster map from an elevation raster map. |
r.topmodel | Simulates TOPMODEL which is a physically based hydrologic model. |
r.uslek | Computes USLE Soil Erodibility Factor (K). |
r.usler | Computes USLE R factor, Rainfall erosivity index. |
r.water.outlet | Creates watershed basins from a drainage direction map. |
r.watershed | Calculates hydrological parameters and RUSLE factors. |
r3.flow | Computes 3D flow lines and 3D flow accumulation. |
See also the corresponding keyword hydrology for additional references.
Main index | Topics index | Keywords index | Graphical index | Full index
© 2003-2023 GRASS Development Team, GRASS GIS 7.8.9dev Reference Manual
