Image processing
From GRASS-Wiki
(Redirected from Remote Sensing)
Jump to: navigation, search
Contents
Introduction
Satellite imagery and orthophotos (aerial photographs) are handled in GRASS as raster maps and specialized tasks are performed using the imagery (i.*) modules. All general operations are handled by the raster modules.
  • Data import is generally handled by the r.in.gdal module
Screenshots
Importing
Satellite Data
Ocean Color
Sea Surface Temperature (SST)
High resolution data
Orthophotos
Preprocessing
See also NASA LaRC Satellite Overpass Predictor
Geometric preprocessing/Georectification
  • Georectification tool is available from the File menu in the GUI.
  • i.points, i.vpoints (scanned maps, satellite images)
  • i.ortho.photo (aerial images)
A multi-band image may be grouped and georectified with a single set of ground control points (i.group, i.target, i.rectify).
See also the Georeferencing wiki page
Radiometric preprocessing
Correction for atmospheric effects
Correction for topographic/terrain effects
In rugged terrain, such correction might be useful to minimize negative effects.
  • simple "cosine correction" using r.sunmask, r.mapcalc (tends to overshoot when slopes are high)
  • In i.topo.corr (from GRASS AddOns) the following correction methods are implemented: cosine, minnaert, percent, c-factor.
Cloud removal
Image classification
See the dedicated Image classification page.
Filtering
Fourier Transform
Canonical Component Analysis
Principal Component Analysis
Texture
A series of commonly used texture measures (derived from the Grey Level Co-occurrence Matrix, GLCM), also called Haralick's texture features are available:
  • r.texture: In case of panchromatic maps or limited amount of channels, it is often recommended to generate synthetic channels through texture analysis
See here and here for the formulas to calculate texture.
Time series analysis
Enhancements
Radiometric Enhancements
Geometric Enhancements - Image Fusion - Pansharpening
  • i.rgb.his and i.his.rgb: can be used for image fusion
  • i.fusion.brovey: image fusion of pan-chromatic and color channels
  • r.seg which performs image segmentation and discontinuity detection (based on the Mumford-Shah variational model). The module generates a piece-wise smooth approximation of the input raster map and a raster map of the discontinuities of the output approximation. The discontinuities of the output approximation are preserved from being smoothed.
Optimal channel selection for color composites
Stereo anaglyphs
Ideas collection for improving GRASS' Image processing capabilities
Below modules need some tuning before being added to GRASS 6. Volunteers welcome.
Spectral unmixing ideas
Spectral angle mapping ideas
Geocoding ideas
Image matching ideas
  • i.points.auto: automated search of GCPs based on FFT correlation (as improved i.points)
Reference: M. Neteler, D. Grasso, I. Michelazzi, L. Miori, S. Merler, and C. Furlanello, 2005: An integrated toolbox for image registration, fusion and classification. International Journal of Geoinformatics, 1(1), pp. 51-61 PDF
Image classification ideas
Stereo ideas
This is stand-alone stereo modeling software (DEM extraction etc). Waits for integration into GRASS.
Lidar LAS format
LAS Tools by M. Isenburg, Howard Butler et al.: http://www.liblas.org
   las2txt | r.in.xyz in=- fs=" "
Update: r.in.lidar and v.in.lidar implemented by Markus Metz (GRASS 7)
(see LIDAR)
Improving the existing code
It might be sensible to merge the various image libraries:
  • GRASS 6 standard libs:
    • lib/imagery/: standard lib, in use (i.* except for i.points3, i.rectify3, see below)
    • imagery/i.ortho.photo/libes/: standard lib, in use (i.ortho.photo, photo.*)
  • GRASS 5 (! only) image3 lib:
    • libes/image3/: never finished improvement which integrated the standard lib and the ortho lib. Seems to provide also ortho rectification for satellite data (i.points3, i.rectify3)
  • GRASS 5/6 image proc commands:
    • merge of i.points, i.vpoints, i.points3 (see above)
    • merge of i.rectify and i.rectify3 (see above)
    • addition of new resampling algorithms such as bilinear, cubic convolution (take from r.proj or r.resamp.aggreg) (done 10/2010)
    • add other warping methods (maybe lanczos or thin splines from GDAL?): Addons#i.warp
    • implement/finish linewise ortho-rectification of satellite data
Bibliography
Personal tools
Namespaces
Variants
Actions
Navigation
Toolbox
