NAME
i.sentinel.parallel.download - Downloads Sentinel-2 images in parallel using i.sentinel.download.
KEYWORDS
imagery,
satellite,
Sentinel,
download,
parallel
SYNOPSIS
i.sentinel.parallel.download --help
i.sentinel.parallel.download [-sfe] [settings=name] [scene_name=string[,string,...]] [output=name] [clouds=integer] [producttype=string] [start=string] [end=string] [nprocs=integer] [datasource=string] [limit=integer] [--help] [--verbose] [--quiet] [--ui]
Flags:
- -s
- Use scenename/s instead of start/end/producttype to download specific S2 data (specify in the scene_name field)
- -f
- Download each Sentinel-2 datasat into an individual folder within the output folder
- -e
- Use ESA-style scenename/s to download from USGS
- --help
- Print usage summary
- --verbose
- Verbose module output
- --quiet
- Quiet module output
- --ui
- Force launching GUI dialog
Parameters:
- settings=name
- Full path to settings file (user, password)
- Name of input file
- scene_name=string[,string,...]
- Names of the scenes to be downloaded
- output=name
- Name for output directory where to store downloaded Sentinel data
- clouds=integer
- Maximum cloud cover percentage for Sentinel scene
- Default: 20
- producttype=string
- Sentinel product type to filter
- Options: SLC, GRD, OCN, S2MSI1C, S2MSI2A, S2MSI2Ap
- Default: S2MSI2A
- start=string
- Start date ('YYYY-MM-DD')
- end=string
- End date ('YYYY-MM-DD')
- nprocs=integer
- Number of parallel processes
- Number of used CPUs
- Default: 1
- datasource=string
- Default is ESA Copernicus Open Access Hub (ESA_COAH), but Sentinel-2 L1C data can also be acquired from USGS Earth Explorer (USGS_EE) or Google Cloud Storage (GCS)
- Data-Hub to download scenes from
- Options: ESA_COAH, USGS_EE, GCS
- Default: ESA_COAH
- limit=integer
- Maximum number of scenes to filter/download
i.sentinel.parallel.download downloads Sentinel-2 data defined
by scene names in parallel using
If no scene names are specified
downloads data for the computational region set in the mapset; i.e, only
products which footprint intersects the current computation region extent
(area of interest, AOI) are selected.
i.sentinel module set,
i.sentinel.download
Guido Riembauer,
mundialis
SOURCE CODE
Available at:
i.sentinel.parallel.download source code
(history)
Accessed: Monday May 04 06:29:18 2026
Main index |
Imagery index |
Topics index |
Keywords index |
Graphical index |
Full index
© 2003-2025
GRASS Development Team,
GRASS GIS 8.4.3dev Reference Manual
