GRASS logo
NAME
r.green.gshp.technical - Calculate the Ground Source Heat Pump technical potential using the ASHRAE method.
KEYWORDS
raster, geothermal, renewable energy
SYNOPSIS
r.green.gshp.technical --help
r.green.gshp.technical [-d] ground_conductivity=name [ground_diffusivity_rast=name] [ground_diffusivity_value=double] [ground_temp_rast=name] [ground_temp_value=double] [g_loads_6h_rast=name] [g_loads_6h_value=double] [g_loads_1m_rast=name] [g_loads_1m_value=double] [g_loads_1y_rast=name] [g_loads_1y_value=double] [fluid_capacity=double] [fluid_massflow=double] [fluid_inlettemp=double] [bh_radius=double] [bh_convection=double] [bh_resistence=double] [pipe_inner_radius=double] [pipe_outer_radius=double] [pipe_distance=double] [k_pipe=double] [k_grout=double] [field_distance=double] [field_number=integer] [field_ratio=double] [bhe_length=name] [bhe_field_length=name] [--overwrite] [--help] [--verbose] [--quiet] [--ui]
Flags:
-d
Debug with intermediate maps
--overwrite
--help
Print usage summary
--verbose
Verbose module output
--quiet
Quiet module output
--ui
Force launching GUI dialog
Parameters:
ground_conductivity=name [required]
Raster with depth-averaged ground thermal conductivity lambda [W m-1 K-1]
Raster with depth-averaged ground diffusivity [m2 day-1]
Value with depth-averaged ground diffusivity [m2 day-1]
Default: 0.086
Raster with the initial ground temperature T0 [degrees C]
Value with the initial ground temperature T0 [degrees C]
Default: 10.
Peak of the maximum 6 hourly ground loads [W]
Default: 60.
Month with the maximum ground loads [W]
Default: 15.
Yearly average ground loads [W]
Default: 5.
Fluid capacity Cp [J kg-1 K-1]
Default: 4200.
Fluid massflow [kg s-1 kW-1]
Default: 0.050
Inlet temperature [degrees C]
Default: 2.
bh_radius=double
Borehole radius [m]
Default: 0.06
Internal convection coefficient [W m-2 K-1]
Default: 1.52
Borehole thermal resistance [m K W-1]
Default: nan
Borehole pipe inner radius [m]
Default: 0.01365
Borehole pipe outer radius [m]
Default: 0.0167
Center-to-center distance between pipes [m]
Default: 0.0511
k_pipe=double
Pipe thermal conductivity [W m-1 K-1]
Default: 0.42
k_grout=double
Grout thermal conductivity [W m-1 K-1]
Default: 1.52
Distance between boreholes heat exchanger
Default: 6.1
Number of borehole heat exchanger
Default: 2
field_ratio=double
Borefield aspect ratio
Default: 1.2
bhe_length=name
Name of output raster map with the geothermal length of the BHE [m]
Name of output raster map with the geothermal length of the BHE field [m]
Table of contents
DESCRIPTION
r.green.gshp.technical calculates the lenght of the borehole for Groud Source Heat Pump plants.
NOTES
The required inputs are the ground source conductivity and the ground loads.
EXAMPLES
python r.green.gshp.technical.py --overwrite ground_conductivity=g_conductivity ground_diffusivity_rast=g_diffusivity ground_temp_rast=g_temperature g_loads_6h_rast=g_loads_6h g_loads_1m_rast=g_loads_1m g_loads_1y_rast=g_loads_1y fluid_capacity=4000. fluid_massflow=0.074 fluid_inlettemp=4.44 bh_radius=0.054 pipe_inner_radius=0.01365 pipe_outer_radius=0.0167 bh_convection=1000. pipe_distance=0.0471 k_pipe=0.45 k_grout=1.73 field_distance=6.1 field_number=120 field_ratio=1.2 bhe_length=len_bhe bhe_field_length=len_bhe_field -d
SEE ALSO
AUTHOR
Pietro Zambelli (Eurac Research, Bolzano, Italy)
SOURCE CODE
Available at: r.green.gshp.technical source code (history)
Latest change: Saturday Oct 18 14:02:41 2025 in commit: 5cb968f55a99751846ac9af8070831e07b9710e5
Main index | Raster index | Topics index | Keywords index | Graphical index | Full index
© 2003-2025 GRASS Development Team, GRASS GIS 8.4.2dev Reference Manual
