GRASS logo
NAME
r.slopeunits.metrics - Create metrics for slope units
KEYWORDS
raster, elevation, slopeunits
SYNOPSIS
r.slopeunits.metrics --help
r.slopeunits.metrics basin=name demmap=name slumapclean=name cleansize=float areamin=float cvmin=float resolution=float [outfile=name] [--overwrite] [--help] [--verbose] [--quiet] [--ui]
Flags:
--overwrite
--help
Print usage summary
--verbose
Verbose module output
--quiet
Quiet module output
--ui
Force launching GUI dialog
Parameters:
basin=name [required]
Name of input vector map
Input basin
demmap=name [required]
Input digital elevation model
slumapclean=name [required]
Output Slope Units layer, cleaned (the main output)
cleansize=float [required]
Slope Units size to be removed
Default: 25000
areamin=float [required]
Minimum area (m^2) below which the slope unit is not further segmented
cvmin=float [required]
Minimum value of the circular variance (0.0-1.0) below which the slope unit is not further segmented
resolution=float [required]
Resolution
outfile=name
Output file with metrics
Table of contents
DESCRIPTION
r.slopeunits.metrics creates metrics for slope units. Returns output "areamin, cvmin, v_fin and i_fin" to stdout, optionally writes to a file.
EXAMPLE
r.slopeunits.metrics \
    basin=basin_chk \
    demmap=dem_italia_isolegrandi@su_test \
    slumapclean=su_tmp_cl \
    cleansize=25000 \
    areamin=50000.0 \
    cvmin=0.05 \
    resolution=625 \
    outfile=objf_1.dat
REFERENCES
SEE ALSO
r.slopeunits.create, r.slopeunits.clean, r.slopeunits.optimize
AUTHORS
Main authors: Ivan Marchesini, Massimiliano Alvioli, CNR-IRPI
Carmen Tawalika (translation to python), mundialis
SOURCE CODE
Available at: r.slopeunits.metrics source code (history)
Accessed: Saturday Apr 11 06:36:34 2026
Main index | Raster index | Topics index | Keywords index | Graphical index | Full index
© 2003-2025 GRASS Development Team, GRASS GIS 8.4.3dev Reference Manual
