NAME
r.slopeunits.optimize - Optimize inputs for slope units
KEYWORDS
raster,
elevation,
slopeunits
SYNOPSIS
r.slopeunits.optimize --help
r.slopeunits.optimize [-s] demmap=name [plainsmap=name] basin=name slumap=name [slumapclean=name] thresh=float rf=integer maxiteration=integer cleansize=float cvmin=min,max areamin=min,max epsilonx=float epsilony=float outdir=name [convergence=integer] [--overwrite] [--help] [--verbose] [--quiet] [--ui]
Flags:
- -s
- SFD (D8) flow in r.watershed (default is MFD)
- SFD: single flow direction, MFD: multiple flow direction
- --overwrite
- Allow output files to overwrite existing files
- --help
- Print usage summary
- --verbose
- Verbose module output
- --quiet
- Quiet module output
- --ui
- Force launching GUI dialog
Parameters:
- demmap=name [required]
- Input digital elevation model
- plainsmap=name
- Input raster map of alluvial plains
- basin=name [required]
- Name of input vector map
- Input basin passed to r.slopeunits.metrics
- slumap=name [required]
- Slope Units layer (the main output of r.slopeunits.create)
- Default: su_tmp
- slumapclean=name
- Slope Units layer, cleaned (the main output of r.slopeunits.clean)
- Default: su_tmp_cl
- thresh=float [required]
- Initial threshold (m^2)
- rf=integer [required]
- Factor used to iterativelly reduce initial threshold
- maxiteration=integer [required]
- maximum number of iteration to do before stopped
- cleansize=float [required]
- Slope Units size to be removed
- Default: 25000
- cvmin=min,max [required]
- Start search with these initial minimum and maximum values of the circular variance (0.0-1.0) below which the slope unit is not further segmented
- Default: 0.05,0.25
- areamin=min,max [required]
- Start search with these initial minimum and maximum values of the area (m^2) below which the slope unit is not further segmented
- Default: 50000.0,200000.0
- epsilonx=float [required]
- Stop loop when difference of cvmin limits is lesser than this value
- Default: 0.01
- epsilony=float [required]
- Stop loop when difference of areamin limits is lesser than this value
- Default: 50000
- outdir=name [required]
- Output directory for intermediate results for all cvmin and areamin values and final results. Default folder "outdir" in current working directory.
- Default: outdir
- convergence=integer
- Convergence factor for MFD in r.watershed (1-10)
- 1 = most diverging flow, 10 = most converging flow. Recommended: 5
- Default: 5
r.slopeunits.optimize determines optimal input values for slope units:
"areamin" - Minimum area (m^2) below which the slope unit is not further segmented
"cvmin" - Minimum value of the circular variance (0.0-1.0) below which the slope unit is not further segmented
It calls
r.slopeunits.create,
r.slopeunits.clean, and
r.slopeunits.metrics iteratively.
Output is a file
opt.txt with optimal values in either specified folder or in folder
output/"
in the current working directory. Also files
calcd.dat and
current.txt are created with
all determined and examined values and the four latest examined values (combination of
areamin
and cvmin minimum and maximum) and center, respectively.
r.slopeunits.optimize \
basin=basin_chk \
demmap=dem_italia_isolegrandi@su_test \
plainsmap=flat \
thresh=250000 \
rf=2 \
maxiteration=50 \
cleansize=25000
- Alvioli, M., Marchesini, I., Reichenbach, P., Rossi, M., Ardizzone, F., Fiorucci, F., and Guzzetti, F. (2016): Automatic delineation of geomorphological slope units with r.slopeunits v1.0 and their optimization for landslide susceptibility modeling, Geosci. Model Dev., 9, 3975-3991. DOI:10.5194/gmd-9-3975-2016
- Alvioli, M., Guzzetti, F., & Marchesini, I. (2020): Parameter-free delineation of slope units and terrain subdivision of Italy. Geomorphology, 358, 107124. DOI:10.1016/j.geomorph.2020.107124
r.slopeunits.clean,
Main authors: Ivan Marchesini, Massimiliano Alvioli, CNR-IRPI
Carmen Tawalika (translation to python, refactoring), mundialis
SOURCE CODE
Available at:
r.slopeunits.optimize source code
(history)
Accessed: Friday Apr 24 06:37:45 2026
Main index |
Raster index |
Topics index |
Keywords index |
Graphical index |
Full index
© 2003-2025
GRASS Development Team,
GRASS GIS 8.4.3dev Reference Manual
