NAME
d.polar - Draws polar diagram of angle map such as aspect or flow directions
KEYWORDS
display,
diagram
SYNOPSIS
d.polar
d.polar --help
d.polar [-x] map=name [undef=float] [output=name] [--overwrite] [--help] [--verbose] [--quiet] [--ui]
Flags:
- -x
- Plot using Xgraph
- --overwrite
- Allow output files to overwrite existing files
- --help
- Print usage summary
- --verbose
- Verbose module output
- --quiet
- Quiet module output
- --ui
- Force launching GUI dialog
Parameters:
- map=name [required]
- Name of raster angle map
- undef=float
- Pixel value to be interpreted as undefined (different from NULL)
- output=name
- Name for optional EPS output file
d.polar calculates and displays a polar diagram of an
angle raster map such as aspect, wind direction, or flow.
The input angle map orientation must be counter-clockwise (CCW)
from east, and the angle map units must be degrees. This refers
to the standard orientation of GRASS (e.g., see
r.slope.aspect).
The radius of the outer circle is defined by the total number
of pixels in the map. If the polar diagram does not reach the
outer circle, no data (NULL) pixels were found in the map.
The vector in the diagram indicates a prevailing direction, its length
the strength of such direction. In case all angle vectors are oriented
along the same direction, the length for the vector is maximal (in fact
it is equal to length of the most populated bin of the underlying histogram).
As a side effect, the quality of the angle map can be derived from
the diagram. Strong spikes may indicate an over-representation of
the related angle(s) which happens in particular if integer maps
are used.
If the
output parameter is used, the diagram is generated
as EPS file. If the
-x flag is used
xgraph is launched.
Otherwise
d.polar will use
d.graph to draw the plot
in the current display frame.
If d.polar is used on an aspect map generated by
r.slope.aspect, the undef parameter should be
set to 0 to distinguish NO DATA (NULL) areas from areas where
aspect is undefined (i.e. flat areas).
Polar diagram of aspect map
In this example, the polar diagram of the 'aspect' angle map in the
North Carolina sample dataset is generated:
g.region raster=aspect -p
d.polar aspect
Xgraph must be installed for the
-x flag to function.
d.graph,
d.histogram,
d.rast.arrow,
r.slope.aspect
J. Hofierka, H. Mitasova, and M. Neteler (2009): Terrain parameterization in GRASS.
In T. Hengl and H.I. Reuter, editors, Geomorphometry: concepts, software, applications. Elsevier
DOI)
Markus Neteler, ITC-irst, Italy
Bruno Caprile, ITC-irst, Italy
Hamish Bowman, Otago University, New Zealand
SOURCE CODE
Available at:
d.polar source code
(history)
Latest change: Friday Oct 25 16:16:09 2024 in commit: 4ea983fff87951516b6e4578a0527e3b10f04643
Main index |
Display index |
Topics index |
Keywords index |
Graphical index |
Full index
© 2003-2025
GRASS Development Team,
GRASS GIS 8.4.3dev Reference Manual
