NAME
v.mkgrid - Creates a vector map of a user-defined grid.
KEYWORDS
vector,
geometry,
grid,
point pattern,
hexagon
SYNOPSIS
v.mkgrid
v.mkgrid --help
v.mkgrid [-had] map=name [grid=rows,columns] [position=string] [coordinates=east,north] [box=width,height] [angle=float] [breaks=integer] [type=string] [--overwrite] [--help] [--verbose] [--quiet] [--ui]
Flags:
- -h
- Create hexagons (default: rectangles)
- -a
- Allow asymmetric hexagons
- -d
- EXPERIMENTAL: Add diagonals to rectangular lines
- Applies only to lines for rectangles
- --overwrite
- Allow output files to overwrite existing files
- --help
- Print usage summary
- --verbose
- Verbose module output
- --quiet
- Quiet module output
- --ui
- Force launching GUI dialog
Parameters:
- map=name [required]
- Name for output vector map
- grid=rows,columns
- Number of rows and columns in grid
- position=string
- Where to place the grid
- Options: region, coor
- Default: region
- region: current region
- coor: use 'coor' and 'box' options
- coordinates=east,north
- Lower left easting and northing coordinates of map
- box=width,height
- Width and height of boxes in grid
- angle=float
- Angle of rotation (in degrees counter-clockwise)
- Default: 0
- breaks=integer
- Number of vertex points per grid cell
- Options: 0-60
- Default: 0
- type=string
- Output feature type
- Options: point, line, area
- Default: area
v.mkgrid creates a vector map representation of a regular
coordinate grid. Point, line, and area vector grids can be created.
Grid points created with the
type=point option will be placed at
the
center of each grid cell, like centroids with the default
type=area option.
Grid lines created with the type=line option will be identical to
the edges of each grid cell, like boundaries with the default
type=area option.
The resultant grid can be rotated around the origin (center of the
grid) with the angle option.
Optionally hexagons can be created with the -h flag. Hexagons
are by default symmetric. Asymmetric hexagons can be allowed with the
-a flag.
This module is NOT to be used to generate a vector map of USGS
quadrangles, because USGS quads are not exact rectangles.
To be run in a latitude-longitude project (WGS84)
# set the region:
g.region n=90 s=-90 w=-180 e=180 res=10 -p
projection: 3 (Latitude-Longitude)
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 90N
south: 90S
west: 180W
east: 180E
nsres: 10
ewres: 10
rows: 18
cols: 36
cells: 648
# create 10 degree size grid:
v.mkgrid map=grid_10deg
# create 20 degree size grid:
v.mkgrid map=grid_20deg box=20,20
Creating a 4x3 grid, cells 20km a side, with lower left corner at 2716500,6447000:
v.mkgrid map=coro_grid grid=4,3 position=coor coordinates=2716500,6447000 box=20000,20000
Creating a 10x12 lat/lon grid, cells 2 arc-min a side, with lower left corner
at 167deg 52min east, 47deg 6min south. For use with e.g. QGIS you can then
pull this grid into a project with projected coordinate reference system (CRS)
using
v.proj before
exporting as a vector file with
v.out.ogr (within GRASS GIS you could
just use
d.grid -w from the project with projected CRS for the same effect):
v.mkgrid map=p2min_grid grid=10,12 position=coor coordinates=167:52E,47:06S box=0:02,0:02
North Carolina sample dataset example, creating a 1km spaced point grid
based on the current region extent defined by the "elevation" map:
g.region raster=elevation res=1000 -pa
v.mkgrid type=point map=pointpattern
North Carolina sample dataset example, creating a regular spaced point grid
based on the current region extent defined by the "elevation" map, using
a two-step approach:
# create first set of points, covering extent of "elevation" raster map
v.mkgrid type=point map=pointpattern1
# shift grid by half point distance (map units)
g.region n=n+500 w=w+500 e=e+500 s=s+500 -p
# create second set of points
v.mkgrid type=point map=pointpattern2
# merge into final point pattern
v.patch input=pointpattern1,pointpattern2 output=pointpattern3
Different point patterns for sampling design
North Carolina sample dataset example, creating regular hexagons
based on the current region extent defined by the "elevation" map and
raster resolution for the hexagon size:
g.region raster=elevation res=5000 -pa
v.mkgrid map=hexagons -h
d.grid 5000
Hexagon map
To compute point density in a hexagonal grid for the vector map
points_of_interest in the basic North Carolina sample dataset,
the vector map itself is used to set extent of the computational region.
The resolution is based on the desired size of hexagons.
g.region vector=points_of_interest res=2000 -pa
The hexagonal grid is created as a vector map based on the previously
selected extent and size of the grid.
The following counts the number of points per hexagon using the
v.vect.stats module.
v.vect.stats points=points_of_interest areas=hexagons count_column=count
Users should note that some of the points may be outside the grid
since the hexagons cannot cover all the area around the edges
(the computational region extent needs to be enlarged if all points
should be considered).
The last command sets the vector map color table to
viridis
based on the
count column.
v.colors map=hexagons use=attr column=count color=viridis
Point density in a hexagonal grid
d.grid,
v.in.region,
v.patch,
v.vect.stats
Michael Higgins,
U.S.Army Construction Engineering
Research Laboratory
Update for new vectors Radim Blazek 10/2004
SOURCE CODE
Available at:
v.mkgrid source code
(history)
Latest change: Tuesday Dec 17 20:17:20 2024 in commit: d962e90c026708a4815ea2b9f46c0e84c17de22d
Main index |
Vector index |
Topics index |
Keywords index |
Graphical index |
Full index
© 2003-2025
GRASS Development Team,
GRASS GIS 8.4.2dev Reference Manual
