NAME
i.hyper.explore - Visualize spectra from hyperspectral 3D raster maps.
KEYWORDS
visualization,
hyperspectral,
3D raster
SYNOPSIS
i.hyper.explore
i.hyper.explore --help
i.hyper.explore [-p] map=name[,name,...] [coordinates=east,north[,east,north,...]] [points=name] [output=name] [dpi=integer] [style_scale=float] [--overwrite] [--help] [--verbose] [--quiet] [--ui]
Flags:
- -p
- Print JSON to stdout instead of plotting
- --overwrite
- Allow output files to overwrite existing files
- --help
- Print usage summary
- --verbose
- Verbose module output
- --quiet
- Quiet module output
- --ui
- Force launching GUI dialog
Parameters:
- map=name[,name,...] [required]
- Input 3D raster map(s) with hyperspectral data (comma-separated)
- coordinates=east,north[,east,north,...]
- Comma separated list of coordinates
- points=name
- Name of input vector map
- Point vector map with query locations
- output=name
- Output plot file (.png, .pdf, .svg). If not set, opens an interactive window
- Name for output file
- dpi=integer
- DPI value for output image (used only with output=)
- Default: 300
- style_scale=float
- Scale factor for fonts and line widths when exporting (e.g., 1.8)
- Default: 1.0
i.hyper.explore visualizes spectra extracted from hyperspectral 3D raster maps (raster_3d).
It allows users to interactively inspect spectral signatures at given map coordinates or from point vector maps.
The module supports multiple 3D raster maps simultaneously for comparison (e.g., original data, preprocessed data, or reduced components).
Each queried location is sampled across all spectral bands using r3.what.
The resulting spectral curves are plotted or printed in JSON format (with the -p flag).
If an output file is specified (output=), the figure is exported instead of being shown interactively.
i.hyper.explore automatically reads wavelength metadata, measurement type (e.g., reflectance, radiance), and units from hyper.json produced by i.hyper.import or i.hyper.preproc.
If the map contains principal components or other dimensionally reduced features, the module detects this and adjusts the X-axis to component indices.
- Query spectra from one or more 3D raster maps at arbitrary locations.
- Plot spectral curves for all queried points, automatically handling units and wavelength axes.
- Detects whether the data represent reflectance, radiance, or dimensional components from metadata.
- Export plots to
.png, .pdf, or .svg via output=.
- Optionally output structured JSON data for external analysis with the -p flag.
- Automatically labels plots based on measurement type, units, and number of components.
- Supports coordinate pairs (
coordinates=) and vector point maps (points=).
- Wavelength metadata must be available in
hyper.json.
- The module uses
r3.what to extract band values at each 2D location.
- If the raster represents dimensional components (e.g., PCA, NMF), the plot’s X-axis switches to “Components”.
- The output plot resolution can be set with
dpi=.
- Line width and font size can be scaled with
style_scale= (default: 1.0).
- Line colors correspond to query points; linestyles correspond to input maps.
- Interactive plots support renaming legends and saving figures directly from the viewer.
# Example 1: Compare spectra from EnMAP 3D raster map at two locations
i.hyper.explore map=enmap@PERMANENT \
coordinates=4718536.78125,2587471.78125,4718504.625,2587623.375
Figure: Reflectance spectra plots generated with i.hyper.explore
Data source: Copyright © 2012–2025 EnMAP at Earth Observation Center EOC of DLR.
# Example 2: Explore multiple spectra from Tanager 3D raster map
i.hyper.explore map=tanager@PERMANENT \
coordinates=481043.478,8184411.261,483979.826,8180452.435,472444.174,8181841.957
Figure: Radiance spectra plots generated with i.hyper.explore
Data source: Planet Labs – Open Data, CC-BY-4.0.
Tomaž Žagar and Alen Mangafić, Geodetic Institute of Slovenia
SOURCE CODE
Available at:
i.hyper.explore source code
(history)
Latest change: Wednesday Jun 17 14:05:16 2026 in commit: 2b69c1e5403d2a3377c287af027fcbad020a088c
Main index |
Imagery index |
Topics index |
Keywords index |
Graphical index |
Full index
© 2003-2026
GRASS Development Team,
GRASS 8.5.1dev Reference Manual
