v.transects
Creates transect lines or quadrilateral areas at regular intervals perpendicular to a polyline.
v.transects [-l] input=name output=name transect_spacing=float [dleft=float] [dright=float] [type=string] [metric=string] [transect_perpendicular=string] [--overwrite] [--verbose] [--quiet] [--qq] [--ui]
Example:
sh
v.transects input=name output=name transect_spacing=0.0
grass.script.run_command("v.transects", input, output, transect_spacing, dleft=None, dright=None, type="line", metric="straight", transect_perpendicular="trend", flags=None, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
python
gs.run_command("v.transects", input="name", output="name", transect_spacing=0.0)
grass.tools.Tools.v_transects(input, output, transect_spacing, dleft=None, dright=None, type="line", metric="straight", transect_perpendicular="trend", flags=None, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
python
tools = Tools()
tools.v_transects(input="name", output="name", transect_spacing=0.0)
Parameters
input=name [required]
Name of input vector map
Or data source for direct OGR access
output=name [required]
Name for output vector map
transect_spacing=float [required]
Transect spacing along input polyline
dleft=float
Distance transect extends to the left of input line
Default is the same as the transect spacing
dright=float
Distance transect extends to the right of input line
type=string
Output type
Input feature type
Allowed values: point, line, area
Default: line
metric=string
Determines how transect spacing is measured
Allowed values: straight, along
Default: straight
straight: Straight distance between transect points
along: Distance along the line
Determines which line is the transect perpendicular to
Allowed values: trend, line
Default: trend
trend: Perpendicular to the line connecting transect points
line: Perpendicular to the particular segment of the original line
-l
Use the last point of the line to create transect
--overwrite
--help
Print usage summary
--verbose
Verbose module output
--quiet
Quiet module output
--qq
Very quiet module output
--ui
Force launching GUI dialog
input : str, required
Used as: input, vector, name
output : str, required
Used as: output, vector, name
transect_spacing : float, required
dleft : float, optional
dright : float, optional
type : str, optional
Output type
Input feature type
Default: line
metric : str, optional
Default: straight
transect_perpendicular : str, optional
Default: trend
flags : str, optional
Allowed values: l
l
overwrite : bool, optional
Default: None
verbose : bool, optional
Default: None
quiet : bool, optional
Quiet module output
Default: None
superquiet : bool, optional
Default: None
Output type
Input feature type
Default: line
Default: straight
Default: trend
Allowed values: l
l
Default: None
Default: None
Quiet module output
Default: None
Default: None
Returns:
Raises:
DESCRIPTION
v.transects creates equally spaced geometries along input lines. Depending on the selected metric, the distances are measured either as straight distances between the transects or along the line. Straight distance is better when the lines are complicated (shorelines) and using the distance along line would result in big differences in the transect spacing.
The geometries can be lines or quadrilateral areas. Lines and areas are generated to be perpendicular to either the input line (select line for parameter transect_perpendicular), or to the line connecting the transect points (select trend for parameter transect_perpendicular). The latter option is useful for complicated lines, because it follows the trend of the line.
By default the last point of each line is not used because the last transect distance would be typically different from the previous once. To create a transect from the last point, use flag -l.
The following pictures show the effect of different options on a line
with simple geometry. In the first picture, the circles show points
generated by
v.segment
in 100 m interval along the line. The green lines were generated with
option metric=along, therefore they match with the points. The blue
lines were generated with metric=straight.
In the second picture, green lines use transect_perpendicular=line
while the blue ones use transect_perpendicular=trend.
NOTES
Input vector lines that are shorter than transect_spacing are ignored.
transect_spacing, dleft, and dright are interpreted to be in horizontal map units (e.g., degrees in the LatLong/WGS84 coordinate system).
v.transects may fail for a network of lines in Windows.
EXAMPLES
In these examples, the Nags Head (19MB) mapset is used to generate a shoreline and shore-perpendicular geometries. To use the mapset, unpack it into the nc_spm_08_grass7 (50MB) location.
Example 1) - Generate line transects along shoreline
Generate 20 cross-shore transects along 2008 shoreline (1m contour)
```sh g.region raster=NH_2008_1m r.contour input=NH_2008_1m output=NH_2008_1m level=1 cut=100 v.report map=NH_2008_1m option=length
cat|level|length
1|1|1037.86684790028
1038m / 20transects = 52m per transect (value for transect_spacing)
v.transects input=NH_2008_1m output=NH_2008_transects transect_spacing=52 v.info NH_2008_transects ```
Example 2) - Generate line transects specifying the left and right length
Generate longer, more parallel transects by specifying dleft and dright and smoothing the input line
sh
v.generalize input=NH_2008_1m output=NH_2008_1m_smoothed \
method=sliding_averaging look_ahead=201
v.transects input=NH_2008_1m_smoothed \
output=NH_2008_transects_long_smoothed transect_spacing=52 \
dleft=20 dright=300
Example 3) - Generate area transects along shoreline
sh
v.transects input=NH_2008_1m output=NH_2008_areas \
transect_spacing=52 dleft=20 dright=300 type=area
v.db.addtable NH_2008_areas
v.db.addcolumn map=NH_2008_areas columns='demStats DOUBLE PRECISION'
v.rast.stats vector=NH_2008_areas raster=NH_2008_1m column_prefix=NH2008
v.db.select NH_2008_areas
SEE ALSO
v.segment
v.generalize
v.transects
tutorial
AUTHORS
Eric Hardin, Helena Mitasova, Updates by John Lloyd
SOURCE CODE
Available at: v.transects source code
(history)
Latest change: Tuesday Feb 17 14:54:26 2026 in commit 051b9c1
