Skip to content
r.reclass.area
Reclasses a raster map greater or less than user specified area size (in hectares).
r.reclass.area [-cd] input=name output=name value=float mode=string [method=string] [--overwrite] [--verbose] [--quiet] [--qq] [--ui]
Example:
r.reclass.area input=name output=name value=0.0 mode=lesser
grass.tools.Tools.r_reclass_area(input, output, value, mode, method="reclass", flags=None, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
tools = Tools()
tools.r_reclass_area(input="name", output="name", value=0.0, mode="lesser")
grass.script.run_command("r.reclass.area", input, output, value, mode, method="reclass", flags=None, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
gs.run_command("r.reclass.area", input="name", output="name", value=0.0, mode="lesser")
Parameters
input=name [required]
    Name of input raster map
output=name [required]
    Name for output raster map
value=float [required]
    Value option that sets the area size limit (in hectares)
mode=string [required]
    Lesser or greater than specified value
    Allowed values: lesser, greater
method=string
    Method used for reclassification
    Allowed values: reclass, rmarea
    Default: reclass
-c
    Input map is clumped
-d
    Clumps including diagonal neighbors
--overwrite
--help
    Print usage summary
--verbose
    Verbose module output
--quiet
    Quiet module output
--qq
    Very quiet module output
--ui
    Force launching GUI dialog
input : str | np.ndarray, required
    Used as: input, raster, name
    Used as: output, raster, name
value : float, required
mode : str, required
method : str, optional
    Default: reclass
flags : str, optional
    Allowed values: c, d
    c
    d
overwrite : bool, optional
    Default: None
verbose : bool, optional
    Default: None
quiet : bool, optional
    Quiet module output
    Default: None
superquiet : bool, optional
    Default: None
Returns:
Raises:
input : str, required
output : str, required
    Default: reclass
    c
    d
    Default: None
    Default: None
    Quiet module output
    Default: None
    Default: None
DESCRIPTION
r.reclass.area reclasses a raster map greater or less than a user specified area size (in hectares).
If the -c flag is used, r.reclass.area will skip the creation of a clumped raster and assume that the input raster is already clumped.
EXAMPLES
In this example, the ZIP code map in the North Carolina sample dataset is filtered for large areas (removing smaller areas from the map).
g.region raster=zipcodes -p
r.report zipcodes unit=h
Extract only areas greater than 2000 ha, NULL otherwise:
r.reclass.area input=zipcodes output=zipcodes_larger2000ha mode=greater value=2000
r.report zipcodes_larger2000ha unit=h
Figure: r.reclass.area method=reclass
In this example, the ZIP code map in the North Carolina sample dataset is filtered for smaller areas which are substituted with the value of the respective adjacent area with largest shared boundary. Reclass by substitutional removing of areas minor of 1000 ha:
r.reclass.area input=zipcodes output=zipcodes_minor1000ha mode=lesser value=1000 method=rmarea
Figure: r.reclass.area method=rmarea
SEE ALSO
r.reclass, r.clump, r.stats
AUTHORS
NRCS,
Markus Neteler
SOURCE CODE
Available at: r.reclass.area source code (history)
Latest change: Thursday May 22 05:23:53 2025 in commit 199e858
