GRASS logo
NAME
r.surf.gauss - Generates a raster map using gaussian random number generator.
Mean and standard deviation of gaussian deviates can be expressed by the user.
KEYWORDS
raster, surface, random
SYNOPSIS
r.surf.gauss
r.surf.gauss --help
r.surf.gauss output=name [mean=float] [sigma=float] [seed=integer] [--overwrite] [--help] [--verbose] [--quiet] [--ui]
Flags:
--overwrite
--help
Print usage summary
--verbose
Verbose module output
--quiet
Quiet module output
--ui
Force launching GUI dialog
Parameters:
output=name [required]
Name for output raster map
mean=float
Distribution mean
Default: 0.0
sigma=float
Standard deviation
Default: 1.0
seed=integer
Seed for random number generator
The same seed can be used to obtain same results or random seed can be generated by other means.
Table of contents
DESCRIPTION
r.surf.gauss produces a raster map of Gaussian deviates whose mean and standard deviation can be expressed by the user. It uses a Gaussian random number generator. It is essentially the same as r.surf.random, but uses a Gaussian random number generator instead.
EXAMPLE
g.region -p n=228500 s=215000 w=630000 e=645000 res=10
r.surf.gauss out=gauss mean=0 sigma=10
# check result
r.univar gauss
r.surf.gauss example (mean: 0; sigma: 10)
Figure: Random Gaussian surface example (mean: 0; sigma: 10)
With the histogram tool the cell values versus count can be shown.
r.surf.gauss example histogram (mean: 0; sigma: 10)
Figure: Histogram of random Gaussian surface example (mean: 0; sigma: 10)
SEE ALSO
r.surf.contour, r.surf.fractal, r.surf.idw, r.surf.random, v.surf.rst
AUTHOR
Jo Wood, ASSIST's home
SOURCE CODE
Available at: r.surf.gauss source code (history)
Latest change: Tuesday Dec 17 20:17:20 2024 in commit: ab90c5e5a9b668894da360fa97ffd4a51a38931e
Main index | Raster index | Topics index | Keywords index | Graphical index | Full index
© 2003-2024 GRASS Development Team, GRASS GIS 8.5.0dev Reference Manual
