Skip to content
v.net.alloc
Allocates subnets for nearest centers.
Center node must be opened (costs >= 0). Costs of center node are used in calculation.
v.net.alloc [-tgu] input=name output=name [method=string] center_cats=range arc_layer=string arc_type=string [,string,...] node_layer=string [arc_column=name] [arc_backward_column=name] [node_column=name] [turn_layer=string] [turn_cat_layer=string] [--overwrite] [--verbose] [--quiet] [--qq] [--ui]
Example:
v.net.alloc input=name output=name center_cats=range arc_layer=1 arc_type=line,boundary node_layer=2
grass.script.run_command("v.net.alloc", input, output, method="from", center_cats, arc_layer="1", arc_type="line,boundary", node_layer="2", arc_column=None, arc_backward_column=None, node_column=None, turn_layer="3", turn_cat_layer="4", flags=None, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
gs.run_command("v.net.alloc", input="name", output="name", center_cats="range", arc_layer="1", arc_type="line,boundary", node_layer="2")
grass.tools.Tools.v_net_alloc(input, output, method="from", center_cats, arc_layer="1", arc_type="line,boundary", node_layer="2", arc_column=None, arc_backward_column=None, node_column=None, turn_layer="3", turn_cat_layer="4", flags=None, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
tools = Tools()
tools.v_net_alloc(input="name", output="name", center_cats="range", arc_layer="1", arc_type="line,boundary", node_layer="2")
Parameters
input=name [required]
    Name of input vector map
    Or data source for direct OGR access
output=name [required]
    Name for output vector map
method=string
    Use costs from centers or costs to centers
    Allowed values: from, to
    Default: from
center_cats=range [required]
    Category values
    Categories of centers (points on nodes) to which net will be allocated, layer for this categories is given by nlayer option
arc_layer=string [required]
    Arc layer
    Vector features can have category values in different layers. This number determines which layer to use. When used with direct OGR access this is the layer name.
    Default: 1
arc_type=string [,string,...] [required]
    Arc type
    Input feature type
    Allowed values: line, boundary
    Default: line,boundary
node_layer=string [required]
    Node layer
    Default: 2
arc_column=name
    Arc forward/both direction(s) cost column (number)
    Arc backward direction cost column (number)
node_column=name
    Node cost column (number)
turn_layer=string
    Layer with turntable
    Relevant only with -t flag
    Default: 3
    Layer with unique categories used in turntable
    Default: 4
-t
    Use turntable
-g
    Use geodesic calculation for longitude-latitude projects
-u
    Create unique categories and attribute table
    Default: same category like nearest center
--overwrite
--help
    Print usage summary
--verbose
    Verbose module output
--quiet
    Quiet module output
--qq
    Very quiet module output
--ui
    Force launching GUI dialog
input : str, required
    Used as: input, vector, name
output : str, required
    Used as: output, vector, name
method : str, optional
    Default: from
center_cats : str, required
    Category values
    Used as: input, cats, range
arc_layer : str, required
    Arc layer
    Used as: input, layer
    Default: 1
arc_type : str | list[str], required
    Arc type
    Input feature type
node_layer : str, required
    Node layer
    Default: 2
arc_column : str, optional
    Used as: input, dbcolumn, name
arc_backward_column : str, optional
node_column : str, optional
turn_layer : str, optional
    Default: 3
turn_cat_layer : str, optional
    Default: 4
flags : str, optional
    Allowed values: t, g, u
    t
        Use turntable
    g
    u
overwrite : bool, optional
    Default: None
verbose : bool, optional
    Default: None
quiet : bool, optional
    Quiet module output
    Default: None
superquiet : bool, optional
    Default: None
    Default: from
    Category values
    Arc layer
    Default: 1
    Arc type
    Input feature type
    Node layer
    Default: 2
    Default: 3
    Default: 4
    t
        Use turntable
    g
    u
    Default: None
    Default: None
    Quiet module output
    Default: None
    Default: None
Returns:
Raises:
DESCRIPTION
v.net.alloc allocates subnets for nearest centers. Center nodes must be opened (costs >= 0). Costs of center nodes are used in the calculation.
Costs may be either line lengths, or attributes saved in a database table. These attribute values are taken as costs of whole segments, not as costs to traverse a length unit (e.g. meter) of the segment. For example, if the speed limit is 100 km / h, the cost to traverse a 10 km long road segment must be calculated as
length / speed = 10 km / (100 km/h) = 0.1 h.
Supported are cost assignments for both arcs and nodes, and also different costs for both directions of a vector line. For areas, costs will be calculated along boundary lines.
The input vector needs to be prepared with v.net operation=connect in order to connect points representing center nodes to the network.
The nearest center can be determined using either costs from the nearest center or costs to the nearest center with option method. See example below.
By default, the category value of the nearest center is used as category value for output lines. With the -u flag, output lines become unique categories and an attribute table is created with the fields cat, ocat, center. The ocat field holds the original line category in arc_layer and the center field holds the center category in node_layer. Additionally, original line categories are copied from the input arc_layer to layer 2 in the output, together with any attribute table.
Application of flag -t enables a turntable support. This flag requires additional parameters turn_layer and turn_cat_layer that are otherwise ignored. The turntable allows to model e.g. traffic code, where some turns may be prohibited. This means that the input layer is expanded by turntable with costs of every possible turn on any possible node (intersection) in both directions. Turntable can be created by the v.net module. For more information about turns in the vector network analyses see wiki page.
NOTES
Nodes and arcs can be closed using cost = -1.
Center nodes can also be assigned to vector nodes using wxGUI vector digitizer.
EXAMPLES
1. Subnetwork allocation using distance:
v.net.alloc example using distance
2. Subnetwork allocation using traveling time:
v.net.alloc example using time
Example 1: Calculating subnets for 3 center nodes using distances
# Spearfish
# center nodes:
echo "591235.5|4926306.62|1
596591.8|4917042.5|2
602722.9|4923544.2|3" | v.in.ascii in=- out=centernodes
g.copy vect=roads,myroads
# connect points to network
v.net myroads points=centernodes out=myroads_net op=connect thresh=200
# allocate, specifying range of center cats (easier to catch all):
v.net.alloc myroads_net out=myroads_net_alloc center_cats=1-100000 node_layer=2
# report categories
v.category myroads_net_alloc option=report
To display the result, run for example:
# show result
g.region vector=myroads_net
d.mon x0
d.vect myroads_net layer=1
# the result has to be selected by category number of the relevant node:
d.vect myroads_net_alloc cat=1 col=red layer=1
d.vect myroads_net_alloc cat=2 col=green layer=1
d.vect myroads_net_alloc cat=3 col=yellow layer=1
# center nodes
d.vect myroads_net col=red icon=basic/triangle fcol=green size=12 layer=2
Example 2: Calculating subnets for 3 center nodes using traveling time
# Spearfish
# center nodes:
# create lines map connecting points to network
v.net myroads points=centernodes out=myroads_net op=connect thresh=500 arc_layer=1 node_layer=2
# set up costs
# create unique categories for each road in layer 3
v.category in=myroads_net out=myroads_net_time opt=add cat=1 layer=3 type=line
# add new table for layer 3
v.db.addtable myroads_net_time layer=3 col="cat integer,label varchar(43),length double precision,speed double precision,cost double precision,bcost double precision"
# copy road type to layer 3
v.to.db myroads_net_time layer=3 qlayer=1 opt=query qcolumn=label columns=label
# upload road length in miles
v.to.db myroads_net_time layer=3 type=line option=length col=length unit=miles
# set speed limits in miles / hour
v.db.update myroads_net_time layer=3 col=speed val="5.0"
v.db.update myroads_net_time layer=3 col=speed val="75.0" where="label='interstate'"
v.db.update myroads_net_time layer=3 col=speed val="75.0" where="label='primary highway, hard surface'"
v.db.update myroads_net_time layer=3 col=speed val="50.0" where="label='secondary highway, hard surface'"
v.db.update myroads_net_time layer=3 col=speed val="25.0" where="label='light-duty road, improved surface'"
v.db.update myroads_net_time layer=3 col=speed val="5.0" where="label='unimproved road'"
# define traveling costs as traveling time in minutes:
# set forward costs
v.db.update myroads_net_time layer=3 col=cost val="length / speed * 60"
# set backward costs
v.db.update myroads_net_time layer=3 col=bcost val="length / speed * 60"
# subnetwork allocation with fastest paths
v.net.alloc in=myroads_net_time arc_layer=3 node_layer=2 arc_column=cost arc_backward_column=bcost out=myroads_net_alloc_time center_cats=1-3
# show result
d.mon x0
d.vect myroads_net type=line layer=1
d.vect myroads_net_alloc_time cat=1 col=red layer=1
d.vect myroads_net_alloc_time cat=2 col=green layer=1
d.vect myroads_net_alloc_time cat=3 col=yellow layer=1
# center nodes
d.vect myroads_net_time col=red icon=basic/triangle fcol=green size=12 type=point layer=2
Example 3: Differences between costs from centers and costs to centers
Each lane of the two-lane road is a one-way road.
1. Subnetwork allocation from centers:
v.net.alloc example from centers
A center reaches any point following the one-way lanes.
2. Subnetwork allocation to centers:
v.net.alloc example to centers
Any node reaches reaches the nearest center following the one-way lanes.
In case of an accident, the ambulance should come from the nearest 'from' hospital and go to the nearest 'to' hospital.
# North Carolina
# center nodes are hospitals:
# connect hospitals to streets as layer 2
v.net input=streets_wake points=hospitals output=streets_hospitals operation=connect thresh=400 arc_layer=1 node_layer=2
v.to.db map=streets_hospitals layer=1 type=line option=cat columns=cat
# close oneway roads
v.db.update map=streets_hospitals column=TF_COST value=-1 where="ONE_WAY = 'FT'"
v.db.update map=streets_hospitals column=FT_COST value=-1 where="ONE_WAY = 'TF'"
# add costs to newly created lines
v.db.update map=streets_hospitals column=TF_COST value=0 where="cat > 49746"
v.db.update map=streets_hospitals column=FT_COST value=0 where="cat > 49746"
# from centers
v.net.alloc in=streets_hospitals out=streets_hospitals_alloc_from center_cats=1-10000 arc_column=FT_COST arc_backward_column=TF_COST
# to centers
v.net.alloc in=streets_hospitals out=streets_hospitals_alloc_to method=to center_cats=1-10000 arc_column=FT_COST arc_backward_column=TF_COST
SEE ALSO
d.path, v.net, v.net.iso, v.net.path, v.net.steiner, v.net.salesman
AUTHORS
Radim Blazek, ITC-Irst, Trento, Italy
Documentation: Markus Neteler, Markus Metz
TURNS SUPPORT
The turns support was implemnented as part of GRASS GIS turns cost project at Czech Technical University in Prague, Czech Republic. Eliska Kyzlikova, Stepan Turek, Lukas Bocan and Viera Bejdova participated at the project. Implementation: Stepan Turek Documentation: Lukas Bocan Mentor: Martin Landa
SOURCE CODE
Available at: v.net.alloc source code (history)
Latest change: Friday May 09 14:33:40 2025 in commit b356c7e
