Skip to content
Migration guide: from grass.script command functions to grass.tools
Overview
The grass.tools module provides a modern, more Pythonic interface to GRASS tools compared to the traditional grass.script command functions (run_command, read_command, write_command, and parse_command). This guide helps you migrate existing code that uses these functions to the new grass.tools.Tools object.
Note that this migration guide focuses specifically on replacing the grass.script.run_command family of functions and their wrappers, such as list_strings. Other grass.script functionality, such as project and session management (gs.create_project, gs.setup.init), was enhanced and no changes in user code are required.
Why migrate?
The grass.script.run_command family of functions stems from GRASS's transition from Bash scripting to Python. While functional, this approach has significant drawbacks: the tool name is in a string parameter while generic function names like run_command and parse_command dominate your code. Different functions are required depending on whether you need to capture output (read_command), parse results (parse_command), or pipe input (write_command). This forces you to think about the mechanics of calling tools rather than focusing on the tools themselves.
The new grass.tools API centers everything around the tools. Tool names become Python function names of a Tools object, all parameters become keyword arguments, and you get consistent, smart return values regardless of what the tool outputs. The result is code that reads more naturally and requires less mental overhead because the tool names are more prominent and special configuration is concentrated in one place.
Key advantages of grass.tools:
  • More Pythonic: Function-style syntax with snake-case tool names (e.g., tools.r_random_surface())
  • Powerful return values: All tools return result objects with standardized attributes
  • Cleaner syntax: No need to repeatedly pass the env parameter
  • JSON support: Better support for JSON output format
  • Flexible input: Direct support for Python objects beyond numbers and lists (e.g., io.StringIO or np.array)
Basic syntax transformation
Tool names as function names
The fundamental shift is from calling generic functions with tool names as string parameters to calling tools directly as Python functions.
The run_command approach requires run_command with the tool name as a string:
import grass.script as gs
gs.run_command("r.slope.aspect", elevation="elevation", slope="slope")
The new approach makes the tool name the function itself. Create a Tools object once, then call tools using snake_case names (dots become underscores):
from grass.tools import Tools
tools = Tools()
tools.r_slope_aspect(elevation="elevation", slope="slope")
Notice how r.slope.aspect becomes r_slope_aspect, and the tool name is now prominent in your code rather than hidden in a string.
If you need the string-based syntax (for example, when the tool name is in a variable), you can use tools.run():
tools.run("r.slope.aspect", elevation="elevation", slope="slope")
tools.run(tool_name, **parameters)
However, the function syntax is recommended as your primary approach because it provides better code completion support, works better with generative AI, catches typos sooner, and reads more naturally.
One object for all tool types
The run_command API requires different functions depending on what you needed from the tool. Running a tool that creates data outputs as files used run_command, getting text output requires read_command, piping input needed write_command, and parsing structured output demands parse_command. You have to remember which function to use and switch between them as your needs change.
The new API uses a single, unified approach. Every tool is called the same way, and the result object provides access to everything you might need. This means you don't need to change function names when you realize you need to access the tool's output or when using a different tool.
Special parameters in one place
In grass.tools, handling of special parameters is centralized. For example, instead of passing an env parameter to every tool invocation:
gs.run_command("g.region", raster="elevation", env=session.env)
gs.run_command("r.slope.aspect", elevation="elevation", slope="slope", env=session.env)
You configure the environment once when creating a Tools instance:
tools = Tools(env=session.env)
tools.g_region(raster="elevation")
This eliminates repetitive parameters in tool calls and makes workflows easier to read and maintain. The following examples will not use the explicit session setting, assuming an existing global session, but the Tools API makes it easy to add an explicit session in one place.
Replacing different command functions
From run_command to direct tool calls
When you just need to run a tool and create outputs, the migration is straightforward. The run_command syntax:
gs.run_command("r.random.surface", output="surface", seed=42)
Becomes:
tools = Tools()
tools.r_random_surface(output="surface", seed=42)
Or with the string syntax:
tools.run("r.random.surface", output="surface", seed=42)
From read_command to result attributes
The read_command function captures a tool's standard output as a string. With grass.tools, every tool call returns a result object, and you access the output through its attributes.
The run_command family way to get text output:
result = gs.read_command("g.region", flags="c")
# Returns: "center easting:  0.500000\ncenter northing: 0.500000\n"
The new approach accesses the text attribute, which strips trailing whitespace:
result = tools.g_region(flags="c").text
# Returns: "center easting:  0.500000\ncenter northing: 0.500000"
If you need the output exactly as it was written, including newlines or original encoding, use stdout instead:
result = tools.g_region(flags="c").stdout
This works identically with the string syntax:
result = tools.run("g.region", flags="c").stdout
From parse_command to smart result objects
The parse_command function parses key-value output from tools, and more recently JSON, depending on the parameters. Shell format returns strings, while JSON format returns proper numbers. With grass.tools, you get automatic type conversion and can access parsed data directly.
The old approach with shell format:
result = gs.parse_command("g.region", flags="c", format="shell")
# Returns: {"center_easting": "0.500000", "center_northing": "0.500000"}
The new keyval attribute automatically converts to numbers if the string values are convertible, bringing the output processing closer to JSON:
result = tools.g_region(flags="c", format="shell").keyval
# Returns: {"center_easting": 0.5, "center_northing": 0.5}
For JSON format, the old approach was:
result = gs.parse_command("g.region", flags="c", format="json")
For JSON format, you can use the json attribute explicitly:
result = tools.g_region(flags="c", format="json").json
However, for simpler syntax, result objects also support dictionary-like access, avoiding a need for an additional variable or attribute access in the code:
data = tools.g_region(flags="c", format="json")
center_e = data["center_easting"]
center_n = data["center_northing"]
From write_command to passing objects
The write_command function pipes text to a tool's standard input using a special stdin parameter along with input="-" which is required by the tools (but standardized across tools). This syntax requires two different parameters to set the input in addition to using a dedicated function name.
The run_command family approach:
gs.write_command(
    "v.in.ascii",
    input="-",
    output="point1",
    separator=",",
    stdin="13.45,29.96,200\n",
With grass.tools, you pass io.StringIO objects directly to the input parameter, treating stdin like any other input source:
import io
tools.v_in_ascii(
    input=io.StringIO("13.45,29.96,200\n"),
    output="point3",
    separator=",",
This also works with the string syntax:
tools.run(
    "v.in.ascii",
    output="point2",
    separator=",",
Replacing convenience wrapper functions
Beyond the core *_command functions, grass.script provides various convenience wrappers to mitigate different shortcomings of the run_command family approach. These can be replaced with direct tool calls using JSON format.
Type conversion for values is done automatically in the result object and/or with JSON, and the basic tool call syntax is more lightweight, so the direct tool call is usually not that different from a wrapper. Direct tool calling also benefits from other features, not just the new Python API, namely from better tool defaults (e.g., printing more in JSON) and from more consistent tool behavior (e.g., tools accepting format="json").
Not using the wrappers also makes it clear that any special parameters, such as a session, need to be passed to each relevant call. While this is obvious for the tools, it is less obvious when the wrappers are used.
From mapcalc to r.mapcalc
The mapcalc function is a shortcut for r.mapcalc:
gs.mapcalc("a = 1")
With grass.tools, call r.mapcalc directly with the expression parameter for short expressions:
tools.r_mapcalc(expression="a = 1")
For longer expressions (which would hit the operating system limit on the length of subprocess parameter list), you can use a StringIO object:
tools.r_mapcalc(file=io.StringIO("a = 1"))
While this requires you to make a decision about the parameter, depending on the length of the expression as well as specifying the parameter explicitly, the same approach also works for other tools that accept potentially long parameter values (e.g., r.series), without needing a tool-specific wrapper. In practice, the decision should be easy: all generated expressions should use the file parameter, while expressions written as a Python string literal over a couple of lines can use the simpler expression parameter.
Replacing mapcalc usage of string templates
The mapcalc wrapper function internally uses Python string templates which allows shell-like variable replacement where the values are passed as parameters:
gs.mapcalc("$c = $a + $b", a=input_1, b=input_2, c=sum_raster)
This usage pattern can be replaced by direct use of Python formatting capabilities, for example an f-strings:
tools.r_mapcalc(expression=f"{sum_raster} = {input_1} + {input_2}")
For simple expressions and limited number of input rasters, the r.mapcalc.simple tool provides an alternative syntax:
tools.r_mapcalc_simple(expression="A + B", a=input_1, b=input_2, output=sum_raster)
For r.mapcalc.simple, the parametrized inputs need to be rasters and they are always marked by letters in the expression. However, r.mapcalc.simple provides access to convenience features of the grass.tools API, such as the direct input of NumPy arrays.
From list_grouped, list_strings, list_pairs to g.list
The old API provides several functions for listing maps, each returning data in a different format. These are replaced by calling g.list with JSON format and using list comprehensions to extract the data you need.
Assume we have rasters named ["a", "b", "c", "surface", "surface2", "surface3"] in the PERMANENT mapset.
The list_grouped wrapper organizes maps by mapset:
result = gs.list_grouped("raster")
names = result["PERMANENT"]
Use g.list with JSON format and filter by mapset:
names = [
    item["name"]
    for item in tools.g_list(type="raster", format="json")
    if item["mapset"] == "PERMANENT"
The list_strings wrapper returns full names:
result = gs.list_strings("raster")
Extract the fullname field from the JSON output:
result = [item["fullname"] for item in tools.g_list(type="raster", format="json")]
The list_pairs returns tuples:
result = gs.list_pairs("raster")
Extract name and mapset as tuples:
result = [
    (item["name"], item["mapset"])
While these require more code than the convenience functions, they're more flexible and use the standard Python functionality to deal with the data retrieved through the JSON output, allowing for greater customization most fitting to the specific use case.
From region to g.region
The region wrapper parses g.region output and returns a dictionary with type-converted values:
info = gs.region()
num_rows = info["rows"]
# Returns: 1 (as integer because of internal conversion)
Call g.region directly with JSON format:
num_rows = tools.g_region(flags="p", format="json")["rows"]
# Returns: 1 (as an integer thanks to JSON)
Handling special cases
The general tool behavior and interaction is configured when creating a new Tools instance:
tools = Tools(consistent_return_value=True, overwrite=True)
This configuration applies to all calls made with this Tools instance, avoiding repetition of the parameters. On the other hand, if you need to set the special parameter for only one tool call, you will typically need to create a separate Tools object for that call. However, the objects are cheap to create, so the overhead is negligible in most cases.
Checking return codes without exceptions
By default, grass.tools raises exceptions when tools fail, which is appropriate for most workflows. If you need to check return codes without raising exceptions, configure the Tools object accordingly.
The run_command approach uses errors="status":
returncode = gs.run_command("r.mask.status", flags="t", errors="status")
# Returns: 1 (if no mask exists)
Configure the Tools object to ignore errors and always return result objects:
tools_with_returncode = Tools(
    errors="ignore",
result = tools_with_returncode.r_mask_status(flags="t")
returncode = result.returncode
# Returns: 1
While the new tool call above involves more objects, namely a separate Tools object and also tool result object, an actual tool call in the code may be quite straightforward:
returncode = tools.r_mask_status(flags="t").returncode
# Returns: 1
Using the overwrite flag
The overwrite flag can be set per tool call or globally for all calls.
The run_command approach requires it on every call:
gs.run_command(
    "r.random.surface",
    output="surface",
    seed=42,
    overwrite=True,
Or you can set that for the whole process using an environment variable, called GRASS_OVERWRITE. You also can pass a dedicated environment with the env parameter with the variable set there influencing only those tools for which you pass the env variable.
The environment variable approach is still available with grass.tools, but the Tools class allows a more clear and friendlier approach.
You can still pass it per call:
tools = Tools()
tools.r_random_surface(output="surface", seed=42, overwrite=True)
However, you can set overwrite globally when creating the Tools object:
tools = Tools(overwrite=True)
This approach is particularly useful in scripts where you frequently recreate outputs during development and testing, but are not ready to turn your script into a GRASS tool in Python which provides the overwrite settings automatically. For many scripts, this means that overwrite setting is limited to one line rather than being present in every tool call.
Environment and session management
One of the biggest improvements in grass.tools is how it handles environments. Instead of passing env=session.env to every single function call, you configure it once.
The run_command approach repeats the environment parameter for every call:
gs.run_command("r.import", input="elevation.tif", output="elevation", env=session.env)
With grass.tools, set the environment once:
tools.r_import(input="elevation.tif", output="elevation")
You can pass either a session object or an environment dictionary:
# Using a session object
tools = Tools(session=session)
# Using an environment dictionary
For rare cases where individual tool calls need different environments (such as in certain parallelization scenarios), you can still override per call:
tools.g_region(rows=100, cols=100, env=custom_env)
tools.r_random_surface(output="surface", seed=42, env=another_custom_env)
However, the typical pattern is to create separate Tools objects for different environments rather than overriding per call.
Return values
For grass.tools, the return value of a tool call depends on the parameters and the tool's output, unlike the run_command family of functions where the return value depends on the function used in addition to parameters. By default, a tool call returns a result object if the tool produces output (stdout) or None when a tool produces no output. The result object provides multiple ways to access the tool's output and performs any further processing based on what attributes or functions are used.
For JSON results, you can also use dictionary-style indexing directly on the result object:
result = tools.g_region(flags="p", format="json")
rows = result["rows"]  # Equivalent to result.json["rows"]
While the grass.tools return value is supposed to be predictable and useful, it is not as consistent as with the run_command family of functions. If you need a consistent return value, e.g., for automation, a consistent return value behavior can be requested:
tools = Tools(consistent_return_value=True)
result = tools.r_slope_aspect(elevation="elevation", slope="slope")
# result is now a result object, even though stdout was empty
This configurable behavior avoids cluttering interactive sessions when a tool creates output files, but prints nothing to stdout (like r.slope.aspect), while at the same time it accommodates more advanced cases when consistent, not just predictable, return value is needed. This further provides better control when NumPy arrays are returned by the tool call.
Complete migration example
Here's a complete example showing the transformation from run_command to grass.tools syntax for a script which explicitly sets up and passes a session to tool calls. (A code for an analytical GRASS tool will typically leave out the session handling completely relying on the parent session. Scripts can simply set up a global session and rely on it implicitly, without passing it to each call. Consequently, your actual code may be much simpler, then this example.)
Old approach using run_command functions
with gs.setup.init("path/to/project") as session:
    # Import raster
    gs.run_command(
        "r.import", input="/path/to/elevation.tif", output="elevation", env=session.env
    # Set region
    # Calculate slope
    gs.run_command(
    # Get region info
    region_info = gs.region(env=session.env)
    print(f"Rows: {region_info['rows']}")
    # List rasters
    rasters = gs.list_strings("raster", env=session.env)
    print(f"Rasters: {rasters}")
New approach using grass.tools
    # Import raster
    tools.r_import(input="/path/to/elevation.tif", output="elevation")
    # Set region
    # Calculate slope
    # Get region info
    region_info = tools.g_region(flags="p", format="json")
    # List rasters
    rasters = [item["fullname"] for item in tools.g_list(type="raster", format="json")]
Most of the calls are shorter because run_command-like functions are avoided and passing of the environment is done once. The code focuses on what you're doing rather than how you're calling tools.
Migration status and stability
Migration to grass.tools is recommended for new code but not required. The API is included in GRASS 8.5 but not yet considered stable. However, no major API changes are expected—only implementation refinements, additions, and internal refactoring.
If your project requires absolute API stability, continue using grass.script.run_command and related functions. There are no current plans to deprecate the command functions or the grass.pygrass.modules submodule, so you can migrate at your own pace.
For projects that can accommodate minor API adjustments, adopting grass.tools now will provide immediate benefits in code clarity and maintainability. The core syntax and patterns are solid and unlikely to change.
Summary
Migrating from grass.script command functions to grass.tools involves these key changes:
  • Create and use a Tools object once instead of calling different generic functions.
  • Replace run_command("tool.name", ...) with tools.tool_name(...).
  • Replace read_command with result attributes like stdout or text.
  • Replace parse_command with json or keyval attributes.
  • Replace write_command with direct io.StringIO input.
  • Replace convenience functions like mapcalc, list_pairs, and region with direct tool calls using JSON format.
  • Set session (environment) once on the Tools object rather than passing env to every call.
  • Use the function syntax tools.r_slope_aspect() as your primary approach, with tools.run("r.slope.aspect") available when needed.
The rest of grass.script (project management, session handling, etc.) remains unchanged and should continue to be used alongside grass.tools.
For more information, see the introduction to the Python interface.
SOURCE CODE
Available at: migration_to_grass_tools_python_api source code (history)
Latest change: Thursday Nov 19 12:05:09 2026 in commit cb5bcdb
