Skip to content
Tools
GRASS offers a comprehensive set of tools for geospatial processing, modeling, analysis, and visualization. These tools are categorized by data type, with prefixes indicating their respective categories. Use the table below to explore the main tool categories:
Prefix Category Description
g. General General GIS management tools
r. Raster Raster data processing tools
r3. 3D raster 3D Raster data processing tools
v. Vector Vector data processing tools
i. Imagery Imagery processing tools
t. Temporal Temporal data processing tools
db. Database Database management tools
d. Display Display and visualization tools
m. Miscellaneous Miscellaneous tools
Display tools (d.)
Name Description
d.background Fills the graphics display frame with user defined color.
d.barscale Displays a barscale on the graphics monitor.
d.colorlist Outputs a list of all available display colors.
d.colortable Displays the color table associated with a raster map layer.
d.correlate Prints a graph of the correlation between raster maps (in pairs).
d.erase Erases the contents of the active graphics display frame with user defined color.
d.font Selects the font in which text will be displayed on the user's graphics monitor.
d.fontlist Lists the available fonts.
d.frame Manages display frames on the user's graphics monitor.
d.geodesic Displays a geodesic line, tracing the shortest distance between two geographic points along a great circle, in a longitude/latitude data set.
d.graph Program for generating and displaying simple graphics on the display monitor.
d.grid Overlays a user-specified grid in the active display frame on the graphics monitor.
d.his Displays the result obtained by combining hue, intensity, and saturation (HIS) values from user-specified input raster map layers.
d.histogram Displays a histogram in the form of a pie or bar chart for a user-specified raster map.
d.info Displays information about the active display monitor. Display monitors are maintained by d.mon.
d.labels Displays text labels (created with v.label) to the active frame on the graphics monitor.
d.legend Displays a legend for a 2D or 3D raster map in the active frame of the graphics monitor.
d.legend.vect Displays a vector legend in the active graphics frame.
d.linegraph Generates and displays simple line graphs in the active graphics monitor display frame.
d.mon Controls graphics display monitors from the command line.
d.northarrow Displays a north arrow on the graphics monitor.
d.out.file Saves the contents of the active display monitor to a graphics file.
d.path Finds shortest path for selected starting and ending node.
d.polar Draws polar diagram of angle map such as aspect or flow directions
d.profile Plots profile of a transect.
d.rast.arrow Draws arrows representing cell aspect direction for a raster map containing aspect data.
d.rast.edit Edits cell values in a raster map.
d.rast.leg Displays a raster map and its legend on a graphics window
d.rast Displays user-specified raster map in the active graphics frame.
d.rast.num Overlays cell category values on a raster map displayed in the active graphics frame.
d.redraw Redraws the content of currently selected monitor.
d.rgb Displays three user-specified raster maps as red, green, and blue overlays in the active graphics frame.
d.rhumbline Displays the rhumbline joining two longitude/latitude coordinates.
d.shade Drapes a color raster over an shaded relief or aspect map.
d.text Draws text in the active display frame on the graphics monitor using the current font.
d.title Create a TITLE for a raster map in a form suitable for display with d.text.
d.to.rast Saves the contents of the active display monitor to a raster map.
d.vect.chart Displays charts of vector data in the active frame on the graphics monitor.
d.vect Displays user-specified vector map in the active graphics frame.
d.vect.thematic Displays a thematic vector map in the active graphics frame.
d.what.rast Allows the user to interactively query raster map layers at user-selected locations.
d.what.vect Allows the user to interactively query vector map layers at user-selected locations.
d.where Identifies the geographic coordinates associated with point locations given in display coordinates.
Database tools (db.)
Name Description
db.columns List all columns for a given table.
db.connect Prints/sets general DB connection for current mapset.
db.copy Copy a table. Either 'from_table' (optionally with 'where') can be used or 'select' option, but not 'from_table' and 'select' at the same time.
db.createdb Creates an empty database.
db.databases Lists all databases for a given driver and location.
db.describe Describes a table in detail.
db.drivers Lists all database drivers.
db.dropcolumn Drops a column from selected attribute table.
db.dropdb Removes an existing database.
db.droptable Drops an attribute table.
db.execute Executes any SQL statement. For SELECT statements use 'db.select'.
db.in.ogr Imports attribute tables in various formats.
db.login Sets user/password for DB driver/database.
db.out.ogr Exports attribute tables into various formats.
db.select Selects data from attribute table. Performs SQL query statement(s).
db.tables Lists all tables for a given database.
db.test Test database driver, database must exist and set by db.connect.
db.univar Calculates univariate statistics on selected table column.
General tools (g.)
Name Description
g.access Controls access to the current mapset for other users on the system. If no option given, prints current status.
g.cairocomp Overlays multiple X Pixmaps.
g.copy Creates copies of maps and other elements Copies available data files in the current mapset search path to the user's current mapset.
g.dirseps Internal GRASS utility for converting directory separator characters. Converts any directory separator characters in the input string to or from native host format, and writes the changed path to standard output. Useful in scripts for Windows compatibility.
g.download.location Download GRASS project (location) from the web Get GRASS project from an URL or file path
g.download.project Download GRASS project from the web Get GRASS project from an URL or file path
g.extension.all Rebuilds or removes all locally installed GRASS Addons extensions. By default only extensions built against different GIS Library are rebuilt.
g.extension Maintains GRASS Addons extensions in local GRASS installation. Downloads and installs extensions from GRASS Addons repository or other source into the local GRASS installation or removes installed extensions.
g.filename Prints GRASS data base file names.
g.findetc Searches for GRASS support files.
g.findfile Searches for GRASS data base files and sets variables for the shell.
g.gisenv Outputs and modifies the user's current GRASS variable settings. Prints all defined GRASS variables if no option is given.
g.gui.animation Tool for animating a series of raster and vector maps or a space time raster or vector dataset.
g.gui.datacatalog Tool for browsing, modifying and managing GRASS maps.
g.gui.dbmgr Launches graphical attribute table manager.
g.gui.gcp Georectifies a map and allows managing Ground Control Points.
g.gui.gmodeler Graphical Modeler. Allows interactively creating, editing and managing models.
g.gui.iclass Tool for supervised classification of imagery data. Generates spectral signatures for an image by allowing the user to outline regions of interest.
g.gui.image2target Georectifies a map and allows managing Ground Control Points for 3D correction.
g.gui.mapswipe Interactively compares two maps by swiping a visibility bar.
g.gui Launches a GRASS graphical user interface (GUI) session. Optionally updates default user interface settings.
g.gui.photo2image Corrects scanning distortions of a paper photo.
g.gui.psmap Tool for creating hardcopy map outputs.
g.gui.rdigit Interactive editing and digitizing of raster maps.
g.gui.rlisetup Configuration tool for r.li modules.
g.gui.timeline Allows comparing temporal datasets by displaying their temporal extents in a plot.
g.gui.tplot Plots the values of temporal datasets.
g.gui.vdigit Interactive editing and digitization of vector maps.
g.list Lists available GRASS data base files of the user-specified data type optionally using the search pattern.
g.manual Displays the manual pages of GRASS modules.
g.mapset Changes or reports current mapset. Optionally, creates new mapset or lists available mapsets in given project (location).
g.mapsets Modifies or reports the user's current mapset search path. Affects the user's access to data existing under the other mapsets in the current project.
g.message Prints a message, warning, progress info, or fatal error in the GRASS way. This module should be used in scripts for messages served to user.
g.mkfontcap Generates the font configuration file by scanning various directories for fonts.
g.parser Provides automated parser, GUI, and help support for GRASS scripts.
g.pnmcomp Overlays multiple PPM image files.
g.ppmtopng Converts between PPM/PGM and PNG image formats.
g.proj Prints or modifies GRASS projection information files (in various coordinate system descriptions). Can also be used to create new GRASS projects.
g.region Manages the boundary definitions for the geographic region.
g.remove Removes data base element files from the user's current mapset using the search pattern.
g.rename Renames data base element files in the user's current mapset.
g.search.modules Search in GRASS modules using keywords
g.tempfile Creates a temporary file and prints it's file name.
g.version Displays GRASS version info. Optionally also prints build or copyright information.
Imagery tools (i.)
Name Description
i.albedo Computes broad band albedo from surface reflectance.
i.aster.toar Calculates Top of Atmosphere Radiance/Reflectance/Brightness Temperature from ASTER DN.
i.atcorr Performs atmospheric correction using the 6S algorithm. 6S - Second Simulation of Satellite Signal in the Solar Spectrum.
i.band.library Prints available semantic label information used for multispectral data.
i.biomass Computes biomass growth, precursor of crop yield calculation.
i.cca Canonical components analysis (CCA) program for image processing.
i.cluster Generates spectral signatures for land cover types in an image using a clustering algorithm. The resulting signature file is used as input for i.maxlik, to generate an unsupervised image classification.
i.colors.enhance Performs auto-balancing of colors for RGB images.
i.eb.eta Actual evapotranspiration for diurnal period (Bastiaanssen, 1995).
i.eb.evapfr Computes evaporative fraction and root zone soil moisture.
i.eb.hsebal01 Computes sensible heat flux iteration SEBAL 01.
i.eb.netrad Net radiation approximation (Bastiaanssen, 1995).
i.eb.soilheatflux Soil heat flux approximation (Bastiaanssen, 1995).
i.emissivity Computes emissivity from NDVI, generic method for sparse land.
i.evapo.mh Computes evapotranspiration calculation modified or original Hargreaves formulation, 2001.
i.evapo.pm Computes potential evapotranspiration calculation with hourly Penman-Monteith.
i.evapo.pt Computes evapotranspiration calculation Priestley and Taylor formulation, 1972.
i.evapo.time Computes temporal integration of satellite ET actual (ETa) following the daily ET reference (ETo) from meteorological station(s).
i.fft Fast Fourier Transform (FFT) for image processing.
i.gensig Generates statistics for i.maxlik from raster map.
i.gensigset Generates statistics for i.smap from raster map.
i.group Creates, edits, and lists groups of imagery data.
i.his.rgb Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to RGB (Red-Green-Blue) color space.
i.ifft Inverse Fast Fourier Transform (IFFT) for image processing.
i.image.mosaic Mosaics several images and extends colormap.
i.in.spotvgt Imports SPOT VGT NDVI data into a raster map.
i.landsat.acca Performs Landsat TM/ETM+ Automatic Cloud Cover Assessment (ACCA).
i.landsat.toar Calculates top-of-atmosphere radiance or reflectance and temperature for Landsat MSS/TM/ETM+/OLI
i.maxlik Classifies the cell spectral reflectances in imagery data. Classification is based on the spectral signature information generated by either i.cluster, g.gui.iclass, or i.gensig.
i.modis.qc Extracts quality control parameters from MODIS QC layers.
i.oif Calculates Optimum-Index-Factor table for spectral bands
i.ortho.camera Select and modify the imagery group camera reference file.
i.ortho.elev Select or modify the target elevation model.
i.ortho.init Interactively creates or modifies entries in a camera initial exposure station file for imagery group referenced by a sub-block.
i.ortho.photo Menu driver for the photo imagery programs.
i.ortho.rectify Orthorectifies an image by using the image to photo coordinate transformation matrix.
i.ortho.target Select or modify the imagery group target.
i.ortho.transform Computes a coordinate transformation based on the control points.
i.pansharpen Image fusion algorithms to sharpen multispectral with high-res panchromatic channels
i.pca Principal components analysis (PCA) for image processing.
i.rectify Rectifies an image by computing a coordinate transformation for each pixel in the image based on the control points.
i.rgb.his Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-Intensity-Saturation) color space.
i.segment Identifies segments (objects) from imagery data.
i.signatures Manage imagery classification signature files
i.smap Performs contextual image classification using sequential maximum a posteriori (SMAP) estimation.
i.spectral Displays spectral response at user specified locations in group or images.
i.svm.predict Predict with a SVM Predict with a Support Vector Machine
i.svm.train Train a SVM Train a Support Vector Machine
i.target Targets an imagery group to a GRASS location and mapset.
i.tasscap Performs Tasseled Cap (Kauth Thomas) transformation.
i.topo.corr Computes topographic correction of reflectance.
i.vi Calculates different types of vegetation indices. Uses red and nir bands mostly, and some indices require additional bands.
i.zc Zero-crossing "edge detection" raster function for image processing.
Miscellaneous tools (m.)
Name Description
m.cogo A simple utility for converting bearing and distance measurements to coordinates and vice versa. It assumes a cartesian coordinate system
m.measure Measures the lengths and areas of features.
m.nviz.image Creates a 3D rendering of GIS data. Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster data) in 3D.
m.nviz.script Creates fly-through script to run in NVIZ.
m.proj Converts coordinates from one projection to another (cs2cs frontend).
m.transform Computes a coordinate transformation based on the control points.
PostScript tools (ps.)
Name Description
ps.map Produces hardcopy PostScript map output.
Raster tools (r.)
Name Description
r.basins.fill Generates watershed subbasins raster map.
r.blend Blends color components of two raster maps by a given ratio.
r.buffer.lowmem Creates a raster map showing buffer zones surrounding cells that contain non-NULL category values. This is the low-memory alternative to the classic r.buffer module.
r.buffer Creates a raster map showing buffer zones surrounding cells that contain non-NULL category values.
r.buildvrt Build a VRT (Virtual Raster) from the list of input raster maps.
r.carve Generates stream channels. Takes vector stream data, transforms it to raster and subtracts depth from the output DEM.
r.category Manages category values and labels associated with user-specified raster map layers.
r.circle Creates a raster map containing concentric rings around a given point.
r.clump Recategorizes data in a raster map by grouping cells that form physically discrete areas into unique categories.
r.coin Tabulates the mutual occurrence (coincidence) of categories for two raster map layers.
r.colors Creates/modifies the color table associated with a raster map.
r.colors.out Exports the color table associated with a raster map.
r.colors.stddev Sets color rules based on stddev from a raster map's mean value.
r.composite Combines red, green and blue raster maps into a single composite raster map.
r.compress Compresses and decompresses raster maps.
r.contour Produces a vector map of specified contours from a raster map.
r.cost Creates a raster map showing the cumulative cost of moving between different geographic locations on an input raster map whose cell category values represent cost.
r.covar Outputs a covariance/correlation matrix for user-specified raster map layer(s).
r.cross Creates a cross product of the category values from multiple raster map layers.
r.describe Prints terse list of category values found in a raster map layer.
r.distance Locates the closest points between objects in two raster maps.
r.drain Traces a flow through an elevation model or cost surface on a raster map.
r.external Links GDAL supported raster data as a pseudo GRASS raster map.
r.external.out Redirects raster output to file utilizing GDAL library rather than storing in GRASS raster format.
r.fill.dir Filters and generates a depressionless elevation map and a flow direction map from a given elevation raster map.
r.fill.stats Rapidly fills 'no data' cells (NULLs) of a raster map with interpolated values (IDW).
r.fillnulls Fills no-data areas in raster maps using spline interpolation.
r.flow Constructs flowlines. Computes flowlines, flowpath lengths, and flowaccumulation (contributing areas) from a elevation raster map.
r.geomorphon Calculates geomorphons (terrain forms) and associated geometry using machine vision approach.
r.grow.distance Generates a raster map containing distances to nearest raster features and/or the value of the nearest non-null cell.
r.grow Generates a raster map layer with contiguous areas grown by one cell.
r.gwflow Numerical calculation program for transient, confined and unconfined groundwater flow in two dimensions.
r.his Generates red, green and blue (RGB) raster map layers combining hue, intensity and saturation (HIS) values from user-specified input raster map layers.
r.horizon Computes horizon angle height from a digital elevation model. The module has two different modes of operation: 1. Computes the entire horizon around a single point whose coordinates are given with the 'coord' option. The horizon height (in radians). 2. Computes one or more raster maps of the horizon height in a single direction. The input for this is the angle (in degrees), which is measured counterclockwise with east=0, north=90 etc. The output is the horizon height in radians.
r.import Imports raster data into a GRASS raster map using GDAL library and reprojects on the fly.
r.in.ascii Converts a GRASS ASCII raster file to binary raster map.
r.in.aster Georeference, rectify, and import Terra-ASTER imagery and relative DEMs using gdalwarp.
r.in.bin Import a binary raster file into a GRASS raster map layer.
r.in.gdal Imports raster data into a GRASS raster map using GDAL library.
r.in.gridatb Imports GRIDATB.FOR map file (TOPMODEL) into a GRASS raster map.
r.in.mat Imports a binary MAT-File(v4) to a GRASS raster.
r.in.pdal Creates a raster map from LAS LiDAR points using univariate statistics.
r.in.png Imports non-georeferenced PNG format image.
r.in.poly Creates raster maps from ASCII polygon/line/point data files.
r.in.srtm Imports SRTM HGT files into raster map.
r.in.wms Downloads and imports data from OGC WMS and OGC WMTS web mapping servers.
r.in.xyz Creates a raster map from an assemblage of many coordinates using univariate statistics.
r.info Outputs basic information about a raster map.
r.kappa Calculates error matrix and kappa parameter for accuracy assessment of classification result.
r.lake Fills lake at given point to given level.
r.latlong Creates a latitude/longitude raster map.
r.li.cwed Calculates contrast weighted edge density index on a raster map
r.li.daemon Support module for r.li landscape index calculations.
r.li.dominance Calculates dominance's diversity index on a raster map
r.li.edgedensity Calculates edge density index on a raster map, using a 4 neighbour algorithm
r.li Landscape structure analysis package overview
r.li.mpa Calculates mean pixel attribute index on a raster map
r.li.mps Calculates mean patch size index on a raster map, using a 4 neighbour algorithm
r.li.padcv Calculates coefficient of variation of patch area on a raster map
r.li.padrange Calculates range of patch area size on a raster map
r.li.padsd Calculates standard deviation of patch area a raster map
r.li.patchdensity Calculates patch density index on a raster map, using a 4 neighbour algorithm
r.li.patchnum Calculates patch number index on a raster map, using a 4 neighbour algorithm.
r.li.pielou Calculates Pielou's diversity index on a raster map
r.li.renyi Calculates Renyi's diversity index on a raster map
r.li.richness Calculates richness index on a raster map
r.li.shannon Calculates Shannon's diversity index on a raster map
r.li.shape Calculates shape index on a raster map
r.li.simpson Calculates Simpson's diversity index on a raster map
r.mapcalc Raster map calculator.
r.mapcalc.simple Calculates a new raster map from a simple r.mapcalc expression.
r.mask Creates a raster mask for limiting raster operation.
r.mask.status Reports presence or absence of a raster mask Provides information about the presence of a 2D raster mask as text output or return code
r.mfilter Performs raster map matrix filter.
r.mode Finds the mode of values in a cover map within areas assigned the same category value in a user-specified base map.
r.neighbors Makes each cell category value a function of the category values assigned to the cells around it, and stores new cell values in an output raster map layer.
r.null Manages NULL-values of given raster map.
r.object.geometry Calculates geometry parameters for raster objects.
r.out.ascii Converts a raster map layer into a GRASS ASCII text file.
r.out.bin Exports a GRASS raster to a binary array.
r.out.gdal Exports GRASS raster maps into GDAL supported formats.
r.out.gridatb Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL).
r.out.mat Exports a GRASS raster to a binary MAT-File.
r.out.mpeg Converts raster map series to MPEG movie.
r.out.png Export a GRASS raster map as a non-georeferenced PNG image.
r.out.pov Converts a raster map layer into a height-field file for POV-Ray.
r.out.ppm Converts a GRASS raster map to a PPM image file.
r.out.ppm3 Converts 3 GRASS raster layers (R,G,B) to a PPM image file.
r.out.vrml Exports a raster map to the Virtual Reality Modeling Language (VRML).
r.out.vtk Converts raster maps into the VTK-ASCII format.
r.out.xyz Exports a raster map to a text file as x,y,z values based on cell centers.
r.pack Exports a raster map as GRASS specific archive file
r.param.scale Extracts terrain parameters from a DEM. Uses a multi-scale approach by taking fitting quadratic parameters to any size window (via least squares).
r.patch Creates a composite raster map layer by using known category values from one (or more) map layer(s) to fill in areas of "no data" in another map layer.
r.path Traces paths from starting points following input directions.
r.plane Creates raster plane map given dip (inclination), aspect (azimuth) and one point.
r.profile Outputs the raster map layer values lying on user-defined line(s).
r.proj Re-projects a raster map from given project to the current project.
r.quant Produces the quantization file for a floating-point map.
r.quantile Compute quantiles using two passes.
r.random.cells Generates random cell values with spatial dependence.
r.random Creates randomly placed raster cells or vector points Creates a raster map and vector point map containing randomly located cells and points.
r.random.surface Generates random surface(s) with spatial dependence.
r.reclass.area Reclasses a raster map greater or less than user specified area size (in hectares).
r.reclass Reclassify raster map based on category values. Creates a new raster map whose category values are based upon a reclassification of the categories in an existing raster map.
r.recode Recodes categorical raster maps.
r.region Sets the boundary definitions for a raster map.
r.regression.line Calculates linear regression from two raster maps: y = a + b*x.
r.regression.multi Calculates multiple linear regression from raster maps.
r.relief Creates shaded relief map from an elevation map (DEM).
r.report Reports statistics for raster maps.
r.resamp.bspline Performs bilinear or bicubic spline interpolation with Tykhonov regularization.
r.resamp.filter Resamples raster map layers using an analytic kernel.
r.resamp.interp Resamples raster map to a finer grid using interpolation.
r.resamp.rst Reinterpolates and optionally computes topographic analysis from input raster map to a new raster map (possibly with different resolution) using regularized spline with tension and smoothing.
r.resamp.stats Resamples raster map layers to a coarser grid using aggregation.
r.resample GRASS raster map layer data resampling capability.
r.rescale.eq Rescales histogram equalized the range of category values in a raster map layer.
r.rescale Rescales the range of category values in a raster map layer.
r.rgb Splits a raster map into red, green and blue maps.
r.ros Generates rate of spread raster maps. Generates three, or four raster map layers showing the base (perpendicular) rate of spread (ROS), the maximum (forward) ROS, the direction of the maximum ROS, and optionally the maximum potential spotting distance for fire spread simulation.
r.semantic.label Manages semantic label information assigned to a single raster map or to a list of raster maps.
r.series.accumulate Makes each output cell value a accumulationfunction of the values assigned to the corresponding cells in the input raster map layers.
r.series.interp Interpolates raster maps located (temporal or spatial) in between input raster maps at specific sampling positions.
r.series Makes each output cell value a function of the values assigned to the corresponding cells in the input raster map layers.
r.shade Drapes a color raster over an shaded relief or aspect map.
r.sim.sediment Sediment transport and erosion/deposition simulation using path sampling method (SIMWE).
r.sim.water Overland flow hydrologic simulation using path sampling method (SIMWE).
r.slope.aspect Generates raster maps of slope, aspect, curvatures and partial derivatives from an elevation raster map. Aspect is calculated counterclockwise from east.
r.smooth.edgepreserve Smoothing with anisotropic diffusion
r.solute.transport Numerical calculation program for transient, confined and unconfined solute transport in two dimensions
r.spread Simulates elliptically anisotropic spread. Generates a raster map of the cumulative time of spread, given raster maps containing the rates of spread (ROS), the ROS directions and the spread origins. It optionally produces raster maps to contain backlink UTM coordinates for tracing spread paths. Usable for fire spread simulations.
r.spreadpath Recursively traces the least cost path backwards to cells from which the cumulative cost was determined.
r.statistics Calculates category or object oriented statistics.
r.stats Generates area statistics for raster map.
r.stats.quantile Compute category quantiles using two passes.
r.stats.zonal Calculates category or object oriented statistics (accumulator-based statistics).
r.stream.extract Performs stream network extraction.
r.sun Solar irradiance and irradiation model. Computes direct (beam), diffuse and reflected solar irradiation raster maps for given day, latitude, surface and atmospheric conditions. Solar parameters (e.g. sunrise, sunset times, declination, extraterrestrial irradiance, daylight length) are saved in the map history file. Alternatively, a local time can be specified to compute solar incidence angle and/or irradiance raster maps. The shadowing effect of the topography is optionally incorporated.
r.sunhours Calculates solar elevation, solar azimuth, and sun hours. Solar elevation: the angle between the direction of the geometric center of the sun's apparent disk and the (idealized) horizon. Solar azimuth: the angle from due north in clockwise direction.
r.sunmask Calculates cast shadow areas from sun position and elevation raster map. Either exact sun position (A) is specified, or date/time to calculate the sun position (B) by r.sunmask itself.
r.support Allows creation and/or modification of raster map layer support files.
r.support.stats Update raster map statistics
r.surf.area Prints estimation of surface area for raster map.
r.surf.contour Generates surface raster map from rasterized contours.
r.surf.fractal Creates a fractal surface of a given fractal dimension.
r.surf.gauss Generates a raster map using gaussian random number generator. Mean and standard deviation of gaussian deviates can be expressed by the user.
r.surf.idw Provides surface interpolation from raster point data by Inverse Distance Squared Weighting.
r.surf.random Produces a raster surface map of uniform random deviates with defined range.
r.terraflow Performs flow computation for massive grids.
r.texture Generate images with textural features from a raster map.
r.thin Thins non-null cells that denote linear features in a raster map layer.
r.tile Splits a raster map into tiles.
r.tileset Produces tilings of the source projection for use in the destination region and projection.
r.timestamp Modifies a timestamp for a raster map. Print/add/remove a timestamp for a raster map.
r.to.rast3 Converts 2D raster map slices to one 3D raster volume map.
r.to.rast3elev Creates a 3D volume map based on 2D elevation and value raster maps.
r.to.vect Converts a raster map into a vector map.
r.topidx Creates a topographic index (wetness index) raster map from an elevation raster map.
r.topmodel Simulates TOPMODEL which is a physically based hydrologic model.
r.transect Outputs raster map layer values lying along user defined transect line(s).
r.univar Calculates univariate statistics from the non-null cells of a raster map. Statistics include number of cells counted, minimum and maximum cell values, range, arithmetic mean, population variance, standard deviation, coefficient of variation, and sum.
r.unpack Imports a GRASS specific raster archive file (packed with r.pack) as a raster map
r.uslek Computes USLE Soil Erodibility Factor (K).
r.usler Computes USLE R factor, Rainfall erosivity index.
r.viewshed Computes the viewshed of a point on an elevation raster map. Default format: NULL (invisible), vertical angle wrt viewpoint (visible).
r.volume Calculates the volume of data "clumps". Optionally produces a GRASS vector points map containing the calculated centroids of these clumps.
r.walk Creates a raster map showing the anisotropic cumulative cost of moving between different geographic locations on an input raster map whose cell category values represent cost.
r.water.outlet Creates watershed basins from a drainage direction map.
r.watershed Calculates hydrological parameters and RUSLE factors.
r.what.color Queries colors for a raster map layer.
r.what Queries raster maps on their category values and category labels.
3D raster tools (r3.)
Name Description
r3.colors Creates/modifies the color table associated with a 3D raster map.
r3.colors.out Exports the color table associated with a 3D raster map.
r3.cross.rast Creates cross section 2D raster map from 3D raster map based on 2D elevation map
r3.flow Computes 3D flow lines and 3D flow accumulation.
r3.gradient Computes gradient of a 3D raster map and outputs gradient components as three 3D raster maps.
r3.gwflow Numerical calculation program for transient, confined groundwater flow in three dimensions.
r3.in.ascii Converts a 3D ASCII raster text file into a (binary) 3D raster map.
r3.in.bin Imports a binary raster file into a GRASS 3D raster map.
r3.in.v5d Import 3-dimensional Vis5D files.
r3.in.xyz Create a 3D raster map from an assemblage of many coordinates using univariate statistics
r3.info Outputs basic information about a user-specified 3D raster map layer.
r3.mapcalc Raster map calculator.
r3.mask Establishes the current working 3D raster mask.
r3.mkdspf Creates a display file from an existing 3D raster map according to specified threshold levels.
r3.neighbors Makes each voxel value a function of the values assigned to the voxels around it, and stores new voxel values in an output 3D raster map
r3.null Explicitly create the 3D NULL-value bitmap file.
r3.out.ascii Converts a 3D raster map layer into a ASCII text file.
r3.out.bin Exports a GRASS 3D raster map to a binary array.
r3.out.netcdf Export a 3D raster map as netCDF file.
r3.out.v5d Exports GRASS 3D raster map to 3-dimensional Vis5D file.
r3.out.vtk Converts 3D raster maps into the VTK-ASCII format.
r3.retile Retiles an existing 3D raster map with user defined x, y and z tile size.
r3.stats Generates volume statistics for 3D raster maps.
r3.support Allows creation and/or modification of 3D raster map layer support files.
r3.timestamp Modifies a timestamp for a 3D raster map. Print/add/remove a timestamp for a 3D raster map.
r3.to.rast Converts 3D raster maps to 2D raster maps
r3.univar Calculates univariate statistics from the non-null cells of a 3D raster map. Statistics include number of cells counted, minimum and maximum cell values, range, arithmetic mean, population variance, standard deviation, coefficient of variation, and sum.
Temporal tools (t.)
Name Description
t.connect Prints/sets general temporal GIS database connection for current mapset.
t.copy Creates a copy of a space time raster dataset.
t.create Creates a space time dataset.
t.info Lists information about space time datasets and maps.
t.list Lists space time datasets and maps registered in the temporal database.
t.merge Merges several space time datasets into a single space time dataset.
t.rast.accdetect Detects accumulation patterns in temporally accumulated space time raster datasets created by t.rast.accumulate.
t.rast.accumulate Computes cyclic accumulations of a space time raster dataset.
t.rast.aggregate.ds Aggregates data of an existing space time raster dataset using the time intervals of a second space time dataset.
t.rast.aggregate Aggregates temporally the maps of a space time raster dataset by a user defined granularity.
t.rast.algebra Apply temporal and spatial operations on space time raster datasets using temporal raster algebra.
t.rast.colors Creates/modifies the color table associated with each raster map of the space time raster dataset.
t.rast.contour Produces a space time vector dataset of specified contours from a space time raster dataset.
t.rast.export Exports space time raster dataset.
t.rast.extract Extracts a subset of a space time raster datasets.
t.rast.gapfill Replaces gaps in a space time raster dataset with interpolated raster maps.
t.rast.import Imports space time raster dataset.
t.rast.list Lists registered maps of a space time raster dataset.
t.rast.mapcalc Performs spatio-temporal mapcalc expressions on temporally sampled maps of space time raster datasets.
t.rast.neighbors Performs a neighborhood analysis for each map in a space time raster dataset.
t.rast.out.vtk Exports space time raster dataset as VTK time series.
t.rast.series Performs different aggregation algorithms from r.series on all or a subset of raster maps in a space time raster dataset.
t.rast.to.rast3 Converts a space time raster dataset into a 3D raster map.
t.rast.to.vect Converts a space time raster dataset into a space time vector dataset
t.rast.univar Calculates univariate statistics from the non-null cells for each registered raster map of a space time raster dataset.
t.rast.what Sample a space time raster dataset at specific vector point coordinates and write the output to stdout using different layouts
t.rast3d.algebra Apply temporal and spatial operations on space time 3D raster datasets using temporal 3D raster algebra.
t.rast3d.extract Extracts a subset of a space time 3D raster dataset.
t.rast3d.list Lists registered maps of a space time raster3d dataset.
t.rast3d.mapcalc Performs r3.mapcalc expressions on maps of sampled space time 3D raster datasets.
t.rast3d.univar Calculates univariate statistics from the non-null cells for each registered 3D raster map of a space time 3D raster dataset.
t.register Assigns timestamps and registers raster, vector and raster3d maps in a space time dataset.
t.remove Removes space time datasets from temporal database.
t.rename Renames a space time dataset
t.sample Samples the input space time dataset(s) with a sample space time dataset and print the result to stdout.
t.select Select maps from space time datasets by topological relationships to other space time datasets using temporal algebra.
t.shift Shifts temporally the maps of a space time dataset.
t.snap Snaps temporally the maps of a space time dataset.
t.support Modifies the metadata of a space time dataset.
t.topology Lists temporal topology of a space time dataset.
t.unregister Unregisters raster, vector and raster3d maps from the temporal database or a specific space time dataset.
t.upgrade Upgrades the version of the temporal database.
t.vect.algebra Apply temporal and spatial operations on space time vector datasets using temporal vector algebra.
t.vect.db.select Prints attributes of vector maps registered in a space time vector dataset.
t.vect.export Exports a space time vector dataset as GRASS specific archive file.
t.vect.extract Extracts a subset of a space time vector dataset.
t.vect.import Imports a space time vector dataset from a GRASS specific archive file.
t.vect.list Lists registered maps of a space time vector dataset.
t.vect.observe.strds Observes specific locations in a space time raster dataset over a period of time using vector points.
t.vect.univar Calculates univariate statistics of attributes for each registered vector map of a space time vector dataset
t.vect.what.strds Stores raster map values at spatial and temporal positions of vector points as vector attributes.
Vector tools (v.)
Name Description
v.buffer Creates a buffer around vector features of given type.
v.build.all Rebuilds topology on all vector maps in the current mapset.
v.build Creates topology for vector map. Optionally also checks for topological errors.
v.build.polylines Builds polylines from lines or boundaries.
v.category Attaches, deletes or reports vector categories to/from/of map geometry.
v.centroids Adds missing centroids to closed boundaries.
v.class Classifies attribute data, e.g. for thematic mapping
v.clean Toolset for cleaning topology of vector map.
v.clip Extracts features of input map which overlay features of clip map.
v.cluster Performs cluster identification.
v.colors Creates/modifies the color table associated with a vector map.
v.colors.out Exports the color table associated with a vector map.
v.db.addcolumn Adds one or more columns to the attribute table connected to a given vector map.
v.db.addtable Creates and connects a new attribute table to a given layer of an existing vector map.
v.db.connect Prints/sets DB connection for a vector map to attribute table.
v.db.dropcolumn Drops a column from the attribute table connected to a given vector map.
v.db.droprow Removes a vector feature from a vector map through attribute selection.
v.db.droptable Removes existing attribute table of a vector map.
v.db.join Joins a database table to a vector map table.
v.db.reconnect.all Reconnects attribute tables for all vector maps from the current mapset to a new database.
v.db.renamecolumn Renames a column in the attribute table connected to a given vector map.
v.db.select Prints vector map attributes.
v.db.univar Calculates univariate statistics on selected table column for a GRASS vector map.
v.db.update Updates a column in the attribute table connected to a vector map.
v.decimate Decimates a point cloud Copies points from one vector to another while applying different decimations
v.delaunay Creates a Delaunay triangulation from an input vector map containing points or centroids.
v.dissolve Dissolves adjacent or overlapping features sharing a common category number or attribute.
v.distance Finds the nearest element in vector map 'to' for elements in vector map 'from'.
v.drape Converts 2D vector features to 3D by sampling of elevation raster map.
v.edit Edits a vector map, allows adding, deleting and modifying selected vector features.
v.external Creates a new pseudo-vector map as a link to an OGR-supported layer or a PostGIS feature table.
v.external.out Defines vector output format.
v.extract Selects vector features from an existing vector map and creates a new vector map containing only the selected features.
v.extrude Extrudes flat vector features to 3D vector features with defined height. Optionally the height can be derived from sampling of elevation raster map.
v.fill.holes Fill holes in areas by keeping only outer boundaries
v.generalize Performs vector based generalization.
v.geometry Prints geometry metrics of vector features.
v.hull Produces a 2D/3D convex hull for a given vector map.
v.import Imports vector data into a GRASS vector map using OGR library and reprojects on the fly.
v.in.ascii Creates a vector map from an ASCII points file or ASCII vector file.
v.in.db Creates new vector (points) map from database table containing coordinates.
v.in.dxf Converts file in DXF format to GRASS vector map.
v.in.e00 Imports E00 file into a vector map.
v.in.geonames Imports geonames.org country files into a vector points map.
v.in.lines Imports ASCII x,y[,z] coordinates as a series of lines.
v.in.mapgen Imports Mapgen or Matlab-ASCII vector maps into GRASS.
v.in.ogr Imports vector data into a GRASS vector map using OGR library.
v.in.pdal Converts LAS LiDAR point clouds to a GRASS vector map with PDAL.
v.in.region Creates a vector polygon from the current region extent.
v.in.wfs Imports GetFeature from a WFS server.
v.info Outputs basic information about a vector map.
v.kcv Randomly partition points into test/train sets.
v.kernel Generates a raster density map from vector points map. Density is computed using a moving kernel. Optionally generates a vector density map on a vector network.
v.label Creates paint labels for a vector map from attached attributes.
v.label.sa Create optimally placed labels for vector map(s)
v.lidar.correction Corrects the v.lidar.growing output. It is the last of the three algorithms for LIDAR filtering.
v.lidar.edgedetection Detects the object's edges from a LIDAR data set.
v.lidar.growing Building contour determination and Region Growing algorithm for determining the building inside
v.lrs.create Creates a linear reference system.
v.lrs.label Creates stationing from input lines, and linear reference system.
v.lrs.segment Creates points/segments from input lines, linear reference system and positions read from stdin or a file.
v.lrs.where Finds line id and real km+offset for given points in vector map using linear reference system.
v.mkgrid Creates a vector map of a user-defined grid.
v.neighbors Neighborhood analysis tool for vector point maps. Makes each cell value a function of the attribute values assigned to the vector points or centroids in a radius around it, and stores new cell values in an output raster map.
v.net.alloc Allocates subnets for nearest centers. Center node must be opened (costs >= 0). Costs of center node are used in calculation.
v.net.allpairs Computes the shortest path between all pairs of nodes in the network.
v.net.bridge Computes bridges and articulation points in the network.
v.net.centrality Computes degree, centrality, betweenness, closeness and eigenvector centrality measures in the network.
v.net.components Computes strongly and weakly connected components in the network.
v.net.connectivity Computes vertex connectivity between two sets of nodes in the network.
v.net.distance Computes shortest distance via the network between the given sets of features. Finds the shortest paths from each 'from' point to the nearest 'to' feature and various information about this relation are uploaded to the attribute table.
v.net.flow Computes the maximum flow between two sets of nodes in the network.
v.net.iso Splits subnets for nearest centers by cost isolines. Splits net to bands between cost isolines (direction from center). Center node must be opened (costs >= 0). Costs of center node are used in calculation.
v.net Performs network maintenance.
v.net.path Finds shortest path on vector network.
v.net.salesman Creates a cycle connecting given nodes (Traveling salesman problem). Note that TSP is NP-hard, heuristic algorithm is used by this module and created cycle may be sub optimal
v.net.spanningtree Computes minimum spanning tree for the network.
v.net.steiner Creates Steiner tree for the network and given terminals. Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm is used in this module so the result may be sub optimal.
v.net.timetable Finds shortest path using timetables.
v.net.visibility Performs visibility graph construction.
v.normal Tests for normality for vector points.
v.out.ascii Exports a vector map to a GRASS ASCII vector representation. By default only features with category are exported. To export all features use 'layer=-1'.
v.out.dxf Exports vector map to DXF file format.
v.out.ogr Exports a vector map layer to any of the supported OGR vector formats. By default a vector map layer is exported to OGC GeoPackage format.
v.out.postgis Exports a vector map layer to PostGIS feature table.
v.out.pov Converts GRASS x,y,z points to POV-Ray x,z,y format.
v.out.svg Exports a vector map to SVG file.
v.out.vtk Converts a vector map to VTK ASCII output.
v.outlier Removes outliers from vector point data.
v.overlay Overlays two vector maps offering clip, intersection, difference, symmetrical difference, union operators.
v.pack Exports a vector map as GRASS specific archive file
v.parallel Creates parallel line to input vector lines.
v.patch Creates a new vector map by combining other vector maps.
v.perturb Random location perturbations of vector points.
v.ppa Point pattern analysis using the G, F, K, and L summary functions.
v.profile Vector map profiling tool
v.proj Re-projects a vector map from one project to the current project.
v.qcount Indices for quadrat counts of vector point lists.
v.random Generates random 2D/3D vector points.
v.rast.stats Calculates univariate statistics from a raster map based on a vector map and uploads statistics to new attribute columns.
v.reclass Changes vector category values for an existing vector map according to results of SQL queries or a value in attribute table column.
v.rectify Rectifies a vector by computing a coordinate transformation for each object in the vector based on the control points.
v.report Reports geometry statistics for vector maps.
v.sample Samples a raster map at vector point locations.
v.segment Creates points/segments from input vector lines and positions.
v.select Selects features from vector map (A) by features from other vector map (B).
v.split Splits vector lines to shorter segments.
v.support Updates vector map metadata.
v.surf.bspline Performs bicubic or bilinear spline interpolation with Tykhonov regularization.
v.surf.idw Provides surface interpolation from vector point data by Inverse Distance Squared Weighting.
v.surf.rst Performs surface interpolation from vector points map by splines. Spatial approximation and topographic analysis from given point or isoline data in vector format to floating point raster format using regularized spline with tension.
v.timestamp Modifies a timestamp for a vector map. Print/add/remove a timestamp for a vector map.
v.to.3d Performs transformation of 2D vector features to 3D.
v.to.db Populates attribute values from vector features.
v.to.lines Converts vector polygons or points to lines.
v.to.points Creates points along input lines in new vector map with 2 layers.
v.to.rast Converts (rasterize) a vector map into a raster map.
v.to.rast3 Converts a vector map (only points) into a 3D raster map.
v.transform Performs an affine transformation (shift, scale and rotate) on vector map.
v.type Changes type of vector features.
v.univar Calculates univariate statistics of vector map features. Variance and standard deviation is calculated only for points if specified.
v.unpack Imports a GRASS specific vector archive file (packed with v.pack) as a vector map
v.vect.stats Count points in areas, calculate statistics from point attributes.
v.vol.rst Interpolates point data to a 3D raster map using regularized spline with tension (RST) algorithm.
v.voronoi Creates a Voronoi diagram constrained to the extents of the current region from an input vector map containing points or centroids.
v.what Queries a vector map at given locations.
v.what.rast Uploads raster values at positions of vector points to the table.
v.what.rast3 Uploads 3D raster values at positions of vector points to the table.
v.what.strds Uploads space time raster dataset values at positions of vector points to the table.
v.what.vect Uploads vector values at positions of vector points to the table.
