Skip to content
Python introduction
GRASS Python interface provides libraries to use GRASS tools, create scripts, and access the GRASS data structures. The Python interface consists of three main libraries: grass.tools provides a Python interface to GRASS tools, grass.script handles GRASS projects and sessions in Python, and grass.pygrass enables a fine-grained access to the GRASS data structures.
Scripting
Setup
To get started with scripting, you must first append the GRASS Python path to the system path and then import the grass.script library and Tools from the grass.tools library. (On some systems, you may skip the path append step.) From here, you can create a new project with gs.create_project and start a GRASS session with the grass.script.setup.init function.
import sys
import subprocess
# Append GRASS to the python system path
sys.path.append(
    subprocess.check_output(["grass", "--config", "python_path"], text=True).strip()
import grass.script as gs
from grass.tools import Tools
# Create a new project
gs.create_project(path="path/to/my_project", epsg="3358")
# Initialize the GRASS session
with gs.setup.init("path/to/my_project") as session:
    # Run GRASS tools
    tools = Tools(session=session)
    tools.r_import(input="/path/to/elevation.tif", output="elevation")
    tools.g_region(raster="elevation")
    tools.r_slope_aspect(elevation="elevation", slope="slope")
If you are running a script in an already initialized GRASS session, you can run the tools right away (without the call to init):
# Run GRASS tools
tools = Tools()
Running tools
Tools can be accessed through a grass.tools.Tools object from grass.tools which is created either within an active GRASS session or with a session passed as a parameter (see above). Here, we create the Tools object assuming an active session:
tools = Tools()
Tools can be accessed as methods of the Tools object. The method names use underscores (snakecase) instead of dots (periods). For example, when computing raster slope with r.slope.aspect, we call the r_slope_aspect method:
Above, we used a GRASS tool which creates geospatial data in the current GRASS project, so we didn't do anything with the returned result in Python. Many tools produce machine-readable text output, typically JSON, which can be then used in Python. For example, to get vector attribute data, we use JSON output of v.db.select:
data = tools.v_db_select(map="hospitals", format="json")
To send data to a GRASS tool through the standard input, a StringIO object from the standard package io can be in place of a filename. For example, when writing a custom color scheme to a raster map with r.colors:
from io import StringIO
color_scheme = """
20% #ffffd4
40% #fed98e
60% #fe9929
80% #d95f0e
100% #993404
tools.r_colors(map="elevation", rules=StringIO(color_scheme))
The methods will raise CalledModuleError if a tool fails. For customization of error handling, please refer to the documentation.
Overwriting data
By default, GRASS prevents overwriting existing maps to protect your data, so you need to explicitly allow overwriting when re-running analyses or generating outputs with the same name. For a single call, use the overwrite parameter:
tools.r_slope_aspect(elevation="elevation", slope="slope", overwrite=True)
For multiple tool calls, set the overwrite parameter of Tools:
tools = Tools(overwrite=True)
See related best practices when writing a Python tool.
Pick your way to tools
The API of grass.tools is recommended for new code, but not considered stable in version 8.5. Although no major changes for grass.tools are expected, if you require completely stable API, consider instead other ways of accessing tools. If you want to migrate to grass.tools, check the migration guide.
Available tools and their parameters are listed in the tool documentation:
Documentation of tools
Accessing returned values
The object returned by a tool run provides several ways of accessing the result when a tool returns information as a text (as opposed to creating geospatial data in GRASS project or as files).
The most common output format is JSON. The result object allows you to access the parsed JSON structure without explicitly processing the returned JSON data. You only need to ask the tool to produce JSON, typically with format="json", for example:
tools = Tools()
# Get number of points in a vector map.
# A single value can be accessed directly without storing it.
num_points = tools.v_info(map="hospitals", format="json")["points"]
# Get region resolution to get cell size (assuming projected CRS).
# Result of a tool can be stored and access multiple times.
region = tools.g_region(flags="p", format="json")
cell_area = region["nsres"] * region["ewres"]
We can use additional attributes of the tool run result to get other output than JSON. For example, to get human-readable output of g.region as is, we can use the text attribute:
print(tools.g_region(flags="p").text)
The documentation of grass.tools.support.ToolResult provides an overview of all the attributes and text processing functions, such as text_split function and comma_items attribute.
NumPy interface
The grass.tools API allows tools to accept and output NumPy arrays instead of rasters. Although using GRASS native rasters is faster, NumPy arrays allow for easy integration with other tools in the Python scientific stack for advanced analysis and custom modeling. Additional APIs are available to switch between GRASS raster maps and NumPy arrays, run GRASS tools, and perform array-based operations.
This example shows a workflow which starts with a NumPy array, runs a GRASS tool, and finishes again with a NumPy array:
import numpy as np
# Create a 100x100 sinusoidal elevation surface
xx, yy = np.meshgrid(np.linspace(0, 1, 100), np.linspace(0, 1, 100))
elevation = np.sin(xx) + np.cos(yy)
# Set the region to match the array dimensions and resolution
tools = Tools()
tools.g_region(n=elevation.shape[0], s=0, e=elevation.shape[1], w=0, res=1)
# Use the NumPy array with a GRASS tool to compute, e.g., flow accumulation,
# and get the result as a new NumPy array.
accumulation = tools.r_watershed(elevation=elevation, accumulation=np.array)
Additional APIs, grass.script.array and grass.script.array3d, provide you with full control over read and writing data between GRASS raster maps and NumPy arrays, including 3D raster maps. The following example demonstrates reading an existing GRASS raster into a NumPy array, plotting the data, modifying the array, and writing the modified array back to a GRASS raster:
import numpy as np
import seaborn as sns
import matplotlib.pyplot as plt
import grass.script.array as ga
# Set computational region to match the whole raster
tools = Tools()
# Read elevation as a NumPy array
elevation = ga.array(mapname="elevation")
# Plot raster histogram
sns.histplot(data=elevation.ravel(), kde=True)
plt.show()
# Modify values
elevation *= 2
# Write modified array into a GRASS raster
elevation.write(mapname="elevation_2")
Finally, this example shows a workflow for creating a NumPy array from scratch and writing it as a GRASS raster:
import numpy as np
# Create a 2x3 constant raster with value 10
x = np.full((2, 3), 10)
tools = Tools()
tools.g_region(n=x.shape[0], s=0, e=x.shape[1], w=0, res=1)
# Write the NumPy array to a new GRASS raster map
map2d = ga.array()
map2d[:] = x
map2d.write("x")  # add overwrite=True for repeated runs
Fine-grained data handling
PyGRASS is an object-oriented Python library that provides access to the internal data structures of GRASS for more advanced scripting and modeling. PyGRASS works directly with the C libraries of GRASS and providing a Pythonic interface. The core packages of grass.pygrass include:
Topic Documentation Link
Project and Region Management grass.pygrass.gis
Raster Data Access grass.pygrass.raster
Vector Data Access grass.pygrass.vector
For a complete reference of the PyGRASS library, see the full documentation:
Full Documentation
Project Management
The grass.pygrass.gis module provides access to the project and region management of GRASS. The grass.pygrass.gis module provides functions to create, manage, and delete GRASS projects and mapsets. The core classes include Gisdbase, Location, and Mapset.
The Gisdbase class provides access to the GRASS database and where you can manage GRASS projects and mapsets.
For example, to list all projects in your GRASS database directory you can use:
from grass.pygrass import gis
grassdata = gis.Gisdbase()
projects = grassdata.locations()
print(projects)
This will return a list of all projects in the GRASS database directory as Location objects.
['nc_spm_08_grass7', 'my_project']
The Location object provides access to the specific project and its mapsets.
from grass.pygrass.gis import Location
location = Location()
# Get the name of the location
print(location.name)
# Get list of mapsets in the location
mapsets = location.mapsets()
The Mapset object provides access to the specific mapset and its layers.
from grass.pygrass.gis import Mapset
# Get the current mapset
mapset = Mapset()
# List all rasters in the mapset
rasters = mapset.glist(type="raster")
For more details about the gis module, see the Full Documentation: GIS Module
Region
The grass.pygrass.gis.region module gives access to read and modify computational regions. For example, to get the current extent and resolution of the active mapset:
from grass.pygrass.gis.region import Region
region = Region()
extent = region.get_bbox()
resolution = [region.nsres, region.ewres]
print(f"""
Extent: {extent}
Resolution: {resolution}
Extent: Bbox(228500.0, 215000.0, 645000.0, 630000.0)
Resolution: [10.0, 10.0]
To set the computational region you can adjust the current Region with the adjust method or set it to a specific map to a specific map with from_rast or from_vect methods.:
region = Region()
# Set the region from the elevation raster
region.from_rast("elevation")
# Adjust the region by adding 100 map units
# to the east and north
region.east += 100
region.north += 100
# Apply the changes
region.adjust()
# Lets compare the new region
print(f"""
Extent: {extent}
Here we can see that the region has been adjusted by 100 map units to the east and north while the spatial resolution remains the same.
Extent: Bbox(228600.0, 215000.0, 645100.0, 630000.0)
For more details about the region module, see the Full Documentation:
Full Documentation
Data Management
Raster
Do you have an idea that requires more advanced raster processing? PyGRASS provides direct read and write access to raster data with the grass.pygrass.raster module. The core classes include RasterRow, RasterRowIO, and RasterSegment. Each class provides a different level of access to the raster data with its own set of read and write capabilities, as shown in the table below.
Class Description Read Write
RasterRow Read write access to raster row data. 🐇 Random 🐇 Sequential
RasterRowIO Fast read only access to raster row data. 🐇 Cached ❌ No
RasterSegment Simultaneous read write access to tiled raster segments stored on disk. 🐢 Cached 🐢 Random
The RasterRow class allows for either read or write access to raster row data and provides methods to access raster state and metadata. To read all rows of the elevation raster:
from grass.pygrass import raster
with raster.RasterRow("elevation") as elev:
    # Get the total number of rows
    nrows = elev.info.rows
    print(f"Total Rows: {nrows}")
    for row in elev:
        print(row)
For practice, let's read a value from a row and column in the elevation raster, double it, and write the value back to a new raster elevation_new.
# Open the elevation raster in read mode
    # Read a random row and column
    value = elev[5][10]
    # Open the new elevation raster in write mode
    with raster.RasterRow("elevation_new", mode="w", mtype="FCELL") as new_elev:
        # Sequentially iterate over the rows and columns
        for row_id, row in enumerate(elev, start=0):
            # When we reach the row and column we want to change
            if row_id == 5:
                # Set the value
                row[10] = value * 2
            # Write the rows to the new raster
            new_elev.put_row(row)
RasterSegment
The RasterSegment class provides simultaneous read and write access to tiled raster segments stored on disk. This class is useful for working with large raster datasets that do not fit into memory.
For more details about the raster module, see the Full Documentation:
Full Documentation
Vector
The grass.pygrass.vector module provides direct read and write access to vector data in GRASS. The core classes include Vector and VectorTopo.
Class Description
Vector Provides basic information about vector data.
VectorTopo Read and write access to vector data.
Here is a simple example with Vector to check if a vector map exists and print the mapset it is in.
from grass.pygrass.vector import Vector
# Check if the roads vector map exists
roads = Vector("roadsmajor")
if roads.exist():
    mapset = roads.mapset
    print(f"The roads vector map exists in the {mapset} mapset")
With the VectorTopo class you can get the same basic information about the vector map returned by the Vector class in addition to read and write access.
from grass.pygrass.vector import VectorTopo
# Open the roads vector map as a VectorTopo object
with VectorTopo("roadsmajor") as roads:
    # Get the first feature
    first_feature = roads.next()
    print(first_feature)
    # Get the number of nodes
    roads.number_of("nodes")
Geometry and Attributes
In GRASS vector geometry and attributes are treated separately. This means that the attributes of a vector are not automatically read when the geometry is read.
To build a geometry object, you can use the geometry class in the grass.pygrass.vector.geometry module.
Geometry Class Description
Area Represents the topological composition of a closed ring of boundaries and a centroid.
Boundary Represents the border line to describe an area.
Centroid Represents a centroid feature in a vector map.
Isle Represents an isle feature in a vector map.
Line Represents a line feature in a vector map.
Point Represents a point feature in a vector map.
Each geometry class has its own set of methods to help extract useful information. For example, let's build a Boundary object from a list of points and calculate the area of the boundary.
from grass.pygrass.vector.geometry import Boundary
# Create a new boundary object
border = Boundary(points=[(0, 0), (0, 2), (2, 2), (2, 0), (0, 0)])
# Get the area of the boundary
area = border.area
To access the attributes of a vector map, you can use the attrs attribute of the VectorTopo object. The attrs attribute is a dictionary that contains the attributes of the current feature.
# Open the roads vector map in read mode
    # Read attribute the first feature
    read_feature = roads.read(1)
    # Prints the LINESTRING geometry
    print(read_feature)
    # Prints a dictionary of the attributes
    print(dict(read_feature.attrs))
To write a new feature to the roads vector map with attributes we need to access the database of the vector map with the VectorTopo.
Here is an example of how to write a new feature to the roads vector map.
from grass.pygrass.vector.geometry import Line
with VectorTopo("roadsmajor", mode="rw") as roads:
    # Create a new feature
    # The tuple is shorthand for a list of Point(x, y)
    new_geom = Line([(636981.33, 256517.60), (636983.10, 256526.59)])
    # Get the last cat value (primary key)
    last_record = roads.read(-1)
    last_cat = last_record.cat
    # Create an empty feature from the last record
    new_dict = {key: None for key in last_record.attrs}
    new_dict["cat"] = last_cat + 1
    new_dict["MAJORRDS_"] = 2.0
    new_dict["ROAD_NAME"] = "New Road"
    new_dict["MULTILINE"] = "No"
    new_dict["PROPYEAR"] = 2025
    # Write the new feature to the vector map
    roads.write(new_geom, new_dict)
    # Write the attributes to the database
    roads.table.conn.commit()
    # Build the topology
    roads.build()
Features can also be updated by using the rewrite method instead of the write. If the geometry of the feature has not changed, you can save the attributes to the database table without rebuilding the topology using table.conn.commit.
Querying Vector Data
You can also query the vector map for specific features using the where method. For example, to get all features where the ROAD_NAME attribute is NC-50 and the line segment length is greater than 1000.
    # Iterate over each feature in the vector map
    for feature in roads.viter("lines"):
        # Check if the feature is a line and the length is greater than 1000
        # And the ROAD_NAME attribute is 'NC-50'
        if feature.length() > 1000 and feature.attrs["ROAD_NAME"] == "NC-50":
            print(feature)
You can also use many of Geometry and Attribute methods to filter features in a more concise way.
For example, to test if a random point is within 5000 meters of a road segment you can use the distance method of the Line geometry object. The distance method returns a LineDist object that contains the distance and the closest point on the line.
import random
from grass.pygrass.vector.geometry import Point
    # Get the extent of the roads vector map
    extent = roads.bbox()
    # Create a random point within the extent
    x = random.uniform(extent.west, extent.east)
    y = random.uniform(extent.south, extent.north)
    random_point = Point(x, y)
        # Check if the random point is within a 5000 meters of the line
        line_distance = feature.distance(random_point)
        if line_distance.dist < 5000:
            print(f"""
                The random point {random_point} is within 5000 m
                of the road segment: {feature.cat}
Or to simply filter a table using SQL you can use the where method with table_to_dict to get a dictionary of the features that match the query, the table.Filter class for more advanced operations.
roads = VectorTopo("roadsmajor")
roads.open("r")
# Query the vector map for all features where the
# ROAD_NAME attribute is 'NC-50'
roads.table_to_dict(where="ROAD_NAME = 'NC-50'")
sql_1 = roads.table.filters.get_sql()
# Query the vector map for the first 5 features where the
# ROAD_NAME attribute is 'NC-70'
roads.table.filters.where("ROAD_NAME = 'NC-70'").limit(5)
sql_2 = roads.table.filters.get_sql()
# Close the vector map
roads.close()
The values of the sql_1 and sql_2 variable will be the SQL query that was used to filter the features.
-- Value of sql_1
SELECT * FROM roadsmajor WHERE ROAD_NAME = 'NC-50' ORDER BY cat;
-- Value of sql_2
SELECT * FROM roadsmajor WHERE ROAD_NAME = 'NC-70' ORDER BY cat LIMIT 5;
Used Different SQL Database
The default database for GRASS is SQLite, but you can use other SQL databases like PostgreSQL with the driver option in the VectorTopo object.
For more details about the vector module, see the Full Documentation:
Full Documentation
Additional ways to access tools
Besides grass.tools, there are two other way of accessing GRASS tools: run_command group of functions from grass.script and grass.pygrass.modules.
Shell-like tool calling
The grass.script package provides a set of tool-calling functions which follow text input and output handling use cases from a command-line shell perspective. Four main functions are: gs.run_command, gs.parse_command, gs.read_command, and gs.write_command.
The gs.run_command function is used to run a GRASS tool when you require no return value. For example, when computing raster slope with r.slope.aspect:
gs.run_command("r.slope.aspect", elevation="elevation", slope="slope")
The gs.parse_command function is useful when the tool returns machine-readable text output on the standard output. For example, use it to parse the output of v.db.select to represent attribute data in a Python dictionary:
data = gs.parse_command("v.db.select", map="hospitals", format="json")
The gs.read_command function returns the text output of a GRASS tool. This can be useful when you want to print human-readable output of a tool. For example, when reading the output of g.region:
print(gs.read_command("g.region", flags="p"))
The gs.write_command function is used to send data to a GRASS tool through the standard input. For example, when writing a custom color scheme to a raster map with r.colors:
color_scheme = """
20% #ffffd4
40% #fed98e
60% #fe9929
80% #d95f0e
100% #993404
gs.write_command(
    "r.colors",
    map="elevation",
    rules="-",  # Read from stdin
    stdin=color_scheme,
Tools as objects
The grass.pygrass.modules module provides access to the GRASS tools (also called modules). The Module class provides a Pythonic interface to the GRASS modules and tools.
Here we use the Module class to create an Module object of the r.slope.aspect tool.
from grass.pygrass.modules import Module
slope_aspect_tool = Module(
    "r.slope.aspect", elevation="elevation", slope="slope", aspect="aspect"
The Module object provides a run method to execute the GRASS tool.
slope_aspect_tool.run()
but you can also execute the tool with the () operator.
slope_aspect_tool()
The Module object also provides a the access to the tool attributes such as the name, description, keywords, and inputs.
slope_aspect_tool.name
slope_aspect_tool.description
slope_aspect_tool.keywords
slope_aspect_tool.inputs
The grass.pygrass.modules module provides an alternative approach to running GRASS tools.
To learn more about the Module class, see the Full Documentation:
Full Documentation
GRASS Python best practices
When you are ready to take your scripts to the next level, such as turning them into GRASS addons, check out GRASS Python development best practices. Following the gudelines ensures your tools integrate smoothly with the GRASS environment, and work in parallel processing workflows. To turn your script into an addon, see the GRASS Addon Cookiecutter Template.
SOURCE CODE
Available at: python_intro source code (history)
Latest change: Thursday Nov 19 12:05:09 2026 in commit cb5bcdb
