Skip to content
i.ann.maskrcnn.train
Train your Mask R-CNN network
i.ann.maskrcnn.train [-esbn] training_dataset=name [model=name] classes=string [,string,...] logs=name name=string [epochs=integer] [steps_per_epoch=integer] [rois_per_image=integer] [images_per_gpu=integer] [gpu_count=integer] [mini_mask_size=integer [,integer,...]] [validation_steps=integer] [images_min_dim=integer] [images_max_dim=integer] [backbone=string] [--verbose] [--quiet] [--qq] [--ui]
Example:
sh i.ann.maskrcnn.train training_dataset=name classes=string logs=name name=string
grass.script.run_command("i.ann.maskrcnn.train", training_dataset, model=None, classes, logs, name, epochs=200, steps_per_epoch=3000, rois_per_image=64, images_per_gpu=1, gpu_count=1, mini_mask_size=None, validation_steps=100, images_min_dim=256, images_max_dim=1280, backbone="resnet101", flags=None, verbose=None, quiet=None, superquiet=None)
Example:
python gs.run_command("i.ann.maskrcnn.train", training_dataset="name", classes="string", logs="name", name="string")
grass.tools.Tools.i_ann_maskrcnn_train(training_dataset, model=None, classes, logs, name, epochs=200, steps_per_epoch=3000, rois_per_image=64, images_per_gpu=1, gpu_count=1, mini_mask_size=None, validation_steps=100, images_min_dim=256, images_max_dim=1280, backbone="resnet101", flags=None, verbose=None, quiet=None, superquiet=None)
Example:
python tools = Tools() tools.i_ann_maskrcnn_train(training_dataset="name", classes="string", logs="name", name="string")
Parameters
training_dataset=name [required]
    Path to the dataset with images and masks
    Name of input directory
model=name
    Path to the .h5 file to use as initial values
    Keep empty to train from a scratch
classes=string [,string,...] [required]
    Names of classes separated with ","
logs=name [required]
    Path to the directory in which will be models saved
name=string [required]
    Name for output models
epochs=integer
    Number of epochs
    Default: 200
    Steps per each epoch
    Default: 3000
    How many ROIs train per image
    Default: 64
    Number of images per GPU
    Bigger number means faster training but needs a bigger GPU
    Default: 1
gpu_count=integer
    Number of GPUs to be used
    Default: 1
    Size of mini mask separated with ","
    To use full sized masks, keep empty. Mini mask saves memory at the expense of precision
    Number of validation steps
    Bigger number means more accurate estimation of the model precision
    Default: 100
    Minimum length of images sides
    Images will be resized to have their shortest side at least of this value (has to be a multiple of 64)
    Default: 256
    Maximum length of images sides
    Images will be resized to have their longest side of this value (has to be a multiple of 64)
    Default: 1280
backbone=string
    Backbone architecture
    Allowed values: resnet50, resnet101
    Default: resnet101
-e
    Pretrained weights were trained on another classes / resolution / sizes
-s
    Do not use 10 % of images and save their list to logs dir
-b
    Train also batch normalization layers (not recommended for small batches)
-n
    No resizing or padding of images (images must be of the same size)
--help
    Print usage summary
--verbose
    Verbose module output
--quiet
    Quiet module output
--qq
    Very quiet module output
--ui
    Force launching GUI dialog
training_dataset : str, required
    Used as: input, dir, name
model : str, optional
    Used as: input, file, name
classes : str | list[str], required
logs : str, required
epochs : int, optional
    Number of epochs
    Default: 200
steps_per_epoch : int, optional
    Default: 3000
rois_per_image : int, optional
    Default: 64
images_per_gpu : int, optional
    Default: 1
gpu_count : int, optional
    Default: 1
mini_mask_size : int | list[int] | str, optional
validation_steps : int, optional
    Default: 100
images_min_dim : int, optional
    Default: 256
images_max_dim : int, optional
    Default: 1280
backbone : str, optional
    Default: resnet101
flags : str, optional
    Allowed values: e, s, b, n
    e
    s
    b
    n
verbose : bool, optional
    Default: None
quiet : bool, optional
    Quiet module output
    Default: None
superquiet : bool, optional
    Default: None
model : str | io.StringIO, optional
    Number of epochs
    Default: 200
    Default: 3000
    Default: 64
    Default: 1
    Default: 1
    Default: 100
    Default: 256
    Default: 1280
    Default: resnet101
    e
    s
    b
    n
    Default: None
    Quiet module output
    Default: None
    Default: None
Returns:
Raises:
DESCRIPTION
i.ann.maskrcnn.train allows the user to train a Mask R-CNN model on his own dataset. The dataset has to be prepared in a predefined structure.
DATASET STRUCTURE
Training dataset should be in the following structure:
dataset-directory
  • imagenumber
  • imagenumber.jpg (training image)
  • imagenumber-class1-number.png (mask for one instance of class1)
  • imagenumber-class1-number.png (mask for another instance of class1)
  • imagenumber2
  • imagenumber2-class1-number.png (mask for one instance of class1)
  • imagenumber2-class2-number.png (mask for another class instance)
The described structure of directories is required. Pictures must be *.jpg files with 3 channels (for example RGB), masks must be *.png files consisting of numbers between 1 and 255 (object instance) and 0s (elsewhere). A mask file for each instance of an object should be provided separately distinguished by the suffix number.
NOTES
If you are using initial weights (the model parameter), epochs are divided into three segments. Firstly training layers 5+, then fine-tuning layers 4+ and the last segment is fine-tuning the whole architecture. Ending number of epochs is shown for your segment, not for the whole training.
The usage of the -b flag will result in an activation of batch normalization layers training. By default, this option is set to False, as it is not recommended to train them when using just small batches (batch is defined by the images_per_gpu parameter).
If the dataset consists of images of the same size, the user may use the -n flag to avoid resizing or padding of images. When the flag is not used, images are resized to have their longer side equal to the value of the images_max_dim parameter and the shorter side longer or equal to the value of the images_min_dim parameter and zero-padded to be of shape
images_max_dim x images_max_dim
. It results in the fact that even images of different sizes may be used.
After each epoch, the current model is saved. It allows the user to stop the training when he feels satisfied with loss functions. It also allows the user to test models even during the training (and, again, stop it even before the last epoch).
EXAMPLES
Dataset for examples:
crops
  • 000000
  • 000001
Training from scratch
sh i.ann.maskrcnn.train training_dataset=/home/user/Documents/crops classes=corn,rice logs=/home/user/Documents/logs name=crops
After default number of epochs, we will get a model where the first class is trained to detect corn fields and the second one to detect rice fields.
If we use the command with reversed classes order, we will get a model where the first class is trained to detect rice fields and the second one to detect corn fields.
sh i.ann.maskrcnn.train training_dataset=/home/user/Documents/crops classes=rice,corn logs=/home/user/Documents/logs name=crops
The name of the model does not have to be the same as the dataset folder but should be referring to the task of the dataset. A good name for this one (referring also to the order of classes) could be also this one:
sh i.ann.maskrcnn.train training_dataset=/home/user/Documents/crops classes=rice,corn logs=/home/user/Documents/logs name=rice_corn
Training from a pretrained model
We can use a pretrained model to make our training faster. It is necessary for the model to be trained on the same channels and similar features, but it does not have to be the same ones (e.g. model trained on swimming pools in maps can be used for a training on buildings in maps).
A model trained on different classes (use -e flag to exclude head weights).
sh i.ann.maskrcnn.train training_dataset=/home/user/Documents/crops classes=corn,rice logs=/home/user/Documents/logs name=crops model=/home/user/Documents/models/buildings.h5 -e
A model trained on the same classes.
sh i.ann.maskrcnn.train training_dataset=/home/user/Documents/crops classes=corn,rice logs=/home/user/Documents/logs name=crops model=/home/user/Documents/models/corn_rice.h5
Fine-tuning a model
It is also possible to stop your training and then continue. To continue in the training, just use the last saved epoch as a pretrained model.
sh i.ann.maskrcnn.train training_dataset=/home/user/Documents/crops classes=corn,rice logs=/home/user/Documents/logs name=crops model=/home/user/Documents/models/mask_rcnn_crops_0005.h5
SEE ALSO
Mask R-CNN in GRASS GIS, i.ann.maskrcnn.detect
AUTHOR
Ondrej Pesek
SOURCE CODE
Available at: i.ann.maskrcnn.train source code (history)
Latest change: Thursday Mar 05 14:47:35 2026 in commit 4c42dd0
