r.colors.out_sld
Exports the color table associated with a raster map layer in SLD format.
r.colors.out_sld [-n] map=name [style_name=string] [output=name] [--overwrite] [--verbose] [--quiet] [--qq] [--ui]
Example:
sh
r.colors.out_sld map=name
grass.script.run_command("r.colors.out_sld", map, style_name="GRASS GIS color table", output="-", flags=None, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
python
gs.run_command("r.colors.out_sld", map="name")
grass.tools.Tools.r_colors_out_sld(map, style_name="GRASS GIS color table", output="-", flags=None, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
python
tools = Tools()
tools.r_colors_out_sld(map="name")
Parameters
map=name [required]
Name of raster map
style_name=string
Name for style
A name for the style which might be displayed on the server
Default: GRASS GIS color table
output=name
Name for output SLD rules file
"-" to write to stdout
Default: -
-n
Propagate NULLs
--overwrite
--help
Print usage summary
--verbose
Verbose module output
--quiet
Quiet module output
--qq
Very quiet module output
--ui
Force launching GUI dialog
map : str, required
Name of raster map
Used as: input, raster, name
style_name : str, optional
Name for style
output : str, optional
Used as: output, file, name
Default: -
flags : str, optional
Allowed values: n
n
Propagate NULLs
overwrite : bool, optional
Default: None
verbose : bool, optional
Default: None
quiet : bool, optional
Quiet module output
Default: None
superquiet : bool, optional
Default: None
map : str | np.ndarray, required
Name of raster map
Name for style
Default: -
Allowed values: n
n
Propagate NULLs
Default: None
Default: None
Quiet module output
Default: None
Default: None
Returns:
Raises:
DESCRIPTION
The module r.colors.out_sld exports the colors of a raster map into the Styled Layer Description (SLD) format according to OGC standard.
For raster maps of type CELL also labels are exported. The export of labels requires that the input map is entirely read and may thus take a bit longer than the export of continuous color rules (ramp).
Only if the flag n is given, the NaN values are written into the generated SLD file which leads e.g. in GeoServer to an error when using such SLD.
Currently only SLD v1.0.0 is implemented.
EXAMPLES
```sh
Exporting a color ramp
r.colors.out_sld map=testmap style_name=Celsius ```
SEE ALSO
REFERENCES
https://www.ogc.org/standard/sld
AUTHORS
Hamish Bowman
Stefan Blumentrath, Norwegian Institute for Nature Research, Oslo,
Norway
SOURCE CODE
Available at: r.colors.out_sld source code
(history)
Latest change: Wednesday Mar 11 08:17:30 2026 in commit 2a14bbb
