Skip to content
r.green.biomassfor.impact
Calculates impact and multifunctionality values
r.green.biomassfor.impact [-r] forest=name boundaries=name forest_column_yield=string forest_column_yield_surface=string forest_column_management=string forest_column_treatment=string forest_roads=name [forest_column_roughness=string] [rivers=name] [lakes=name] [energy_tops_hf=float] [energy_cormometric_vol_hf=float] [energy_tops_cop=float] energy_map=name dhp=name [output_sw_map=name] [dtm=name] [soiltx_map=name] [soild_map=name] [soilcmp_map=name] output_basename_co2map=name output_basename_aco2map=name output_basename_nco2map=name [dtm2=name] [forest_column_roughness=string] [soilp2_map=name] [tree_diam=name] [tree_vol=name] [main_roads=name] [slp_min_cc=float] [slp_max_cc=float] [dist_max_cc=float] [slp_max_fw=float] [dist_max_fw=float] [slp_max_cop=float] [dist_max_cop=float] [output_fr_map=name] [firerisk_map=name] [output_tot_re_map=name] [output_imp_re_map=name] [touristic_map=name] [tev=name] [field_tev=name] [area_tev=name] [output_tev=name] [expl=name] [impact=float] [base=name] [--overwrite] [--verbose] [--quiet] [--qq] [--ui]
Example:
r.green.biomassfor.impact forest=name boundaries=name forest_column_yield=string forest_column_yield_surface=string forest_column_management=string forest_column_treatment=string forest_roads=name energy_map=name dhp=name output_basename_co2map=name output_basename_aco2map=name output_basename_nco2map=name
grass.script.run_command("r.green.biomassfor.impact", forest, boundaries, forest_column_yield, forest_column_yield_surface, forest_column_management, forest_column_treatment, forest_roads, forest_column_roughness=None, rivers=None, lakes=None, energy_tops_hf=0.49, energy_cormometric_vol_hf=1.97, energy_tops_cop=0.55, energy_map, dhp, output_sw_map=None, dtm=None, soiltx_map=None, soild_map=None, soilcmp_map=None, output_basename_co2map, output_basename_aco2map, output_basename_nco2map, dtm2=None, forest_column_roughness=None, soilp2_map=None, tree_diam=None, tree_vol=None, main_roads=None, slp_min_cc=30., slp_max_cc=100., dist_max_cc=800., slp_max_fw=30., dist_max_fw=600., slp_max_cop=30., dist_max_cop=600., output_fr_map=None, firerisk_map=None, output_tot_re_map=None, output_imp_re_map=None, touristic_map=None, tev=None, field_tev=None, area_tev=None, output_tev=None, expl=None, impact=0, base=None, flags=None, overwrite=False, verbose=False, quiet=False, superquiet=False)
Example:
gs.run_command("r.green.biomassfor.impact", forest="name", boundaries="name", forest_column_yield="string", forest_column_yield_surface="string", forest_column_management="string", forest_column_treatment="string", forest_roads="name", energy_map="name", dhp="name", output_basename_co2map="name", output_basename_aco2map="name", output_basename_nco2map="name")
Parameters
forest=name [required]
    Name of vector parcel map
boundaries=name [required]
    Name of vector boundaries map (boolean map)
forest_column_yield=string [required]
    Vector field of yield
forest_column_yield_surface=string [required]
    Vector field of stand surface (ha)
forest_column_management=string [required]
    Vector field of forest management (1: high forest, 2:coppice)
forest_column_treatment=string [required]
    Vector field of forest treatment (1: final felling, 2:thinning)
forest_roads=name [required]
    Vector map of forest roads
    Vector field of roughness
rivers=name
    Vector map of rivers
lakes=name
    Vector map of lakes
    Vector map of lakes
    Energy for tops and branches in high forest in MWh/m3
    Default: 0.49
    Energy for tops and branches for high forest in MWh/m3
    Default: 1.97
    Energy for tops and branches for Coppices in MWh/m3
    Default: 0.55
energy_map=name [required]
    Bioenergy map in MWh/m3
dhp=name [required]
    Name of vector district heating points
output_sw_map=name
    Name for output soil and water reduction bioenergy map
dtm=name
    Name of Digital terrain model map
soiltx_map=name
    Soil texture map
soild_map=name
    Soil depth map
soilcmp_map=name
    Soil compaction risk map
output_basename_co2map=name [required]
    Name for output CO2 emissions map
output_basename_aco2map=name [required]
    Name for output avoided CO2 emissions map
output_basename_nco2map=name [required]
    Name for output net CO2 emissions map
dtm2=name
soilp2_map=name
    Soil production map
tree_diam=name
    Average tree diameter map
tree_vol=name
    Average tree volume map
main_roads=name
    Vector map of main roads
slp_min_cc=float
    Percent slope lower limit with Cable Crane
    Default: 30.
slp_max_cc=float
    Percent slope higher limit with Cable Crane
    Default: 100.
dist_max_cc=float
    Maximum distance with Cable Crane
    Default: 800.
slp_max_fw=float
    Percent slope higher limit with Forwarder
    Default: 30.
dist_max_fw=float
    Maximum distance with Forwarder
    Default: 600.
slp_max_cop=float
    Percent slope higher limit with other techniques for Coppices
    Default: 30.
dist_max_cop=float
    Maximum distance with other techniques for Coppices
    Default: 600.
output_fr_map=name
    Name for output reduction map of fire risk
firerisk_map=name
    Fire risk map
    Name for output total recreational map
    Name for output improved recreational map
touristic_map=name
    Touristic map
tev=name
    Name of vector Total Economic Value map
field_tev=name
    Name of field with TEV value
area_tev=name
    Area of TEV polygons
output_tev=name
    TEV result
expl=name
    Exploited areas [Energy/m2]
impact=float
    Percentange of the impact
    Default: 0
base=name
    Map of the reference situation for the impact
-r
    Remove all operational maps
--overwrite
--help
    Print usage summary
--verbose
    Verbose module output
--quiet
    Quiet module output
--qq
    Very quiet module output
--ui
    Force launching GUI dialog
forest : str, required
    Used as: input, vector, name
boundaries : str, required
forest_column_yield : str, required
forest_column_yield_surface : str, required
forest_column_management : str, required
forest_column_treatment : str, required
forest_roads : str, required
forest_column_roughness : str, optional
rivers : str, optional
lakes : str, optional
    Vector map of lakes
    Vector map of lakes
energy_tops_hf : float, optional
    Default: 0.49
energy_cormometric_vol_hf : float, optional
    Default: 1.97
energy_tops_cop : float, optional
    Default: 0.55
energy_map : str, required
    Used as: input, raster, name
dhp : str, required
output_sw_map : str, optional
    Used as: name
dtm : str, optional
soiltx_map : str, optional
    Soil texture map
soild_map : str, optional
    Soil depth map
soilcmp_map : str, optional
output_basename_co2map : str, required
    Used as: output, raster, name
output_basename_aco2map : str, required
output_basename_nco2map : str, required
dtm2 : str, optional
soilp2_map : str, optional
    Soil production map
tree_diam : str, optional
tree_vol : str, optional
main_roads : str, optional
slp_min_cc : float, optional
    Default: 30.
slp_max_cc : float, optional
    Default: 100.
dist_max_cc : float, optional
    Default: 800.
slp_max_fw : float, optional
    Default: 30.
dist_max_fw : float, optional
    Default: 600.
slp_max_cop : float, optional
    Default: 30.
dist_max_cop : float, optional
    Default: 600.
output_fr_map : str, optional
firerisk_map : str, optional
    Fire risk map
output_tot_re_map : str, optional
output_imp_re_map : str, optional
touristic_map : str, optional
    Touristic map
tev : str, optional
field_tev : str, optional
    Used as: name
area_tev : str, optional
    Used as: name
output_tev : str, optional
    TEV result
    Used as: output, , name
expl : str, optional
impact : float, optional
    Default: 0
base : str, optional
flags : str, optional
    Allowed values: r
    r
overwrite: bool, optional
    Default: False
verbose: bool, optional
    Default: False
quiet: bool, optional
    Quiet module output
    Default: False
superquiet: bool, optional
    Default: False
DESCRIPTION
Compute the impact of using biomass forestry residuals for energy production.
NOTES
EXAMPLE
REFERENCE
SEE ALSO
r.green, r.green.biomassfor
AUTHORS
Francesco Geri, Pietro Zambelli, Sandro Sacchelli, Marco Ciolli
SOURCE CODE
Available at: r.green.biomassfor.impact source code (history)
Latest change: Thursday Feb 20 13:02:26 2025 in commit 53de819
