r.green.biomassfor.recommended
Estimates potential bioenergy according to environmental restriction
r.green.biomassfor.recommended hfmap=name cmap=name output_basename=name management=name treatment=name [restrictions=name [,name,...]] [hydro=name] [buffer_hydro=integer] [zone_less=name] [energy_tops_hf=float] [energy_cormometric_vol_hf=float] [energy_tops_cop=float] [--overwrite] [--verbose] [--quiet] [--qq] [--ui]
Example:
grass.script.run_command("r.green.biomassfor.recommended", hfmap, cmap, output_basename, management, treatment, restrictions=None, hydro=None, buffer_hydro=0, zone_less=None, energy_tops_hf=0.49, energy_cormometric_vol_hf=1.97, energy_tops_cop=0.55, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
gs.run_command("r.green.biomassfor.recommended", hfmap="name", cmap="name", output_basename="name", management="name", treatment="name")
grass.tools.Tools.r_green_biomassfor_recommended(hfmap, cmap, output_basename, management, treatment, restrictions=None, hydro=None, buffer_hydro=0, zone_less=None, energy_tops_hf=0.49, energy_cormometric_vol_hf=1.97, energy_tops_cop=0.55, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
tools = Tools()
tools.r_green_biomassfor_recommended(hfmap="name", cmap="name", output_basename="name", management="name", treatment="name")
Parameters
hfmap=name [required]
Bioenergy potential map for High Forest in MWh/m3
cmap=name [required]
Bioenergy potential map for Coppice in MWh/m3
output_basename=name [required]
Basename for final recommended maps of bioenergy (HF,CC and total)
management=name [required]
Map of forest management (1: high forest, 2:coppice)
treatment=name [required]
Map of forest treatment (1: final felling, 2:thinning)
Area with absolute restrictions (protected areas, urban parks etc.)
hydro=name
Rivers network
Buffer area for rivers
Default: 0
zone_less=name
Civic use
Energy for tops and branches in high forest in MWh/m3
Default: 0.49
Energy for tops and branches for high forest in MWh/m3
Default: 1.97
Energy for tops and branches for Coppices in MWh/m3
Default: 0.55
--overwrite
--help
Print usage summary
--verbose
Verbose module output
--quiet
Quiet module output
--qq
Very quiet module output
--ui
Force launching GUI dialog
hfmap : str, required
Used as: input, raster, name
cmap : str, required
output_basename : str, required
Used as: output, , name
management : str, required
treatment : str, required
restrictions : str | list[str], optional
hydro : str, optional
Rivers network
buffer_hydro : int, optional
Default: 0
zone_less : str, optional
Civic use
energy_tops_hf : float, optional
Default: 0.49
energy_cormometric_vol_hf : float, optional
Default: 1.97
energy_tops_cop : float, optional
Default: 0.55
overwrite : bool, optional
Default: None
verbose : bool, optional
Default: None
quiet : bool, optional
Quiet module output
Default: None
superquiet : bool, optional
Default: None
hfmap : str | np.ndarray, required
cmap : str | np.ndarray, required
management : str | np.ndarray, required
treatment : str | np.ndarray, required
hydro : str | np.ndarray, optional
Rivers network
Default: 0
zone_less : str | np.ndarray, optional
Civic use
Default: 0.49
Default: 1.97
Default: 0.55
Default: None
Default: None
Quiet module output
Default: None
Default: None
Returns:
Raises:
DESCRIPTION
Compute the biomass forestry residual potential considering extra constraints.
NOTES
EXAMPLE
REFERENCE
SEE ALSO
AUTHORS
Francesco Geri, Pietro Zambelli, Sandro Sacchelli, Marco Ciolli
SOURCE CODE
Available at: r.green.biomassfor.recommended source code
(history)
Latest change: Wednesday Mar 11 08:17:30 2026 in commit 2a14bbb
