r.green.biomassfor.technical
Estimates the quantity of woody biomass obtained from a forest surface where extraction is possible given a particular level of mechanisation
r.green.biomassfor.technical [-r] dtm=name forest=name boundaries=name forest_column_yield=string forest_column_yield_surface=string forest_column_management=string forest_column_treatment=string forest_roads=name output_basename=name [forest_column_roughness=string] [rivers=name] [lakes=name] [slp_min_cc=float] [slp_max_cc=float] [dist_max_cc=float] [slp_max_fw=float] [dist_max_fw=float] [slp_max_cop=float] [dist_max_cop=float] [energy_tops_hf=float] [energy_cormometric_vol_hf=float] [energy_tops_cop=float] [--overwrite] [--verbose] [--quiet] [--qq] [--ui]
Example:
r.green.biomassfor.technical dtm=name forest=name boundaries=name forest_column_yield=string forest_column_yield_surface=string forest_column_management=string forest_column_treatment=string forest_roads=name output_basename=name
grass.script.run_command("r.green.biomassfor.technical", dtm, forest, boundaries, forest_column_yield, forest_column_yield_surface, forest_column_management, forest_column_treatment, forest_roads, output_basename, forest_column_roughness=None, rivers=None, lakes=None, slp_min_cc=30., slp_max_cc=100., dist_max_cc=800., slp_max_fw=30., dist_max_fw=600., slp_max_cop=30., dist_max_cop=600., energy_tops_hf=0.49, energy_cormometric_vol_hf=1.97, energy_tops_cop=0.55, flags=None, overwrite=False, verbose=False, quiet=False, superquiet=False)
Example:
gs.run_command("r.green.biomassfor.technical", dtm="name", forest="name", boundaries="name", forest_column_yield="string", forest_column_yield_surface="string", forest_column_management="string", forest_column_treatment="string", forest_roads="name", output_basename="name")
Parameters
dtm=name [required]
Name of Digital terrain model map
forest=name [required]
Name of vector parcel map
boundaries=name [required]
Name of vector boundaries map (boolean map)
forest_column_yield=string [required]
Vector field of yield
forest_column_yield_surface=string [required]
Vector field of stand surface (ha)
forest_column_management=string [required]
Vector field of forest management (1: high forest, 2:coppice)
forest_column_treatment=string [required]
Vector field of forest treatment (1: final felling, 2:thinning)
forest_roads=name [required]
Vector map of forest roads
output_basename=name [required]
Basename for technical bioenergy (HF,CC and total)
Vector field of roughness
rivers=name
Vector map of rivers
lakes=name
Vector map of lakes
Vector map of lakes
slp_min_cc=float
Percent slope lower limit with Cable Crane
Default: 30.
slp_max_cc=float
Percent slope higher limit with Cable Crane
Default: 100.
dist_max_cc=float
Maximum distance with Cable Crane
Default: 800.
slp_max_fw=float
Percent slope higher limit with Forwarder
Default: 30.
dist_max_fw=float
Maximum distance with Forwarder
Default: 600.
slp_max_cop=float
Percent slope higher limit with other techniques for Coppices
Default: 30.
dist_max_cop=float
Maximum distance with other techniques for Coppices
Default: 600.
Energy for tops and branches in high forest in MWh/m3
Default: 0.49
Energy for the whole tree in high forest (tops, branches and stem) in MWh/m3
Default: 1.97
Energy for tops and branches for Coppices in MWh/m3
Default: 0.55
-r
Remove all operational maps
--overwrite
--help
Print usage summary
--verbose
Verbose module output
--quiet
Quiet module output
--qq
Very quiet module output
--ui
Force launching GUI dialog
dtm : str, required
Used as: input, raster, name
forest : str, required
Used as: input, vector, name
boundaries : str, required
forest_column_yield : str, required
forest_column_yield_surface : str, required
forest_column_management : str, required
forest_column_treatment : str, required
forest_roads : str, required
output_basename : str, required
Used as: output, , name
forest_column_roughness : str, optional
rivers : str, optional
lakes : str, optional
Vector map of lakes
Vector map of lakes
slp_min_cc : float, optional
Default: 30.
slp_max_cc : float, optional
Default: 100.
dist_max_cc : float, optional
Default: 800.
slp_max_fw : float, optional
Default: 30.
dist_max_fw : float, optional
Default: 600.
slp_max_cop : float, optional
Default: 30.
dist_max_cop : float, optional
Default: 600.
energy_tops_hf : float, optional
Default: 0.49
energy_cormometric_vol_hf : float, optional
Default: 1.97
energy_tops_cop : float, optional
Default: 0.55
flags : str, optional
Allowed values: r
r
overwrite: bool, optional
Default: False
verbose: bool, optional
Default: False
quiet: bool, optional
Quiet module output
Default: False
superquiet: bool, optional
Default: False
DESCRIPTION
Compute the biomass forestry residual potential considering the technical constraints of different harvesting techniques.
NOTES
EXAMPLE
REFERENCE
SEE ALSO
AUTHORS
Francesco Geri, Pietro Zambelli, Sandro Sacchelli, Marco Ciolli
SOURCE CODE
Available at: r.green.biomassfor.technical source code
(history)
Latest change: Thursday Feb 20 13:02:26 2025 in commit 53de819
