r.richdem.terrainattribute
Calculates local terrain attributes.
r.richdem.terrainattribute input=name attribute=string [zscale=float] output=name [--overwrite] [--verbose] [--quiet] [--qq] [--ui]
Example:
sh
r.richdem.terrainattribute input=name attribute=slope_riserun output=name
grass.script.run_command("r.richdem.terrainattribute", input, attribute, zscale=1.0, output, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
python
gs.run_command("r.richdem.terrainattribute", input="name", attribute="slope_riserun", output="name")
grass.tools.Tools.r_richdem_terrainattribute(input, attribute, zscale=1.0, output, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
python
tools = Tools()
tools.r_richdem_terrainattribute(input="name", attribute="slope_riserun", output="name")
Parameters
input=name [required]
Input DEM
Name of input raster map
attribute=string [required]
Terrain attribute to calculate.
Allowed values: slope_riserun, slope_percentage, slope_degrees, slope_radians, aspect, curvature, planform_curvature, profile_curvature
zscale=float
Scalar multiplier for elevation (vertical exaggeration)
Default: 1.0
output=name [required]
Output DEM with depressions filled
Name for output raster map
--overwrite
--help
Print usage summary
--verbose
Verbose module output
--quiet
Quiet module output
--qq
Very quiet module output
--ui
Force launching GUI dialog
input : str, required
Input DEM
Used as: input, raster, name
attribute : str, required
zscale : float, optional
Default: 1.0
output : str, required
Used as: output, raster, name
overwrite : bool, optional
Default: None
verbose : bool, optional
Default: None
quiet : bool, optional
Quiet module output
Default: None
superquiet : bool, optional
Default: None
input : str | np.ndarray, required
Input DEM
Default: 1.0
Default: None
Default: None
Quiet module output
Default: None
Default: None
Returns:
Raises:
DESCRIPTION
PLACEHOLDER
REFERENCES
PLACEHOLDER
SEE ALSO
AUTHORS
Richard Barnes (algorithm and codebase), Andrew D. Wickert (GRASS frontend)
SOURCE CODE
Available at: r.richdem.terrainattribute source code
(history)
Latest change: Wednesday Mar 11 08:17:30 2026 in commit 2a14bbb
