r.wateroutlet.lessmem
Creates watershed basins from a drainage direction map.
r.wateroutlet.lessmem input=name output=name coordinates=east,north [--overwrite] [--verbose] [--quiet] [--qq] [--ui]
Example:
sh
r.wateroutlet.lessmem input=name output=name coordinates=0.0
grass.script.run_command("r.wateroutlet.lessmem", input, output, coordinates, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
python
gs.run_command("r.wateroutlet.lessmem", input="name", output="name", coordinates=0.0)
grass.tools.Tools.r_wateroutlet_lessmem(input, output, coordinates, overwrite=None, verbose=None, quiet=None, superquiet=None)
Example:
python
tools = Tools()
tools.r_wateroutlet_lessmem(input="name", output="name", coordinates=0.0)
Parameters
input=name [required]
Name of input drainage direction map
output=name [required]
Name for output watershed basin map
coordinates=east,north [required]
Coordinates of outlet point
--overwrite
--help
Print usage summary
--verbose
Verbose module output
--quiet
Quiet module output
--qq
Very quiet module output
--ui
Force launching GUI dialog
input : str, required
Used as: input, raster, name
output : str, required
Used as: output, raster, name
coordinates : tuple[float, float] | list[float] | str, required
Used as: input, coords, east,north
overwrite : bool, optional
Default: None
verbose : bool, optional
Default: None
quiet : bool, optional
Quiet module output
Default: None
superquiet : bool, optional
Default: None
input : str | np.ndarray, required
Default: None
Default: None
Quiet module output
Default: None
Default: None
Returns:
Raises:
DESCRIPTION
r.wateroutlet.lessmem is a modified version of r.water.outlet and requires about one third of memory compared to the original module. Input drainage direction information is stored as 4-bit segments in the buffer and output basin result is stored as 1-bit data. Because of heavy bitwise operations, there may be some performance penalty depending on the size of the input map. Other than memory management, this module uses the same interface and algorithm in r.water.outlet, so please refer to r.water.outlet for more details.
SEE ALSO
AUTHOR
Huidae Cho
based on
r.water.outlet
SOURCE CODE
Available at: r.wateroutlet.lessmem source code
(history)
Latest change: Wednesday Mar 11 08:17:30 2026 in commit 2a14bbb
